[Buckminster headless] Workspace overlap error [message #718407] |
Wed, 24 August 2011 04:36  |
I am currently trying to automate the building and testing of an eclipse application, using Jenkins CI in collaboration with Buckminster headless.
This application is an eclipse product, contained in a feature, feature which is itself the composition of several Eclipse plugins. My application is based on Eclipse RCP Helios (release 3.6.2). All of the needed sources are in a Subversion (SVN) repository.
I am already able to build this product flawlessly with Buckminster integrated from within my Eclipse IDE: more precisely, I can build the complete p2 site for my product, from which I can create the final product for any supported platform (linux/gtk, win32, MacOSX...)
I have then installed Buckminster-headless 3.6 on a server, using the director:
./director \
-r http://download.eclipse.org/tools/buckminster/headless-3.6/ \
-d /srv/buckminster/ \
-p Buckminster \
-i org.eclipse.buckminster.cmdline.product
Then I installed the needed portions of Buckminster-headless:
./buckminster install \
org.eclipse.buckminster.core.headless.feature
org.eclipse.buckminster.pde.headless.feature
org.eclipse.buckminster.emma.headless.feature
Using a Jenkins project to extract the needed sources from SVN, I call Buckminster-headless with the following commands :
importtargetdefinition -A '${WORKSPACE}fr.openpeople.platform.product/rcp.target'
import '${WORKSPACE}fr.openpeople.platform.product/OPSWP_product.cquery'
build
junit -l 'fr.openpeople.platform.product/authtest.launch' -o '${WORKSPACE}testsresults/junit.xml' --xml '${WORKSPACE}testsresults/coverage.xml'
perform -D target.os=linux -D target.ws=* -D target.arch=* fr.openpeople.platform.product#site.p2
perform -D target.os=linux -D target.ws=gtk -D target.arch=x86 fr.openpeople.platform.product#create.product.zip
perform -D target.os=linux -D target.ws=gtk -D target.arch=x86_64 fr.openpeople.platform.product#create.product.zip
But while from within the IDE Buckminster works without problem, Buckminster-headless fails at the second step (import cquery) with the following messages:
[workspace] $ /usr/lib/jvm/java-6-sun/bin/java -Dbuckminster.output.root=/srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace/buckminster.output -Dbuckminster.temp.root=/srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace/buckminster.temp -Xmx1024m -jar /srv/buckminster/plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar -application org.eclipse.buckminster.cmdline.headless -data /srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace --loglevel info -S /srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace/commands.txt
INFO: importtargetdefinition '-A' '/srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace/fr.openpeople.platform.ophwp.remotecontrol.product/basic.target'
INFO: import '/srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace/fr.openpeople.platform.ophwp.remotecontrol.product/ophwp-remotecontrol-product.cquery'
ERROR [0001] : Invalid project description.
[0001] : OK
ERROR [0001] : /srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace/fr.openpeople.util.optxManager overlaps the location of another project: 'fr.openpeople.util.optxManager'
INFO: TAG-ID 0001 = Query for fr.openpeople.platform.ophwp.remotecontrol.product:eclipse.feature
I just can't understand what's wrong, nor what this error message really means... The Buckminster book says nothing about this, and I didn't find any entry in Bugzilla related to such a problem... I'm completely stuck. Any help would be greatly appreciated!
NB: this problem seems to be similar to the one described in message #537136 in this forum, but there was alas no answer to this topic...
[Updated on: Wed, 24 August 2011 04:37] by Moderator
Re: [Buckminster headless] [message #718430 is a reply to message #718407] |
Wed, 24 August 2011 05:57   |
You encountered a bug that has been fixed. Please try a more recent buckminster, i.e:
http://download.eclipse.org/tools/buckminster/headless-3.7/
There's no problem building a Helios 3.6.2 based product using a 3.7 based tool.
Thomas Hallgren
> /director \
> -p Buckminster \
> build
> INFO: import
> [0001] : OK
> http://www.eclipse.org/forums/index.php/mv/msg/169195/537136/#msg_537136 in this forum, but there was alas no answer to
> this topic...
Re: [Buckminster headless] [message #718492 is a reply to message #718430] |
Wed, 24 August 2011 09:57   |
Thomas Hallgren
Hello Thomas,
Thanks for your quick reply. I have erased and replaced my Buckminster-headless installation from current 'headless-3.7', as you suggested. I also completely deleted and remade from scratch my Jenkins project, just to ensure no artifact from the 3.6 execution would remain...
Alas, I still encouter this strange error... B-h output is now:
[workspace] $ /usr/lib/jvm/java-6-sun/bin/java -Dbuckminster.output.root=/srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace/buckminster.output -Dbuckminster.temp.root=/srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace/buckminster.temp -Xmx1024m -jar /srv/buckminster/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar -application org.eclipse.buckminster.cmdline.headless -data /srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace --loglevel info -S /srv/jenkins/jobs/TelecommandePFmaterielleOP/workspace/commands.txt
[0001] : OK
To be more precise, the 'cquery' file referenced in the failing operation is as follows:
<cq:componentQuery xmlns:cq="http://www.eclipse.org/buckminster/CQuery-1.0" resourceMap="ophwp-remotecontrol.rmap">
<cq:rootRequest name="fr.openpeople.platform.ophwp.remotecontrol.product" componentType="eclipse.feature"/>
</cq:componentQuery>
As you can see, it is just a mere reference to my project's only feature.
I really can't understand what's happening here... I 'm having Jenkins extract all of the concerned projects (the product's feature plus the plugins) from SVN in the workspace, then I just ask Bh to "view" them and make the according build.
Do you have an idea about the meaning of this error?
FUDForum. Page generated in 0.04744 seconds
