Home » Modeling » GMF (Graphical Modeling Framework) » Change "Arrange All" Orientation
Change "Arrange All" Orientation [message #811483] Fri, 02 March 2012 06:58 Go to next message
Hello i have a question on customizing behaviour of the "Arrange All" function.
Normally all the nodes in are arranged "Bottom-up" as shown in the picture i appended.
Can i change this to a "Top-Down" Orientation quickly , without writing new layouts etc. ?
I think this is a typical use-case so it would be great if it can be fixed quickly.
Greetings
  • Attachment: default.jpeg
    (Size: 30.45KB, Downloaded 337 times)
Re: Change "Arrange All" Orientation [message #813447 is a reply to message #811483] Mon, 05 March 2012 04:17 Go to previous messageGo to next message
I don't know exactly how to do this, but you can have a look to method
org.eclipse.gmf.runtime.diagram.ui.providers.internal.DefaultProvider.layoutTopDown(ConnectionEditPart)
that handles this functionality.
Laurent
> Greetings
Re: Change "Arrange All" Orientation [message #829916 is a reply to message #813447] Mon, 26 March 2012 20:36 Go to previous messageGo to next message
This is what this function did :
protected boolean layoutTopDown(ConnectionEditPart poly) {
return false;
So i think you are wrong.
Re: Change "Arrange All" Orientation [message #829945 is a reply to message #829916] Mon, 26 March 2012 21:42 Go to previous messageGo to next message
solved
Re: Change "Arrange All" Orientation [message #831182 is a reply to message #829945] Wed, 28 March 2012 11:16 Go to previous messageGo to next message
On 27/03/2012 03:42, Snakebyte Mising name wrote:
> solved
Could you say how for other persons that would have the same question?
Laurent
Re: Change "Arrange All" Orientation [message #837799 is a reply to message #831182] Fri, 06 April 2012 01:25 Go to previous messageGo to next message
Currently trying to achieve the same. It would really help if you could let us know how you did it. Smile
Re: Change "Arrange All" Orientation [message #837804 is a reply to message #837799] Fri, 06 April 2012 01:37 Go to previous message
Found it!
Add the following extension to plugin.xml (of the generated GMF diagram project).
<extension point="org.eclipse.gmf.runtime.diagram.ui.layoutProviders">
<?gmfgen generated="false"?>
 <layoutProvider class="org.eclipse.gmf.runtime.diagram.ui.providers.TopDownProvider">
  <Priority name="High"></Priority>
 </layoutProvider>
</extension>
Previous Topic:How to add 2D/3D animation to a GMF generated diagram surface
Next Topic:GMF UI fill error
Current Time: Sat Jul 19 19:36:03 EDT 2025
Powered by FUDForum. Page generated in 0.03696 seconds
