Home » Modeling » TMF (Xtext) » Outline does not work(elements with <unnamed>)
Outline does not work [message #831103] Wed, 28 March 2012 09:34 Go to next message
Hi everybody,
I have implemented a DSL with xtext but when I run it as Eclipse Aplication I am not able to see the correct outline tree. Each element has the name <unnamed> until the first one, like:
myDsl
<unnamed>
<unnamed>
<unnamed>
<unnamed>
<unnamed>
<unnamed>
What's wrong or have I forgot something? I only want the default outline tree, therefore the outline API is enabled
// outline API
fragment = outline.OutlineTreeProviderFragment {}
fragment = outline.QuickOutlineFragment {}
I am using XText2.2.1
Many thanks for your help,
Joe
[Updated on: Wed, 28 March 2012 09:43] by Moderator
Re: Outline does not work [message #831203 is a reply to message #831103] Wed, 28 March 2012 11:49 Go to previous messageGo to next message
Hi does you grammar NOT have name attributes at the places of the
outline nodes. Did you implement a label provider as the docs
suggest?
Re: Outline does not work [message #831842 is a reply to message #831203] Thu, 29 March 2012 08:25 Go to previous messageGo to next message
thanks for this information Smile . Now I have added to the MyDomainLabelProvider the following functions (as example):
String text(Class class){
   return "Class "+ele.getName();
String text(Function fun){
   return "Function";
Of course, as example now the tree looks like
Class [MyClass]
  Function
  Function
The problem is, that "Function" has no method getName() (fun.getName() does not work)
The name of the function is shown in the tree deeper. How can I put the name for the function to an upper level of the tree like:
Class [MyClass]
  Function [MyFunction1]
  Function [MyFunction2]
Many thanks,
Joe
Re: Outline does not work [message #831851 is a reply to message #831842] Thu, 29 March 2012 08:38 Go to previous messageGo to next message
Read the docs on the outline.
Re: Outline does not work [message #834981 is a reply to message #831851] Mon, 02 April 2012 12:35 Go to previous message
Hi Christian,
thanks, I solved it Smile
Previous Topic:"mixed" global scoping
Next Topic:limit cross reference boundary by scoping
Current Time: Sat Jul 19 09:48:07 EDT 2025
Powered by FUDForum. Page generated in 0.06843 seconds
