Home » Modeling » TMF (Xtext) » Generating operation code Xtend/Xtend
Generating operation code Xtend/Xtend [message #822419] Fri, 16 March 2012 11:44 Go to next message
Hello, how can I generated and operation from this xtext models??
Expression :
TerminalExpression ({Operation.left=current}
op='+' right=Expression)?
TerminalExpression returns Expression:
'(' Expression ')' |
{IntLiteral} value=INT
I cant access to the parts...
I try this:
def declare(Expression elem){
''' «elem.left» '''
but there isnt a left atribute...
Any idea???
Thank you very much
Re: Generating operation code Xtend/Xtend [message #822439 is a reply to message #822419] Fri, 16 March 2012 12:18 Go to previous messageGo to next message
Hi the subclass Operation has the left not Expression itself regards
Christian
Re: Generating operation code Xtend/Xtend [message #822512 is a reply to message #822419] Fri, 16 March 2012 14:41 Go to previous messageGo to next message
Ok, but how can i get the operation object to get the left, the right and the op ???
Re: Generating operation code Xtend/Xtend [message #822527 is a reply to message #822512] Fri, 16 March 2012 15:56 Go to previous messageGo to next message
i do not understand your question. the grammar you gave leads to the following metamodel (you can always have a look at the ecore/generated java classes)
interface Expression {
interface Operation extends Expression {
left: Expression
right: Expression
op: String
interface IntLiteral extends Expression {
value: int
Re: Generating operation code Xtend/Xtend [message #822582 is a reply to message #822527] Fri, 16 March 2012 20:47 Go to previous messageGo to next message
sorry, what i want is creating a function in xtend like this:
def declareExpression(Expression elem){
''' «elem.left.declareTerminalExpression» «elem.op» «elem.right.declareExpression» '''
to generate something like this:
1+2+4
but a I dont know how to get the operation object of an expression to make this. Because I need to get the left, the right and de op, fields to be able to print it.
The aim is generating this operation with ints, strings, booleans...
Like this:
(5+4)/20
(true&&false)&&true
"hello"+ "world"
Thanks for the help.
Re: Generating operation code Xtend/Xtend [message #822830 is a reply to message #822582] Sat, 17 March 2012 06:24 Go to previous messageGo to next message
what would you do in java? you would do instance of checks and typecasts
variable instanceof Operation
variable as Operation
or you leverage extends dispatch methods
def dispatch declareExpression(Operation elem){
''' «elem.left.declareExpression» «elem.op» «elem.right.declareExpression» '''
def dispatch declareExpression(TerminalExpression elem){
''' «elem.value» '''
Re: Generating operation code Xtend/Xtend [message #824252 is a reply to message #822830] Mon, 19 March 2012 08:45 Go to previous messageGo to next message
Hi, I am not able to do the second way:
This is my xtext file:
Model:
greetings+=Expression*;
Greeting:
'Hello' name=ID '!';
Expression :
And this is my xtend file:
* generated by Xtext
package org.xtext.example.mydsl.generator
import org.eclipse.emf.ecore.resource.Resource
import org.eclipse.xtext.generator.IGenerator
import org.eclipse.xtext.generator.IFileSystemAccess
import org.xtext.example.mydsl.myDsl.*
class MyDslGenerator implements IGenerator {
override void doGenerate(Resource resource, IFileSystemAccess fsa) {
fsa.generateFile(resource.className+".php", toTropoPHP(resource.contents.head as Model, resource))
def className(Resource res) {
var name = res.URI.lastSegment
return name.substring(0, name.indexOf('.'))
def toTropoPHP(Model sm, Resource resource) {
'''«FOR c : sm.greetings»«c.declareExpression»
«ENDFOR»'''
What am I doing bad???
Thanks a lot.
Re: Generating operation code Xtend/Xtend [message #824253 is a reply to message #824252] Mon, 19 March 2012 08:46 Go to previous messageGo to next message
Sorry, the orange words are the errors that I get Smile
Re: Generating operation code Xtend/Xtend [message #824266 is a reply to message #824252] Mon, 19 March 2012 09:08 Go to previous messageGo to next message
My TerminalExpression is your IntLiteral
Re: Generating operation code Xtend/Xtend [message #824312 is a reply to message #824266] Mon, 19 March 2012 10:19 Go to previous messageGo to next message
Yes, your right Smile
Do you know how to print the brackets???
Ex:
(5+2)*4
Because I am not able to know if they appears or not
Re: Generating operation code Xtend/Xtend [message #824317 is a reply to message #824312] Mon, 19 March 2012 10:25 Go to previous message
You could try to find them in the node model but IMHO you do not need
them at all. If you want to be sure print them always
Previous Topic:Exporting Xtext Project to Plugin
Next Topic:Exclude Directories from the builder
Current Time: Sat Jul 19 10:49:44 EDT 2025
Powered by FUDForum. Page generated in 0.30841 seconds
