Home » Eclipse Projects » WindowBuilder » NoClassDefFound Exception cglib/Callback(Error while parsing)
NoClassDefFound Exception cglib/Callback [message #815582] Wed, 07 March 2012 15:52 Go to next message
Hi Folks,
I'm using WindowsBuilder Pro newly. First, I plugged in to eclipse which is stand on my Xubuntu Virtual Machine. After a few tries, i decided to setup on windows either. But, although that i applied the same procedure to setup, when i try to switch design mode of a JFrame i get the error below:
Internal Error
encountered unexpected internal error.
This could be caused by a bug or by a misconfiguration issue, conflict, partial update, etc.
java.lang.NoClassDefFoundError: net/sf/cglib/proxy/Callback
Show stack trace.
Hide stack trace.
Stack trace:
java.lang.ClassNotFoundException: net.sf.cglib.proxy.Callback
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:513)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:429)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:417)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at org.eclipse.wb.internal.core.utils.state.EditorState.getBroadcast(EditorState.java:130)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.<init>(JavaInfoParser.java:217)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.<init>(JavaInfoParser.java:209)
	at org.eclipse.wb.internal.core.parser.JavaInfoParser.parse(JavaInfoParser.java:150)
	at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:537)
	at org.eclipse.wb.internal.core.editor.DesignPage.access$9(DesignPage.java:525)
	at org.eclipse.wb.internal.core.editor.DesignPage$8$1.run(DesignPage.java:452)
	at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
	at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
	at org.eclipse.swt.widgets.Display.syncExec(Display.java:4683)
	at org.eclipse.wb.internal.core.editor.DesignPage$8.run(DesignPage.java:449)
	at org.eclipse.jface.operation.ModalContext.runInCurrentThread(ModalContext.java:464)
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:372)
	at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
	at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF_withProgress(DesignPage.java:468)
	at org.eclipse.wb.internal.core.editor.DesignPage.internal_refreshGEF(DesignPage.java:418)
	at org.eclipse.wb.internal.core.editor.UndoManager.refreshDesignerEditor(UndoManager.java:381)
	at org.eclipse.wb.internal.core.editor.UndoManager.activate(UndoManager.java:90)
	at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState_True(DesignPage.java:266)
	at org.eclipse.wb.internal.core.editor.DesignPage.handleActiveState(DesignPage.java:244)
	at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.showPage(DefaultMultiMode.java:125)
	at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode$1.widgetSelected(DefaultMultiMode.java:63)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
	at org.eclipse.swt.custom.CTabFolder.setSelection(CTabFolder.java:2746)
	at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1433)
	at org.eclipse.swt.custom.CTabFolder$1.handleEvent(CTabFolder.java:257)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
	at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
	at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
	at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
	at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
	at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Full context stack trace:
Caused by: java.lang.ClassNotFoundException: net.sf.cglib.proxy.Callback
	... 56 more
I added the cglib.jar as referenced library to my project configuration, but still i got the same issue.
Any helps will be appreciated, Umutcan.
Edit: I'm using Swing Designer.
[Updated on: Wed, 07 March 2012 15:58] by Moderator
Re: NoClassDefFound Exception cglib/Callback [message #815737 is a reply to message #815582] Wed, 07 March 2012 20:37 Go to previous messageGo to next message
I would suggest posting a test case.
Re: NoClassDefFound Exception cglib/Callback [message #815746 is a reply to message #815737] Wed, 07 March 2012 20:49 Go to previous messageGo to next message
I have no idea.
I can only repeat error message - there is some installation problem.
Eclipse error log (workspace/.metadata/.log) may help, may be there are OSGi messages about problems with installed bundles.
But easier would be try to install WB again.
Re: NoClassDefFound Exception cglib/Callback [message #816372 is a reply to message #815746] Thu, 08 March 2012 14:26 Go to previous messageGo to next message
@Eric If you don't mind, can you explain that what did you mean with "test case". what kind of test?
Thank you for answering. I'm going to install again, at last resort.
Re: NoClassDefFound Exception cglib/Callback [message #816579 is a reply to message #816372] Thu, 08 March 2012 21:15 Go to previous messageGo to next message
Umutcan Simsek wrote on Thu, 08 March 2012 14:26
See the docs.
[Updated on: Thu, 08 March 2012 21:15] by Moderator
Re: NoClassDefFound Exception cglib/Callback [message #819668 is a reply to message #816579] Tue, 13 March 2012 03:17 Go to previous messageGo to next message
No Message Body
Re: NoClassDefFound Exception cglib/Callback [message #819669 is a reply to message #819668] Tue, 13 March 2012 03:17 Go to previous messageGo to next message
Umutcan
Do you resolve the problem
" WindowBuilder java.lang.NoClassDefFoundError: net/sf/cglib/proxy/Callback " ?
if you have solved , please tell me the skill ,thanks very much !
Re: NoClassDefFound Exception cglib/Callback [message #826262 is a reply to message #819669] Wed, 21 March 2012 17:45 Go to previous message
I would suggest a full reinstall of Eclipse and WindowBuilder.
CGLib is located in the org.eclipse.wb.runtime.lib plugin (in the cglib-nodep-2.2.jar file). If you don't have that, it suggests an install issue of some sort.
Previous Topic:Install Window Builder on Ubuntu 11.10
Next Topic:Cannot use window builder on e4
Current Time: Sat Jul 19 17:33:07 EDT 2025
Powered by FUDForum. Page generated in 0.05137 seconds
