Home » Newcomers » Newcomers » [AXDT] Setting up Xtext Project Builder for external projects
[AXDT] Setting up Xtext Project Builder for external projects [message #819194] Mon, 12 March 2012 12:00
After lots of fiddling and lots of github message exchange, I've got AXDT up and running and the compiler works fine.
That's nice.
But I can't get Eclipse to work with third-party projects and my IDE.
My builder is NOT "com.adobe.flexbuilder.project.flexbuilder" (as pre-configured in the external project) but "org.eclipse.xtext.ui.shared.xtextBuilder". But now there is another problem closely related.
org.eclipse.xtext.ui.shared.xtextBuilder is presumedly contained inside org.eclipse.xtext.ui.shared_2_2.1.v201112130541.jar, so it should be an INTERNAL builder. Within properties of my project, I can only configure EXTERNAL builders.
Setting the .jar directly as location did not work at all (cannot execute binary file).
Editing the .project file manually with these lines
		<buildCommand>
			<name>org.eclipse.xtext.ui.shared.xtextBuilder</name>
			<arguments>
			</arguments>
		</buildCommand>
worked perfectly, but only once. because at some point, Eclipse had overwritten the .project file and deleted everything between <buildCommand>...</buildCommand>, so I will have to set it up the correct way so that it remain permanent even after restarting Eclipse.
How can I do that?
[Updated on: Mon, 12 March 2012 12:01] by Moderator
Previous Topic:Multi-user install on Linux with shared configuration ignoring user plug-ins
Next Topic:How to define a task which concerns several and various sources, tasks and text (wiki)
Current Time: Sat Jul 19 19:03:55 EDT 2025
Powered by FUDForum. Page generated in 0.07972 seconds
