Building the designer, Nullpointer in DEUtil.java [message #824922] |
Tue, 20 March 2012 04:39  |
Hi there,
i checked out the resources via eclipse cvs plugin, and build the designer successfully with the export wizard from the .product-file. The build is successfull and the designer starts on my ubuntu. Clicking the "new" button, selecting the "Report"-entry and clicking "Next>" will generate a NullPointerException in DEUtil like this:
at org.eclipse.core.internal.runtime.FindSupport.findInPlugin(FindSupport.java:232)
at org.eclipse.core.internal.runtime.FindSupport.find(FindSupport.java:99)
at org.eclipse.core.internal.runtime.FindSupport.find(FindSupport.java:60)
at org.eclipse.core.runtime.FileLocator.find(FileLocator.java:84)
at org.eclipse.birt.report.designer.util.DEUtil.getDefaultLibraryHandle(DEUtil.java:3235)
at org.eclipse.birt.report.designer.internal.ui.wizards.WizardTemplateChoicePage.getDefaultLibraryHandleFromResource(WizardTemplateChoicePage.java:1043)
at org.eclipse.birt.report.designer.internal.ui.wizards.WizardTemplateChoicePage.createControl(WizardTemplateChoicePage.java:350)
the line of code which went wrong is:
URL url = FileLocator.find( Platform.getBundle( IResourceLocator.FRAGMENT_RESOURCE_HOST ),
new Path( DEFAULT_LIBRARY ),
null );
DEFAULT_LIBRARY is defined like this:
public static final String DEFAULT_LIBRARY = "/ThemesReportItems.rptlibrary"; //$NON-NLS-1$
i searched the whole repo, but i can't find a file ThemesReportItems.rptlibrary there. what am i missing?
Consequence of this is an empty wizardpage showing up, so i can't create an emtpy / new report.
thx in advance,
hag
[Updated on: Tue, 20 March 2012 04:48] by Moderator
Re: Building the designer, Nullpointer in DEUtil.java [message #1077593 is a reply to message #824987] |
Thu, 01 August 2013 19:08  |
Thanks, your suggestion solved it for me, too. The only plugins I needed to add were all the org.eclipse.birt ones (and their non-optional dependencies). I've listed the full list below, for reference (this is with BIRT 4.2.2). It would be nice if someone would figure out why the default list is insufficient.
<plugin id="com.ibm.icu"/>
<plugin id="com.lowagie.text"/>
<plugin id="javax.annotation"/>
<plugin id="javax.el"/>
<plugin id="javax.inject"/>
<plugin id="javax.servlet"/>
<plugin id="javax.servlet.jsp"/>
<plugin id="javax.wsdl"/>
<plugin id="javax.xml"/>
<plugin id="javax.xml.rpc"/>
<plugin id="javax.xml.soap"/>
<plugin id="org.apache.axis"/>
<plugin id="org.apache.batik.bridge"/>
<plugin id="org.apache.batik.css"/>
<plugin id="org.apache.batik.dom"/>
<plugin id="org.apache.batik.dom.svg"/>
<plugin id="org.apache.batik.ext.awt"/>
<plugin id="org.apache.batik.parser"/>
<plugin id="org.apache.batik.pdf"/>
<plugin id="org.apache.batik.svggen"/>
<plugin id="org.apache.batik.transcoder"/>
<plugin id="org.apache.batik.util"/>
<plugin id="org.apache.batik.util.gui"/>
<plugin id="org.apache.batik.xml"/>
<plugin id="org.apache.commons.codec"/>
<plugin id="org.apache.commons.discovery"/>
<plugin id="org.apache.commons.logging"/>
<plugin id="org.apache.derby.core"/>
<plugin id="org.apache.jasper.glassfish"/>
<plugin id="org.apache.lucene"/>
<plugin id="org.apache.lucene.analysis"/>
<plugin id="org.apache.lucene.core"/>
<plugin id="org.apache.xerces"/>
<plugin id="org.apache.xml.resolver"/>
<plugin id="org.apache.xml.serializer"/>
<plugin id="org.eclipse.birt.axis.overlay" fragment="true"/>
<plugin id="org.eclipse.birt.chart.cshelp"/>
<plugin id="org.eclipse.birt.chart.device.extension"/>
<plugin id="org.eclipse.birt.chart.device.pdf"/>
<plugin id="org.eclipse.birt.chart.device.svg"/>
<plugin id="org.eclipse.birt.chart.device.swt"/>
<plugin id="org.eclipse.birt.chart.engine"/>
<plugin id="org.eclipse.birt.chart.engine.extension"/>
<plugin id="org.eclipse.birt.chart.examples"/>
<plugin id="org.eclipse.birt.chart.examples.core"/>
<plugin id="org.eclipse.birt.chart.reportitem"/>
<plugin id="org.eclipse.birt.chart.reportitem.ui"/>
<plugin id="org.eclipse.birt.chart.ui"/>
<plugin id="org.eclipse.birt.chart.ui.extension"/>
<plugin id="org.eclipse.birt.core"/>
<plugin id="org.eclipse.birt.core.script.function"/>
<plugin id="org.eclipse.birt.core.ui"/>
<plugin id="org.eclipse.birt.cshelp"/>
<plugin id="org.eclipse.birt.data"/>
<plugin id="org.eclipse.birt.data.aggregation"/>
<plugin id="org.eclipse.birt.doc"/>
<plugin id="org.eclipse.birt.example"/>
<plugin id="org.eclipse.birt.jetty.overlay" fragment="true"/>
<plugin id="org.eclipse.birt.me.prettyprint.hector"/>
<plugin id="org.eclipse.birt.report.data.adapter"/>
<plugin id="org.eclipse.birt.report.data.bidi.utils"/>
<plugin id="org.eclipse.birt.report.data.bidi.utils.ui"/>
<plugin id="org.eclipse.birt.report.data.oda.excel"/>
<plugin id="org.eclipse.birt.report.data.oda.excel.ui"/>
<plugin id="org.eclipse.birt.report.data.oda.hive"/>
<plugin id="org.eclipse.birt.report.data.oda.hive.ui"/>
<plugin id="org.eclipse.birt.report.data.oda.jdbc"/>
<plugin id="org.eclipse.birt.report.data.oda.jdbc.ui"/>
<plugin id="org.eclipse.birt.report.data.oda.sampledb"/>
<plugin id="org.eclipse.birt.report.data.oda.sampledb.ui"/>
<plugin id="org.eclipse.birt.report.data.oda.xml"/>
<plugin id="org.eclipse.birt.report.data.oda.xml.ui"/>
<plugin id="org.eclipse.birt.report.designer.core"/>
<plugin id="org.eclipse.birt.report.designer.samplereports"/>
<plugin id="org.eclipse.birt.report.designer.ui"/>
<plugin id="org.eclipse.birt.report.designer.ui.cubebuilder"/>
<plugin id="org.eclipse.birt.report.designer.ui.data"/>
<plugin id="org.eclipse.birt.report.designer.ui.editors"/>
<plugin id="org.eclipse.birt.report.designer.ui.editors.schematic"/>
<plugin id="org.eclipse.birt.report.designer.ui.lib"/>
<plugin id="org.eclipse.birt.report.designer.ui.lib.explorer"/>
<plugin id="org.eclipse.birt.report.designer.ui.preview.web"/>
<plugin id="org.eclipse.birt.report.designer.ui.rcp"/>
<plugin id="org.eclipse.birt.report.designer.ui.samples.rcp"/>
<plugin id="org.eclipse.birt.report.designer.ui.samplesview"/>
<plugin id="org.eclipse.birt.report.designer.ui.views"/>
<plugin id="org.eclipse.birt.report.engine"/>
<plugin id="org.eclipse.birt.report.engine.dataextraction"/>
<plugin id="org.eclipse.birt.report.engine.dataextraction.csv"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.excel"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.html"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.odp"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.ods"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.odt"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.pdf"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.postscript"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.ppt"/>
<plugin id="org.eclipse.birt.report.engine.emitter.config.wpml"/>
<plugin id="org.eclipse.birt.report.engine.emitter.html"/>
<plugin id="org.eclipse.birt.report.engine.emitter.odp"/>
<plugin id="org.eclipse.birt.report.engine.emitter.ods"/>
<plugin id="org.eclipse.birt.report.engine.emitter.odt"/>
<plugin id="org.eclipse.birt.report.engine.emitter.pdf"/>
<plugin id="org.eclipse.birt.report.engine.emitter.postscript"/>
<plugin id="org.eclipse.birt.report.engine.emitter.ppt"/>
<plugin id="org.eclipse.birt.report.engine.emitter.prototype.excel"/>
<plugin id="org.eclipse.birt.report.engine.emitter.wpml"/>
<plugin id="org.eclipse.birt.report.engine.fonts"/>
<plugin id="org.eclipse.birt.report.engine.odf"/>
<plugin id="org.eclipse.birt.report.engine.script.javascript"/>
<plugin id="org.eclipse.birt.report.item.crosstab.core"/>
<plugin id="org.eclipse.birt.report.item.crosstab.ui"/>
<plugin id="org.eclipse.birt.report.model"/>
<plugin id="org.eclipse.birt.report.model.adapter.oda"/>
<plugin id="org.eclipse.birt.report.viewer"/>
<plugin id="org.eclipse.birt.resources"/>
<plugin id="org.eclipse.compare.core"/>
<plugin id="org.eclipse.core.commands"/>
<plugin id="org.eclipse.core.contenttype"/>
<plugin id="org.eclipse.core.databinding"/>
<plugin id="org.eclipse.core.databinding.observable"/>
<plugin id="org.eclipse.core.databinding.property"/>
<plugin id="org.eclipse.core.expressions"/>
<plugin id="org.eclipse.core.filebuffers"/>
<plugin id="org.eclipse.core.filesystem"/>
<plugin id="org.eclipse.core.filesystem.win32.x86" fragment="true"/>
<plugin id="org.eclipse.core.jobs"/>
<plugin id="org.eclipse.core.resources"/>
<plugin id="org.eclipse.core.resources.win32.x86" fragment="true"/>
<plugin id="org.eclipse.core.runtime"/>
<plugin id="org.eclipse.core.runtime.compatibility"/>
<plugin id="org.eclipse.core.runtime.compatibility.registry" fragment="true"/>
<plugin id="org.eclipse.core.variables"/>
<plugin id="org.eclipse.datatools.connectivity"/>
<plugin id="org.eclipse.datatools.connectivity.oda"/>
<plugin id="org.eclipse.datatools.connectivity.oda.consumer"/>
<plugin id="org.eclipse.datatools.connectivity.oda.design"/>
<plugin id="org.eclipse.datatools.connectivity.oda.design.ui"/>
<plugin id="org.eclipse.datatools.connectivity.oda.profile"/>
<plugin id="org.eclipse.datatools.connectivity.sqm.core"/>
<plugin id="org.eclipse.datatools.connectivity.ui"/>
<plugin id="org.eclipse.datatools.enablement.oda.xml"/>
<plugin id="org.eclipse.datatools.enablement.oda.xml.ui"/>
<plugin id="org.eclipse.datatools.help"/>
<plugin id="org.eclipse.datatools.modelbase.dbdefinition"/>
<plugin id="org.eclipse.datatools.modelbase.sql"/>
<plugin id="org.eclipse.draw2d"/>
<plugin id="org.eclipse.e4.core.commands"/>
<plugin id="org.eclipse.e4.core.contexts"/>
<plugin id="org.eclipse.e4.core.di"/>
<plugin id="org.eclipse.e4.core.di.extensions"/>
<plugin id="org.eclipse.e4.core.services"/>
<plugin id="org.eclipse.e4.ui.bindings"/>
<plugin id="org.eclipse.e4.ui.css.core"/>
<plugin id="org.eclipse.e4.ui.css.swt"/>
<plugin id="org.eclipse.e4.ui.css.swt.theme"/>
<plugin id="org.eclipse.e4.ui.di"/>
<plugin id="org.eclipse.e4.ui.model.workbench"/>
<plugin id="org.eclipse.e4.ui.services"/>
<plugin id="org.eclipse.e4.ui.widgets"/>
<plugin id="org.eclipse.e4.ui.workbench"/>
<plugin id="org.eclipse.e4.ui.workbench.addons.swt"/>
<plugin id="org.eclipse.e4.ui.workbench.renderers.swt"/>
<plugin id="org.eclipse.e4.ui.workbench.swt"/>
<plugin id="org.eclipse.e4.ui.workbench3"/>
<plugin id="org.eclipse.emf.common"/>
<plugin id="org.eclipse.emf.ecore"/>
<plugin id="org.eclipse.emf.ecore.change"/>
<plugin id="org.eclipse.emf.ecore.xmi"/>
<plugin id="org.eclipse.equinox.app"/>
<plugin id="org.eclipse.equinox.common"/>
<plugin id="org.eclipse.equinox.ds"/>
<plugin id="org.eclipse.equinox.event"/>
<plugin id="org.eclipse.equinox.http.jetty"/>
<plugin id="org.eclipse.equinox.http.registry"/>
<plugin id="org.eclipse.equinox.http.servlet"/>
<plugin id="org.eclipse.equinox.jsp.jasper"/>
<plugin id="org.eclipse.equinox.jsp.jasper.registry"/>
<plugin id="org.eclipse.equinox.preferences"/>
<plugin id="org.eclipse.equinox.registry"/>
<plugin id="org.eclipse.equinox.util"/>
<plugin id="org.eclipse.gef"/>
<plugin id="org.eclipse.help"/>
<plugin id="org.eclipse.help.base"/>
<plugin id="org.eclipse.jetty.continuation"/>
<plugin id="org.eclipse.jetty.http"/>
<plugin id="org.eclipse.jetty.io"/>
<plugin id="org.eclipse.jetty.security"/>
<plugin id="org.eclipse.jetty.server"/>
<plugin id="org.eclipse.jetty.servlet"/>
<plugin id="org.eclipse.jetty.util"/>
<plugin id="org.eclipse.jface"/>
<plugin id="org.eclipse.jface.databinding"/>
<plugin id="org.eclipse.jface.text"/>
<plugin id="org.eclipse.ltk.core.refactoring"/>
<plugin id="org.eclipse.osgi"/>
<plugin id="org.eclipse.osgi.services"/>
<plugin id="org.eclipse.swt"/>
<plugin id="org.eclipse.swt.win32.win32.x86" fragment="true"/>
<plugin id="org.eclipse.text"/>
<plugin id="org.eclipse.ui"/>
<plugin id="org.eclipse.ui.cheatsheets"/>
<plugin id="org.eclipse.ui.forms"/>
<plugin id="org.eclipse.ui.navigator"/>
<plugin id="org.eclipse.ui.views"/>
<plugin id="org.eclipse.ui.workbench"/>
<plugin id="org.eclipse.ui.workbench.texteditor"/>
<plugin id="org.eclipse.update.configurator"/>
<plugin id="org.mozilla.javascript"/>
<plugin id="org.w3c.css.sac"/>
<plugin id="org.w3c.dom.smil"/>
<plugin id="org.w3c.dom.svg"/>
<plugin id="org.w3c.sac"/>
FUDForum. Page generated in 0.04334 seconds
