Home » Modeling » EMF » Listen to part of Model
Listen to part of Model [message #810722] Thu, 01 March 2012 08:28 Go to next message
I have an emf editor in my rcp client and a treeviewer that represents a part of this tree (some middle layers).
At present the tree does not recognize changes I do to the model through the emf model editor.
Is there a very nice possibility to listen to a part of this tree. It would be ugly if I had to create an observableValue for every Object/Reference/Attribute the treeviewer depends on. It would be also ugly if the treeviewer listens to all changes everywhere in the model.
Any ideas ?
Regards from germany
Re: Listen to part of Model [message #810739 is a reply to message #810722] Thu, 01 March 2012 08:49 Go to previous messageGo to next message
Markus,
Comments below.
On 01/03/2012 2:28 PM, Markus Jo wrote:
Are you using AdapterFactoryContentProvider for it?
How are you rendering the tree? The generator editor shows how to use
EMF item providers to populate a tree and it already responds to
nofifications. There's also data binding support for this, though I'm
not so familiar with that.
You can listen to any object by adding an adapter to its eAdapters().
> Any ideas ?
Re: Listen to part of Model [message #822143 is a reply to message #810739] Fri, 16 March 2012 04:13 Go to previous messageGo to next message
Hmm.....I tried a little bit....AdapterFactoryContentProvider probably will not work for me, because I dont want the model structure exactly in me Tree. I want to leave out some layers.
So I tried to make my viewer an adapter and add is as listener.......but I recognized that I have to add it to every element in the tree because changes of children do not inform its parent.
train.getRouteVariants().eAdapters().add(this);
train.getRouteVariants().getRoute().get(0).getMainRoute().getStops().getStop().get(0).eAdapters().add(this);
Is there a way to say "This is the adapter for this root list. Inform him about all changes of children and childrens children".
Re: Listen to part of Model [message #822158 is a reply to message #822143] Fri, 16 March 2012 04:31 Go to previous messageGo to next message
Markus,
An EContentAdapter is very useful. It attaches itself to the entire
containment tree. You can even attach it to a ResourceSet and listen to
everything that's happening.
Re: Listen to part of Model [message #822182 is a reply to message #822158] Fri, 16 March 2012 05:08 Go to previous message
Thanks Ed,
I used it this way (where I create the treeviewer) and it works.
Train train = (Train) input.getModel();
		EContentAdapter eContentAdapter = new EContentAdapter(){
			public void notifyChanged(Notification notification) {
				super.notifyChanged(notification);
				viewer.refresh();
		eContentAdapter.setTarget(train);
Previous Topic:[CDO] Metamodels in CDO & exceptions
Next Topic:EMF for code generation in EMF application
Current Time: Sat Jul 19 11:49:27 EDT 2025
Powered by FUDForum. Page generated in 0.25252 seconds
