Home » Modeling » TMF (Xtext) » problems for JvmType references when executing tests with Tycho
problems for JvmType references when executing tests with Tycho [message #831090] Wed, 28 March 2012 09:02 Go to next message
I've just started using Tycho (and Jenkins) for building and testing my
Xtext languages (I'm a Tycho newbie so I don't know whether the problem
lies in Xtext or Tycho).
In my DSL I use Xbase expressions and I have some tests for my Dsl that
refer to JvmType (relying also on imports), say something like this:
import org.eclipse.emf.ecore.*
import my.own.plugin.MyClass
var EClass eClass
var MyClass myClass
and of course my test plugin project has a dependency on my.own.plugin
when I run Junit tests (non UI) from Eclipse I have no problems with
such test files (by using ParserHelper and ValidatorHelper);
but when those tests are run using Maven/Tycho, every reference to a
Java class of my.own.plugin produces an error (Couldn't resolve
reference to JvmType 'MyClass'); while there are no problems for
referring to ecore Java classes...
in Tycho I execute the test using a suite, something like
<configuration>
<testSuite>mydslplugin.tests</testSuite>
<testClass>mydslplugin.tests.suites.AllTests</testClass>
<useUIHarness>false</useUIHarness>
<useUIThread>false</useUIThread>
</configuration>
am I missing something?
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: problems for JvmType references when executing tests with Tycho [message #832572 is a reply to message #831090] Fri, 30 March 2012 05:42 Go to previous messageGo to next message
I found the solution myself, and I thought that it might help others
first of all, an easy way to reproduce the problem in eclipse is to run
the Junit tests as Junit Plugin tests, without changing the injector
(i.e., DON'T use the ui injector provider). This seems to recreate the
situation when these headless tests are run by Maven/Tycho.
In order to make the tests work (i.e., make xbase expressions be able to
refer to external Java classes, on which the test plugin explicitly
depends), you need to follow the same approach of the domain model test
plugin: have a custom standalonesetup and a custom injector provider
which bindClassLoaderToInstance (I had always wondered why you need to
customize the injector provider like that :)
for instance (with Xtext 2.3 the customization is different, but again
you can take a look at the domain model example shipped with Xtext 2.3)
public class MyDslInjectorProviderCustom extends
MyDslInjectorProvider {
public static class MyDslStandaloneSetupForTests extends
MyDslStandaloneSetup {
public Injector createInjector() {
return Guice.createInjector(new MyDslRuntimeModule() {
public ClassLoader bindClassLoaderToInstance() {
return MyDslInjectorProviderCustom.class
.getClassLoader();
private Injector injector = new MyDslStandaloneSetupForTests()
.createInjectorAndDoEMFRegistration();
public Injector getInjector() {
return injector;
I separated also the customized standalonesetup so that you can use the
custom setup in tests using AbstractXtextTests, e.g.,
with(MyDslStandaloneSetupForTests.class)
for the tests that use XtextRunner, you simply use the custom injector
provider
@InjectWith(typeof(MyDslInjectorProviderCustom))
@RunWith(typeof(XtextRunner))
hope this helps :)
cheers
Lorenzo
On 03/28/2012 03:02 PM, Lorenzo Bettini wrote:
> Hi
> var EClass eClass
> var MyClass myClass
> <configuration>
> </configuration>
> thanks in advance
> Lorenzo
Re: problems for JvmType references when executing tests with Tycho [message #895632 is a reply to message #832572] Fri, 13 July 2012 17:11 Go to previous messageGo to next message
Hi Lorenzo,
are you using tycho-surefire-plugin ?
if so, could you share the entire plugin configuration?
thanks,
Cristiano
Re: problems for JvmType references when executing tests with Tycho [message #895675 is a reply to message #895632] Sat, 14 July 2012 13:30 Go to previous message
On 07/13/2012 11:11 PM, Cristiano Gaviao wrote:
> Hi Lorenzo,
> thanks,
> Cristiano
Cristiano
I abandoned tycho in favor of Buckminster (thanks to the wizard shipped
with Xtext 2.3.0) and I don't have strange building and testing problems
anymore :)
cheers
Lore
Previous Topic:Xcore validation
Next Topic:Completion from POJO
Current Time: Sun Jul 20 12:26:39 EDT 2025
Powered by FUDForum. Page generated in 0.04352 seconds
