Home » Modeling » EMF » [EMF] [Teneo] [Hibernate] Reference on NON Primary Key
[EMF] [Teneo] [Hibernate] Reference on NON Primary Key [message #815899] Thu, 08 March 2012 02:12 Go to next message
Hallo,
i have 2 EClasses:
Class Person
- ID = PrimaryKey
- Name
- otherUniqueID
Class Adress
- ID = PrimaryKey
- person = Refrence to Person.otherUniqueID
- street
- city
I use a Ecore-Model with Teneo and Hibernate. The problem is, that i dont know the annotation for the person-reference in class "Adress". Does anybody know, how to do that??
Many thanks
Nils
Re: [EMF] [Teneo] [Hibernate] Reference on NON Primary Key [message #816059 is a reply to message #815899] Thu, 08 March 2012 06:25 Go to previous messageGo to next message
Hi Nils,
Can you try this one:
@JoinColumn(referencedColumnName="otherUniqueID")
in the Address.person ereference
the referencedColumnName can be the efeature name on the other side.
gr. Martin
On 03/08/2012 08:12 AM, Nils Koerner wrote:
> Hallo,
> i have 2 EClasses:
> Class Person
> - ID = PrimaryKey
> - Name
> - otherUniqueID
> Class Adress
> - ID = PrimaryKey
> - street
> - city
> Many thanks
> Nils
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [EMF] [Teneo] [Hibernate] Reference on NON Primary Key [message #818936 is a reply to message #815899] Mon, 12 March 2012 05:48 Go to previous messageGo to next message
Hi Martin,
thank you very much for your quick reply. I have defined an annotation on the specified reference (Address.person):
@JoinColumn(name = "key", referencedColumnName="otherUniqueID")
Unfortunately it doesnt work. The first parameter (name = "key") is beeing executed but the second parameter (referencedColumnName="otherUniqueID") is beeing ignored without any error message. Adress.person is still referenced with Person.id. Any idea?
Thank you Smile
Nils
Re: [EMF] [Teneo] [Hibernate] Reference on NON Primary Key [message #818991 is a reply to message #818936] Mon, 12 March 2012 06:56 Go to previous messageGo to next message
Hi Nils,
Did you regenerate the java code? This is needed when adding annotations to the model, as EMF generates java code which
builds the model at runtime.
gr. Martin
On 03/12/2012 10:48 AM, Nils Koerner wrote:
> Hi Martin,
> Thank you :)
> Nils
The Netherlands
Re: [EMF] [Teneo] [Hibernate] Reference on NON Primary Key [message #819001 is a reply to message #818991] Mon, 12 March 2012 07:10 Go to previous messageGo to next message
Hi Martin,
yes, i regenerated the model. It seems that teneo ignores the 2nd part of the annotation.
Greetings
Nils
Re: [EMF] [Teneo] [Hibernate] Reference on NON Primary Key [message #819025 is a reply to message #819001] Mon, 12 March 2012 07:51 Go to previous messageGo to next message
Can you try putting it in an enclosing JoinColumns annotation:
@JoinColumns({@JoinColumn(name = "key", referencedColumnName="otherUniqueID")})
This format I have in several testcases.
gr. Martin
On 03/12/2012 12:10 PM, Nils Koerner wrote:
> Hi Martin,
> Greetings
> Nils
The Netherlands
Re: [EMF] [Teneo] [Hibernate] Reference on NON Primary Key [message #819040 is a reply to message #819025] Mon, 12 March 2012 08:15 Go to previous messageGo to next message
The database-field with the specified name (for example "key111") is created, but the reference is still on the primary key.
greetings,
Nils
Re: [EMF] [Teneo] [Hibernate] Reference on NON Primary Key [message #819120 is a reply to message #819040] Mon, 12 March 2012 10:18 Go to previous message
Okay, how does the generated hbm look like (you can check it through dataStore.getMappingXML()).
gr. Martin
> key.
> greetings,
> Nils
The Netherlands
Previous Topic:Type arguments lost when generating code
Next Topic:EMF Storage
Current Time: Sun Jul 20 15:16:21 EDT 2025
Powered by FUDForum. Page generated in 0.03864 seconds
