[CDO/Hibernate] How to re-save changed model instance [message #820948] |
Wed, 14 March 2012 15:28  |
I am new to CDO/Hibernate and currently I follow the cdo/hibernate quickstart guide from the CDO wiki. So I have downloaded the example projects and looked at and executed the test cases. Then I made the following modification to the QuickStartTest (after the first commit, the street name is changed again and should be saved):
public void testCreatePersist() throws Exception {
// first create an address and persist it
final String addressName = "name " + System.currentTimeMillis(); //$NON-NLS-1$
CDOSession session = openSession();
CDOTransaction transaction = session.openTransaction();
// get/create a resource
final CDOResource resource = transaction.getOrCreateResource("/res1"); //$NON-NLS-1$
// clear any previous data
resource.getContents().clear();
final Company address = CompanyFactory.eINSTANCE.createCompany();
address.setCity("test"); //$NON-NLS-1$
address.setName(addressName);
address.setStreet("test"); //$NON-NLS-1$
resource.getContents().add(address);
transaction.commit();
// change the street name again
address.setStreet("street");
// read back and do some tests
final CDOSession session = openSession();
final CDOTransaction transaction = session.openTransaction();
final CDOResource resource = transaction.getResource("/res1"); //$NON-NLS-1$
assertEquals(true, resource.getContents().get(0) instanceof Company);
assertEquals(1, resource.getContents().size());
final Company address = (Company) resource.getContents().get(0);
assertEquals(addressName, address.getName());
Thus the second change of the street name is not getting persisted in the db, it is still the old "test" name in the db after the test passes. What must I do that the second change gets recognized?
Additionally, I am wondering how to handle the CDOSession lifecycle. The Testcase-methods do not close the opened session. Is the closing done automatically?
Thanks & Regards
Markus
Re: [CDO/Hibernate] How to re-save changed model instance [message #820963 is a reply to message #820948] |
Wed, 14 March 2012 15:53   |
When you open the session/transaction to change the name you also need to read the resource again from that new
transaction, or commit a transaction on the original resource which has the address object.
Yes the testcases should also close the session, that's nicer.
gr. Martin
On 03/14/2012 08:28 PM, Markus M wrote:
> Thanks & Regards
> Markus
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO/Hibernate] How to re-save changed model instance [message #821485 is a reply to message #821394] |
Thu, 15 March 2012 08:24   |
Hi Markus,
CDO is strongly based on the resource concept, the resource can be seen as a hibernate session. It fits less to a dao
pattern where you open and close a transaction for a short period of time. CDO is much stronger if you have objects in
memory longer periods of time. So assuming you are doing a rcp, a resource is linked to a visualization (a grid or edit
form for example) and lives as long as that visualization is shown to the user. So not soo much for doing short dao-like
operations.
If you are doing a non-rcp app (for example a web app) then I would consider the Texo project:
http://wiki.eclipse.org/Texo
gr. Martin
On 03/15/2012 10:51 AM, Markus M wrote:
> Hi Martin and Erdal,
> thanks for your clarifications, I get the point now. However I am still struggling how to cope with it. For example, I
> am unsure how to implement DAO / Persistencemanager-Classes like the following demo class:
> public class PersistenceManager {
> public void saveCompany(final Company company) {
> final CDOResource resource = transaction.getOrCreateResource(RESOURCE_NAME);
> resource.getContents().add(company);
> try {
> } catch (final CommitException e) {
> throw new RuntimeException(e);
> // .... other read/write methods like the above...
> // all this should move into a persistence manager base class...
> private static final String REPO_NAME = "repo1"; //$NON-NLS-1$
> private static final String RESOURCE_NAME = "res1"; //$NON-NLS-1$
> private static final String CONNECTION_ADDRESS = "localhost:2036"; //$NON-NLS-1$
> private CDOSessionConfiguration sessionConfiguration = null;
> * Opens a CDOSession, does not register an EPackage with the session. This should be done by the caller.
> private CDOSession openSession() {
> if (sessionConfiguration == null) {
> initialize();
> final CDOSession cdoSession = sessionConfiguration.openSession();
> cdoSession.getPackageRegistry().putEPackage(CompanyPackage.eINSTANCE);
> return cdoSession;
> * Initializes the connection and creates a {@link CDOSessionConfiguration} which is stored in a member of this
> * class.
> private void initialize() {
> OMPlatform.INSTANCE.setDebugging(true);
> OMPlatform.INSTANCE.addLogHandler(PrintLogHandler.CONSOLE);
> OMPlatform.INSTANCE.addTraceHandler(PrintTraceHandler.CONSOLE);
> // Prepare container
> final IManagedContainer container = ContainerUtil.createContainer();
> Net4jUtil.prepareContainer(container); // Register Net4j factories
> TCPUtil.prepareContainer(container); // Register TCP factories
> CDONet4jUtil.prepareContainer(container); // Register CDO factories
> // LifecycleUtil.activate(container);
> container.activate();
> // Create connector
> final IConnector connector = TCPUtil.getConnector(container, CONNECTION_ADDRESS);
> // Create configuration
> sessionConfiguration = CDONet4jUtil.createSessionConfiguration();
> sessionConfiguration.setConnector(connector);
> sessionConfiguration.setRepositoryName(REPO_NAME);
> So that the saveCompany-Method still works, when the same (changed) model instance is passed in a second time, I would
> have to either remember the transaction of model instance and reuse it instead of creating a new one. Or the other
> alternative would be to get another model instance from the resource (companyb), copy the values from the model instance
> that has been passed in from the caller of saveCompany(...) to companyb instance and save companyb instance with
> getContents().add(). Is there a better way to do it?
> Thanks & Regards
> Markus
The Netherlands
Re: [CDO/Hibernate] How to re-save changed model instance [message #821614 is a reply to message #821599] |
Thu, 15 March 2012 11:56  |
Hi Markus,
I don't do rcp's myself... but I know that Tom Schindl has done blog posts on this topic and on databinding, maybe you
can search for that on the net...
gr. Martin
On 03/15/2012 04:31 PM, Markus M wrote:
> Hi Martin,
> thanks for the additional info on how CDO should be used. Is there any sample project that shows, how to properly apply
> the resource concept in rcp applications?
> Regards
> Markus
The Netherlands
FUDForum. Page generated in 0.04352 seconds
