Home » Eclipse Projects » Rich Client Platform (RCP) » Modal dialogs randomly not working on OS X 10.7.3
Modal dialogs randomly not working on OS X 10.7.3 [message #818948] |
Mon, 12 March 2012 06:04  |
I've recently upgraded a Mac workstation from OS X 10.6 to OS X 10.7.3 and the Eclipse platform from 3.7.0 to 3.7.2
I've cleaned & rebuilt my RCP project and now there's something weird happening. Some of the modal dialogs (FileDialog and DirectoryDialog) just don't block when calling open(). They don't show up and just move on to the next line of code dumping this error on the console:
2012-03-12 10:53:01.273 java[75042:407] An instance 0x7f9d26c070f0 of class SWTFileOpenPanel was deallocated while key value observers were still registered with it. Observation info was leaked, and may even become mistakenly attached to some other object. Set a breakpoint on NSKVODeallocateBreak to stop here in the debugger. Here's the current observation info:
<NSKeyValueObservationInfo 0x7f9d239b2320> (
<NSKeyValueObservance 0x7f9d26cf1b30: Observer: 0x7f9d26ce23d0, Key path: firstResponder, Options: <New: NO, Old: NO, Prior: NO> Context: 0x0, Property: 0x7f9d26cf1940>
Invalid memory access of location 0x0 rip=0x7fff8e426e90
Has anyone ever had a similar problem?
I'm also posting a crash log as sometimes it also crashes:
Process: java [90188]
Path: /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/java
Identifier: java
Version: 1.0 (1.0)
Code Type: X86-64 (Native)
Parent Process: eclipse [88800]
PlugIn Path: /Users/USER/Documents/*/libswt-pi-cocoa-3740.jnilib
PlugIn Identifier: libswt-pi-cocoa-3740.jnilib
PlugIn Version: ??? (???)
Date/Time: 2012-03-12 11:14:40.630 +0100
OS Version: Mac OS X 10.7.3 (11D50)
Report Version: 9
Interval Since Last Report: 8527 sec
Crashes Since Last Report: 7
Per-App Crashes Since Last Report: 6
Anonymous UUID: D99547BF-F773-473B-A506-5B499A345913
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: 0x000000000000000d, 0x0000000000000000
VM Regions Near 0:
__TEXT 00000001088dc000-00000001088e4000 [ 32K] r-x/rwx SM=COW /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/java
Application Specific Information:
objc_msgSend() selector name: isVisible
objc[90188]: garbage collection is OFF
Java information:
Exception type: Bus Error (0xa) at pc=7fff8e426e90
Java VM: Java HotSpot(TM) 64-Bit Server VM (20.4-b02-402 mixed mode macosx-amd64)
Current thread (7f98c5004800): JavaThread "Thread-1" daemon [_thread_in_native, id=2079029600, stack(7fff67cdc000,7fff684dc000)]
Stack: [7fff67cdc000,7fff684dc000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Lorg/eclipse/swt/internal/cocoa/objc_super;JJ)J+0
j org.eclipse.swt.widgets.Display.applicationSendEvent(JJJ)V+383
j org.eclipse.swt.widgets.Display.applicationProc(JJJ)J+107
v ~StubRoutines::call_stub
J org.eclipse.swt.internal.cocoa.OS.objc_msgSend(JJJ)J
j org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(Lorg/eclipse/swt/internal/cocoa/NSEvent;)V+19
j org.eclipse.swt.widgets.Display.readAndDispatch()Z+113
j org.eclipse.ui.internal.Workbench.runEventLoop(Lorg/eclipse/jface/window/Window$IExceptionHandler;Lorg/eclipse/swt/widgets/Display;)V+9
j org.eclipse.ui.internal.Workbench.runUI()I+555
j org.eclipse.ui.internal.Workbench.access$4(Lorg/eclipse/ui/internal/Workbench;)I+1
j org.eclipse.ui.internal.Workbench$7.run()V+73
j org.eclipse.core.databinding.observable.Realm.runWithDefault(Lorg/eclipse/core/databinding/observable/Realm;Ljava/lang/Runnable;)V+12
j org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+18
j org.eclipse.ui.PlatformUI.createAndRunWorkbench(Lorg/eclipse/swt/widgets/Display;Lorg/eclipse/ui/application/WorkbenchAdvisor;)I+2
j it.itablo.designer.Application.start(Lorg/eclipse/equinox/app/IApplicationContext;)Ljava/lang/Object;+12
j org.eclipse.equinox.internal.app.EclipseAppHandle.run(Ljava/lang/Object;)Ljava/lang/Object;+135
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(Ljava/lang/Object;)Ljava/lang/Object;+103
j org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(Ljava/lang/Object;)Ljava/lang/Object;+29
j org.eclipse.core.runtime.adaptor.EclipseStarter.run(Ljava/lang/Object;)Ljava/lang/Object;+149
j org.eclipse.core.runtime.adaptor.EclipseStarter.run([Ljava/lang/String;Ljava/lang/Runnable;)Ljava/lang/Object;+183
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j org.eclipse.equinox.launcher.Main.invokeFramework([Ljava/lang/String;[Ljava/net/URL;)V+211
j org.eclipse.equinox.launcher.Main.basicRun([Ljava/lang/String;)V+126
j org.eclipse.equinox.launcher.Main.run([Ljava/lang/String;)I+4
j org.eclipse.equinox.launcher.Main.main([Ljava/lang/String;)V+10
Java Threads: ( => current thread )
7f98c91c2800 JavaThread "Worker-2" [_thread_blocked, id=367632384, stack(115d9a000,115e9a000)]
7f98c5adf800 JavaThread "Worker-1" [_thread_blocked, id=360755200, stack(11570b000,11580b000)]
7f98c7aad000 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=402771968, stack(117f1d000,11801d000)]
7f98c5d04800 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=369762304, stack(115fa2000,1160a2000)]
7f98c52dc800 JavaThread "AWT-Shutdown" [_thread_blocked, id=336273408, stack(113fb2000,1140b2000)]
7f98c7aac800 JavaThread "Worker-0" [_thread_blocked, id=368701440, stack(115e9f000,115f9f000)]
7f98c5aa0000 JavaThread "Worker-JM" [_thread_blocked, id=333680640, stack(113d39000,113e39000)]
7f98c504d000 JavaThread "[Timer] - Main Queue Handler" daemon [_thread_blocked, id=332619776, stack(113c36000,113d36000)]
7f98c5acb800 JavaThread "Start Level Event Dispatcher" daemon [_thread_blocked, id=329678848, stack(113968000,113a68000)]
7f98c792d800 JavaThread "Framework Event Dispatcher" daemon [_thread_blocked, id=328617984, stack(113865000,113965000)]
7f98c792d000 JavaThread "State Saver" daemon [_thread_blocked, id=327557120, stack(113762000,113862000)]
7f98c792c000 JavaThread "Framework Active Thread" [_thread_blocked, id=326496256, stack(11365f000,11375f000)]
7f98c505a000 JavaThread "Poller SunPKCS11-Darwin" daemon [_thread_blocked, id=303300608, stack(112040000,112140000)]
=>7f98c5004800 JavaThread "Thread-1" daemon [_thread_in_native, id=2079029600, stack(7fff67cdc000,7fff684dc000)]
7f98c6813000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=298852352, stack(111c02000,111d02000)]
7f98c5003800 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=297791488, stack(111aff000,111bff000)]
7f98c5003000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=296730624, stack(1119fc000,111afc000)]
7f98c5002000 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=295669760, stack(1118f9000,1119f9000)]
7f98c5001800 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=294608896, stack(1117f6000,1118f6000)]
7f98c5000800 JavaThread "Finalizer" daemon [_thread_blocked, id=291708928, stack(111532000,111632000)]
7f98c7806800 JavaThread "Reference Handler" daemon [_thread_blocked, id=290648064, stack(11142f000,11152f000)]
7f98c5800800 JavaThread "main" [_thread_in_native, id=152768512, stack(1090b1000,1091b1000)]
Other Threads:
7f98c6812000 VMThread [stack: 11132c000,11142c000] [id=289587200]
7f98c681c800 WatcherThread [stack: 111d05000,111e05000] [id=299913216]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
par new generation total 76672K, used 43811K [7b0000000, 7b5330000, 7b5330000)
eden space 68160K, 59% used [7b0000000, 7b27e1910, 7b4290000)
from space 8512K, 34% used [7b4ae0000, 7b4dc75b0, 7b5330000)
to space 8512K, 0% used [7b4290000, 7b4290000, 7b4ae0000)
concurrent mark-sweep generation total 963392K, used 113669K [7b5330000, 7f0000000, 7f0000000)
concurrent-mark-sweep perm gen total 45248K, used 45135K [7f0000000, 7f2c30000, 800000000)
Code Cache [109329000, 10959a000, 10c329000)
total_blobs=1076 nmethods=377 adapters=661 free_code_cache=48369280 largest_free_block=20992
Virtual Machine Arguments:
JVM Args: -Dosgi.requiredJavaVersion=1.5 -Dorg.eclipse.swt.internal.carbon.smallFonts -Dorg.eclipse.swt.internal.carbon.smallFonts -Dosgi.requiredJavaVersion=1.5 -Xms40m -Xmx384m -Dorg.eclipse.swt.internal.carbon.smallFonts -XX:MaxPermSize=256m -Xms1g -Xmx1g -Dorg.jpedal.jai=true -Dfile.encoding=MacRoman -Xbootclasspath/p:/Applications/eclipse/plugins/org.eclipse.jdt.debug_3.7.1.v20111006_r372/jdi.jar
Java Command: org.eclipse.equinox.launcher.Main -launcher /Applications/eclipse/Eclipse.app/Contents/MacOS/eclipse -name Eclipse -showsplash 600 -product it.itablo.designer.product -data /Users/tanis/Documents/workspace/../runtime-it.itablo.designer.product -configuration file:/Users/tanis/Documents/workspace/.metadata/.plugins/org.eclipse.pde.core/it.itablo.designer.product/ -dev file:/Users/tanis/Documents/workspace/.metadata/.plugins/org.eclipse.pde.core/it.itablo.designer.product/dev.properties -os macosx -ws cocoa -arch x86_64 -nl it_IT -consoleLog
Launcher Type: SUN_STANDARD
Physical Memory: Page Size = 4k, Total = 8192M, Free = 1640M
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x00007fff8e426e90 objc_msgSend + 16
1 com.apple.AppKit 0x00007fff90181956 -[NSViewDynamicToolTipManager _appActivationChanged:] + 59
2 com.apple.Foundation 0x00007fff8e6b3d32 __-[NSNotificationCenter addObserver:selector:name:object:]_block_invoke_1 + 47
3 com.apple.CoreFoundation 0x00007fff955caaaa _CFXNotificationPost + 2634
4 com.apple.Foundation 0x00007fff8e69ffe7 -[NSNotificationCenter postNotificationName:object:userInfo:] + 65
5 com.apple.AppKit 0x00007fff9016f757 -[NSApplication sendEvent:] + 3011
6 libswt-pi-cocoa-3740.jnilib 0x00000001142f0c0f Java_org_eclipse_swt_internal_cocoa_OS_objc_1msgSendSuper__Lorg_eclipse_swt_internal_cocoa_objc_1super_2JJ + 97
7 ??? 0x0000000109339d6e 0 + 4449344878
8 ??? 0x000000010932e929 0 + 4449298729
9 ??? 0x000000010932e85a 0 + 4449298522
10 ??? 0x0000000109329438 0 + 4449276984
11 libclient64.dylib 0x0000000108a2177a 0x108976000 + 702330
12 libclient64.dylib 0x0000000108a2153e 0x108976000 + 701758
13 libclient64.dylib 0x0000000108a44b75 0x108976000 + 846709
14 libclient64.dylib 0x0000000108ce98c3 0x108976000 + 3619011
15 libswt-cocoa-3740.jnilib 0x0000000114238f92 callback + 1344
16 libswt-cocoa-3740.jnilib 0x0000000114218717 fn1_3 + 47
17 libswt-pi-cocoa-3740.jnilib 0x00000001142ec448 Java_org_eclipse_swt_internal_cocoa_OS_objc_1msgSend__JJJ + 54
18 ??? 0x000000010942001d 0 + 4450287645
19 ??? 0x000000010932e929 0 + 4449298729
20 ??? 0x000000010932e85a 0 + 4449298522
21 ??? 0x000000010932ea82 0 + 4449299074
22 ??? 0x000000010932e85a 0 + 4449298522
23 ??? 0x000000010932e96e 0 + 4449298798
24 ??? 0x000000010932e96e 0 + 4449298798
25 ??? 0x000000010932ed34 0 + 4449299764
26 ??? 0x000000010932e85a 0 + 4449298522
27 ??? 0x000000010932e96e 0 + 4449298798
28 ??? 0x000000010932e96e 0 + 4449298798
29 ??? 0x000000010932ee8d 0 + 4449300109
30 ??? 0x000000010932ee8d 0 + 4449300109
31 ??? 0x000000010932e9b3 0 + 4449298867
32 ??? 0x000000010932e9b3 0 + 4449298867
33 ??? 0x000000010932e9b3 0 + 4449298867
34 ??? 0x0000000109329438 0 + 4449276984
35 libclient64.dylib 0x0000000108a2177a 0x108976000 + 702330
36 libclient64.dylib 0x0000000108a2153e 0x108976000 + 701758
37 libclient64.dylib 0x0000000108a39308 0x108976000 + 799496
38 libclient64.dylib 0x0000000108a3a496 0x108976000 + 803990
39 libclient64.dylib 0x0000000108a3a25c JVM_InvokeMethod + 352
40 libjvmlinkage.dylib 0x0000000109078d7e JVM_InvokeMethod + 78
41 ??? 0x0000000109339d6e 0 + 4449344878
42 ??? 0x000000010932e9b3 0 + 4449298867
43 ??? 0x000000010932e9b3 0 + 4449298867
44 ??? 0x000000010932ee8d 0 + 4449300109
45 ??? 0x000000010932e9b3 0 + 4449298867
46 ??? 0x000000010932e85a 0 + 4449298522
47 ??? 0x000000010932e85a 0 + 4449298522
48 ??? 0x000000010932e96e 0 + 4449298798
49 ??? 0x0000000109329438 0 + 4449276984
50 libclient64.dylib 0x0000000108a2177a 0x108976000 + 702330
51 libclient64.dylib 0x0000000108a2153e 0x108976000 + 701758
52 libclient64.dylib 0x0000000108a44b75 0x108976000 + 846709
53 libclient64.dylib 0x0000000108a44a1d 0x108976000 + 846365
54 java 0x00000001088decf3 0x1088dc000 + 11507
55 java 0x00000001088e116d 0x1088dc000 + 20845
56 com.apple.CoreFoundation 0x00007fff9564be0d +[NSObject performSelector:withObject:] + 61
57 com.apple.Foundation 0x00007fff8e6ecd94 __NSThreadPerformPerform + 214
58 com.apple.CoreFoundation 0x00007fff955906e1 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
59 com.apple.CoreFoundation 0x00007fff9558ff4d __CFRunLoopDoSources0 + 253
60 com.apple.CoreFoundation 0x00007fff955b6d39 __CFRunLoopRun + 905
61 com.apple.CoreFoundation 0x00007fff955b6676 CFRunLoopRunSpecific + 230
62 java 0x00000001088e0843 0x1088dc000 + 18499
63 java 0x00000001088e029a 0x1088dc000 + 17050
64 java 0x00000001088dda98 0x1088dc000 + 6808
Thread 1:
0 libsystem_kernel.dylib 0x00007fff91693bca __psynch_cvwait + 10
1 libsystem_c.dylib 0x00007fff95220274 _pthread_cond_wait + 840
2 com.apple.Foundation 0x00007fff8e6f94e4 -[NSCondition wait] + 261
3 com.apple.Foundation 0x00007fff8e6ec878 -[NSObject(NSThreadPerformAdditions) performSelector:onThread:withObject:waitUntilDone:modes:] + 975
4 com.apple.Foundation 0x00007fff8e6ec42b -[NSObject(NSThreadPerformAdditions) performSelectorOnMainThread:withObject:waitUntilDone:] + 135
5 java 0x00000001088e10a7 0x1088dc000 + 20647
6 java 0x00000001088df240 0x1088dc000 + 12864
7 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
8 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 2:: Java: Exception Handler Thread
0 libsystem_kernel.dylib 0x00007fff9169267a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff91691d71 mach_msg + 73
2 libsystem_kernel.dylib 0x00007fff9169231c mach_msg_server + 641
3 libclient64.dylib 0x000000010898ade9 0x108976000 + 85481
4 libclient64.dylib 0x000000010898aca3 0x108976000 + 85155
5 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
6 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
7 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 3:: Java: Gang worker#0 (Parallel GC Threads)
2 libclient64.dylib 0x0000000108989f23 0x108976000 + 81699
3 libclient64.dylib 0x0000000108989de3 0x108976000 + 81379
4 libclient64.dylib 0x0000000108989d42 0x108976000 + 81218
5 libclient64.dylib 0x000000010898991d 0x108976000 + 80157
6 libclient64.dylib 0x00000001089897c3 0x108976000 + 79811
7 libclient64.dylib 0x00000001089a25c8 0x108976000 + 181704
8 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
9 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
10 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 4:: Java: Gang worker#1 (Parallel GC Threads)
Thread 5:: Java: Gang worker#2 (Parallel GC Threads)
Thread 6:: Java: Gang worker#3 (Parallel GC Threads)
Thread 7:: Java: Concurrent Mark-Sweep GC Thread
2 libclient64.dylib 0x0000000108989fb5 0x108976000 + 81845
3 libclient64.dylib 0x00000001089a8b6e 0x108976000 + 207726
4 libclient64.dylib 0x000000010898991d 0x108976000 + 80157
5 libclient64.dylib 0x00000001089897c3 0x108976000 + 79811
6 libclient64.dylib 0x0000000108a7e8e5 0x108976000 + 1083621
7 libclient64.dylib 0x0000000108a7e7cf 0x108976000 + 1083343
8 libclient64.dylib 0x00000001089a89e9 0x108976000 + 207337
9 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
10 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
11 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 8:: Java: VM Thread
6 libclient64.dylib 0x0000000108a205b7 0x108976000 + 697783
7 libclient64.dylib 0x0000000108a20307 0x108976000 + 697095
Thread 9:: Java: Reference Handler
4 libclient64.dylib 0x0000000108a2ebc3 0x108976000 + 756675
5 libclient64.dylib 0x0000000108a2e050 0x108976000 + 753744
6 libclient64.dylib 0x0000000108a2dcbc JVM_MonitorWait + 154
7 libjvmlinkage.dylib 0x0000000109074b0b JVM_MonitorWait + 59
8 ??? 0x0000000109339d6e 0 + 4449344878
10 ??? 0x000000010932e85a 0 + 4449298522
11 ??? 0x0000000109329438 0 + 4449276984
12 libclient64.dylib 0x0000000108a2177a 0x108976000 + 702330
13 libclient64.dylib 0x0000000108a2d808 0x108976000 + 751624
14 libclient64.dylib 0x0000000108a2d6fe 0x108976000 + 751358
15 libclient64.dylib 0x0000000108a2d69e 0x108976000 + 751262
16 libclient64.dylib 0x0000000108a2d540 0x108976000 + 750912
17 libclient64.dylib 0x0000000108a2d355 0x108976000 + 750421
18 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
19 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
20 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 10:: Java: Finalizer
10 ??? 0x000000010932e9b3 0 + 4449298867
11 ??? 0x000000010932e9b3 0 + 4449298867
12 ??? 0x0000000109329438 0 + 4449276984
13 libclient64.dylib 0x0000000108a2177a 0x108976000 + 702330
14 libclient64.dylib 0x0000000108a2d808 0x108976000 + 751624
15 libclient64.dylib 0x0000000108a2d6fe 0x108976000 + 751358
16 libclient64.dylib 0x0000000108a2d69e 0x108976000 + 751262
17 libclient64.dylib 0x0000000108a2d540 0x108976000 + 750912
18 libclient64.dylib 0x0000000108a2d355 0x108976000 + 750421
19 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
20 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
21 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 11:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff916947e6 kevent + 10
1 libdispatch.dylib 0x00007fff964f85be _dispatch_mgr_invoke + 923
2 libdispatch.dylib 0x00007fff964f714e _dispatch_mgr_thread + 54
Thread 12:
0 libsystem_kernel.dylib 0x00007fff91694192 __workq_kernreturn + 10
1 libsystem_c.dylib 0x00007fff9521e594 _pthread_wqthread + 758
2 libsystem_c.dylib 0x00007fff9521fb85 start_wqthread + 13
Thread 13:
Thread 14:: Java: Surrogate Locker Thread (Concurrent GC)
6 libclient64.dylib 0x000000010898972a 0x108976000 + 79658
7 libclient64.dylib 0x0000000108a3dfcd 0x108976000 + 819149
8 libclient64.dylib 0x0000000108a2d540 0x108976000 + 750912
9 libclient64.dylib 0x0000000108a2d355 0x108976000 + 750421
10 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
11 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
12 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 15:: Java: Signal Dispatcher
0 libsystem_kernel.dylib 0x00007fff916926b6 semaphore_wait_trap + 10
1 libclient64.dylib 0x0000000108a3e80f 0x108976000 + 821263
2 libclient64.dylib 0x0000000108a3e296 0x108976000 + 819862
3 libclient64.dylib 0x0000000108a2d540 0x108976000 + 750912
4 libclient64.dylib 0x0000000108a2d355 0x108976000 + 750421
Thread 16:: Java: C2 CompilerThread0
7 libclient64.dylib 0x0000000108a4507d 0x108976000 + 847997
8 libclient64.dylib 0x0000000108a3f67f 0x108976000 + 824959
9 libclient64.dylib 0x0000000108a2d540 0x108976000 + 750912
10 libclient64.dylib 0x0000000108a2d355 0x108976000 + 750421
11 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
12 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
13 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 17:: Java: C2 CompilerThread1
Thread 18:: Java: Low Memory Detector
7 libclient64.dylib 0x0000000108a41080 0x108976000 + 831616
Thread 19:: Java: VM Periodic Task Thread
4 libclient64.dylib 0x0000000108a431b2 0x108976000 + 840114
Thread 20:: Java: Poller SunPKCS11-Darwin
3 libclient64.dylib 0x0000000108b2b8d8 0x108976000 + 1792216
4 libclient64.dylib 0x0000000108b3a466 JVM_Sleep + 191
5 libjvmlinkage.dylib 0x000000010907565e JVM_Sleep + 62
6 ??? 0x0000000109339d6e 0 + 4449344878
8 ??? 0x000000010932ed34 0 + 4449299764
10 libclient64.dylib 0x0000000108a2177a 0x108976000 + 702330
11 libclient64.dylib 0x0000000108a2d808 0x108976000 + 751624
12 libclient64.dylib 0x0000000108a2d6fe 0x108976000 + 751358
13 libclient64.dylib 0x0000000108a2d69e 0x108976000 + 751262
14 libclient64.dylib 0x0000000108a2d540 0x108976000 + 750912
15 libclient64.dylib 0x0000000108a2d355 0x108976000 + 750421
16 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
17 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
18 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 21:: Java: Framework Active Thread
4 libclient64.dylib 0x0000000108a2ebcd 0x108976000 + 756685
10 ??? 0x000000010932ed34 0 + 4449299764
Thread 22:: Java: State Saver
Thread 23:: Java: Framework Event Dispatcher
Thread 24:: Java: Start Level Event Dispatcher
Thread 25:: Java: [Timer] - Main Queue Handler
Thread 26:: Java: Worker-JM
12 libclient64.dylib 0x0000000108a2d808 0x108976000 + 751624
13 libclient64.dylib 0x0000000108a2d6fe 0x108976000 + 751358
14 libclient64.dylib 0x0000000108a2d69e 0x108976000 + 751262
15 libclient64.dylib 0x0000000108a2d540 0x108976000 + 750912
16 libclient64.dylib 0x0000000108a2d355 0x108976000 + 750421
17 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
18 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
19 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 27:: Java: Worker-0
Thread 28:: Java: AWT-Shutdown
11 ??? 0x000000010932ed34 0 + 4449299764
Thread 29:: Java: Java2D Disposer
12 ??? 0x000000010932ed34 0 + 4449299764
13 ??? 0x0000000109329438 0 + 4449276984
14 libclient64.dylib 0x0000000108a2177a 0x108976000 + 702330
15 libclient64.dylib 0x0000000108a2d808 0x108976000 + 751624
16 libclient64.dylib 0x0000000108a2d6fe 0x108976000 + 751358
17 libclient64.dylib 0x0000000108a2d69e 0x108976000 + 751262
18 libclient64.dylib 0x0000000108a2d540 0x108976000 + 750912
19 libclient64.dylib 0x0000000108a2d355 0x108976000 + 750421
20 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
21 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
22 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 30:: Java: AWT-EventQueue-0
12 ??? 0x000000010932ea82 0 + 4449299074
13 ??? 0x000000010932e85a 0 + 4449298522
14 ??? 0x000000010932e85a 0 + 4449298522
15 ??? 0x000000010932e85a 0 + 4449298522
16 ??? 0x000000010932e85a 0 + 4449298522
17 ??? 0x0000000109329438 0 + 4449276984
18 libclient64.dylib 0x0000000108a2177a 0x108976000 + 702330
19 libclient64.dylib 0x0000000108a2d808 0x108976000 + 751624
20 libclient64.dylib 0x0000000108a2d6fe 0x108976000 + 751358
21 libclient64.dylib 0x0000000108a2d69e 0x108976000 + 751262
22 libclient64.dylib 0x0000000108a2d540 0x108976000 + 750912
23 libclient64.dylib 0x0000000108a2d355 0x108976000 + 750421
24 libclient64.dylib 0x0000000108989884 0x108976000 + 80004
25 libsystem_c.dylib 0x00007fff9521c8bf _pthread_start + 335
26 libsystem_c.dylib 0x00007fff9521fb75 thread_start + 13
Thread 31:
Thread 32:: Java: Worker-1
Thread 33:: Java: Worker-2
Thread 34:
Thread 35:
Thread 36:
Thread 37:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff91693df2 __select + 10
1 com.apple.CoreFoundation 0x00007fff955ffcdb __CFSocketManager + 1355
Thread 38:
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00007f98c48babc0 rbx: 0x00007f98c8d01fd0 rcx: 0x00000000000f4f57 rdx: 0x00007f98c4888300
rdi: 0x00007f98c48babc0 rsi: 0x00007fff909e0290 rbp: 0x00007fff684d7800 rsp: 0x00007fff684d77e0
r8: 0x00007f98c4801c00 r9: 0x00007f98c48362f0 r10: 0x0000000113c0b860 r11: 0x500007f98c48b4b0
r12: 0x00007f98c7237200 r13: 0x0000000000000000 r14: 0x00007fff90a56633 r15: 0x00000000000001b3
rip: 0x00007fff8e426e90 rfl: 0x0000000000010246 cr2: 0x00000001155ab01c
Logical CPU: 2
Binary Images:
0x1088dc000 - 0x1088e3fff java (1.0 - 1.0) <4AC9C9AB-E0C3-3116-ADBE-2A99D1505D7B> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bin/java
0x1088ef000 - 0x1088f5fff libjli.jnilib (??? - ???) <2927BE65-1D10-3C92-B5B1-B5E070A84C31> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjli.jnilib
0x1088ff000 - 0x108904fff com.apple.JavaVM (14.1.0 - 14.1.0) <83C8C2AB-E99D-39FF-80B4-90A7DEB1DAFB> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x10890e000 - 0x108913fff JavaLaunching (??? - ???) <94CDB5A6-7C7A-3FAC-BC48-152A1FB96508> /System/Library/PrivateFrameworks/JavaLaunching.framework/Versions/A/JavaLaunching
0x108976000 - 0x108fa4ff7 libclient64.dylib (??? - ???) <D3325E4E-CACF-39AE-8668-8F8E5A8F5B2D> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Home/bundle/Libraries/libclient64.dylib
0x109074000 - 0x10907bfff libjvmlinkage.dylib (??? - ???) <4E1B7F6A-050F-3F83-B333-4C0B5456022B> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjvmlinkage.dylib
0x1091b3000 - 0x1091bbff7 libverify.dylib (1.0 - 1.0) <BEE0B2CE-E7BA-3830-BD53-D1AC2E127C38> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libverify.dylib
0x1091c1000 - 0x1091cbfff JavaNativeFoundation (??? - ???) <3D79FBBE-054D-3209-A8D0-BF5D3D733A91> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x1091d6000 - 0x1091f6ff7 libjava.jnilib (??? - ???) <F16EC2DC-1801-3D12-BB50-2D88A62FC0BA> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjava.jnilib
0x109315000 - 0x109322ff7 libzip.jnilib (??? - ???) <457C25EB-8F18-35CF-878C-82B4D6369300> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libzip.jnilib
0x111e07000 - 0x111e11fff com.apple.JavaApplicationLauncher (14.1.0 - 14.1.0) <22591A47-7E67-3F2C-AAEE-5A63558CA28B> /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher
0x111e97000 - 0x111e9dfef libcldcpuengine.dylib (1.50.69 - compatibility 1.0.0) <C0C4CC37-F2FD-301C-A830-EC54D86612D5> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
0x111ea4000 - 0x111ea7ff7 libCoreFSCache.dylib (??? - ???) <0E2C3D54-7D05-35E8-BA10-2142B7C03946> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x111ebf000 - 0x111ebfff5 +cl_kernels (??? - ???) <4B0A7A66-01A2-492D-9404-64EE44215965> cl_kernels
0x111ecb000 - 0x111ecbffd +cl_kernels (??? - ???) <94BBBFA1-DB3F-4C6D-8562-4F6E3330DCB7> cl_kernels
0x111efa000 - 0x111f02ff7 com.apple.java.JavaRuntimeSupport (14.1.0 - 14.1.0) <B1138A29-DFA3-3496-BA5A-4FDD61C729C5> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
0x111f26000 - 0x111f26fff libcmm.jnilib (??? - ???) <1DF114DE-4BCC-3C7D-A60C-3E5C69612797> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libcmm.jnilib
0x111fbd000 - 0x111fbeffc +cl_kernels (??? - ???) <B071D260-2C4D-45B8-91DD-015BBBF5ADF0> cl_kernels
0x111fe8000 - 0x111ff5fff libj2pkcs11.jnilib (??? - ???) <69689BAB-9455-3758-80A7-26BB4088EBF9> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libj2pkcs11.jnilib
0x111ffb000 - 0x112020fff tokendPKCS11.so (??? - ???) <DC0BBE2F-3BE4-320F-A0EC-C317555286E7> /usr/libexec/SmartCardServices/pkcs11/tokendPKCS11.so
0x112142000 - 0x11214bfff +eclipse_1408.so (??? - ???) <F25E6D65-914A-1B6D-E6EF-B33E70C9FC9A> /Applications/eclipse/*/eclipse_1408.so
0x11324c000 - 0x11324dff3 +cl_kernels (??? - ???) <DF0A493D-0D71-4268-9654-89DE8B0A06E9> cl_kernels
0x113250000 - 0x113257fff com.apple.URLMount.AFPPlugin (4.0 - 4.0) <91C71C5D-562D-37C4-9131-6E6F086288DE> /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
0x113285000 - 0x113290ff7 com.apple.AppleSRP (1.0 - 1) <E6D40A04-D788-3799-ABA4-819055C70951> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x11330b000 - 0x113317fff libnet.jnilib (??? - ???) <597B3A97-B9FE-3EF1-B679-D48167CF1C65> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libnet.jnilib
0x11331d000 - 0x113321fff libnio.jnilib (??? - ???) <3385FD79-7550-3BD9-AC99-51F42EF2CC06> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libnio.jnilib
0x113b8c000 - 0x113bb0fff libdcpr.jnilib (??? - ???) <B059ACB3-2862-3B2A-8D80-B88AB6145278> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libdcpr.jnilib
0x1140ff000 - 0x114125ff7 libjpeg.jnilib (??? - ???) <DAD75831-98EB-3C65-B6E3-50E344CB35E6> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libjpeg.jnilib
0x11416e000 - 0x114171fff libLatinSuppConverter.dylib (54.0.0 - compatibility 1.0.0) <AE9374F3-9A80-37B1-97F9-E5E952CE1D61> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
0x114213000 - 0x11424cfff +libswt-cocoa-3740.jnilib (??? - ???) <BFDF4C6B-E2EC-1B0E-CEFA-D970BFE6A3EC> /Users/USER/Documents/*/libswt-cocoa-3740.jnilib
0x1142dd000 - 0x114303fff +libswt-pi-cocoa-3740.jnilib (??? - ???) <426C4FC2-8051-0A28-4A12-C029EBDFCD63> /Users/USER/Documents/*/libswt-pi-cocoa-3740.jnilib
0x115c1f000 - 0x115c71fff libsuncmm.jnilib (??? - ???) <C032DD07-B828-38A2-A39D-315F14B7542E> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libsuncmm.jnilib
0x115cc3000 - 0x115d29ff7 libfontmanager.jnilib (??? - ???) <193DAC4D-86CC-3A76-811F-E0040A78BB72> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libfontmanager.jnilib
0x117599000 - 0x117771ff7 libawt.jnilib (??? - ???) <2DCB262F-4E60-356D-841E-F128C09228C3> /System/Library/Java/JavaVirtualMachines/1.6.0.jdk/Contents/Libraries/libawt.jnilib
0x11f18b000 - 0x11f21eff7 unorm8_bgra.dylib (1.50.69 - compatibility 1.0.0) <5FB796A4-1AD0-3B4D-AA83-F8A46E039224> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
0x11f49e000 - 0x11f4eaff7 com.apple.AppleShareClientCore (2.5 - 2.5) <CC62F28C-398E-35E2-B2C0-B85A02E57247> /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
0x7fff684dc000 - 0x7fff68510baf dyld (195.6 - ???) <0CD1B35B-A28F-32DA-B72E-452EAD609613> /usr/lib/dyld
0x7fff8a859000 - 0x7fff8a8a7fff libauto.dylib (??? - ???) <D8AC8458-DDD0-3939-8B96-B6CED81613EF> /usr/lib/libauto.dylib
0x7fff8a8a8000 - 0x7fff8a95bfff com.apple.CoreText (220.11.0 - ???) <0322442E-0530-37E8-A7D6-AEFD909F0AFE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8a95c000 - 0x7fff8a9feff7 com.apple.securityfoundation (5.0 - 55107) <6C2E7362-CB11-3CBD-BB1C-348E4B10F25A> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff8aa1e000 - 0x7fff8aa24ff7 com.apple.phonenumbers (1.0 - 47) <BC6C2FE2-99C0-3AD6-AA9C-C88780FFFCCF> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff8aa25000 - 0x7fff8aa78fff com.apple.AppleVAFramework (5.0.14 - 5.0.14) <45159B9E-05BF-35B2-AF76-D933490FBFB1> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff8aa7b000 - 0x7fff8aa91fff libGL.dylib (??? - ???) <6A473BF9-4D35-34C6-9F8B-86B68091A9AF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8aa92000 - 0x7fff8aae9fff com.apple.Suggestions (1.1 - 85.1) <DE511C42-D2F2-309C-80EE-53862245DE22> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x7fff8aaea000 - 0x7fff8af07ff7 com.apple.SceneKit (2.2 - 125.3) <DDCC8DB6-D5DB-31CD-A401-F56C84216E1C> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
0x7fff8af08000 - 0x7fff8af70ff7 com.apple.audio.CoreAudio (4.0.2 - 4.0.2) <DFD8F4DE-3B45-3A2E-9CBE-FD8D5DD30923> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff8af88000 - 0x7fff8af88fff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <C06A140F-6114-3B8B-B080-E509303145B8> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8af89000 - 0x7fff8b0bffff com.apple.vImage (5.1 - 5.1) <A08B7582-67BC-3EED-813A-4833645964A7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff8b297000 - 0x7fff8b2deff7 com.apple.CoreMedia (1.0 - 705.61) <0C34B0D4-DB8A-33C7-B67B-F443AD86482C> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff8b2df000 - 0x7fff8b371fff com.apple.PDFKit (2.6.2 - 2.6.2) <4C8D80F6-09BB-3BD5-983B-A24FBEB5BCF3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff8b372000 - 0x7fff8b839fff FaceCoreLight (1.4.7 - compatibility 1.0.0) <E9D2A69C-6E81-358C-A162-510969F91490> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x7fff8b876000 - 0x7fff8b88aff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Fr
[Updated on: Mon, 12 March 2012 06:16] by Moderator
Current Time: Sat Jul 19 20:54:40 EDT 2025
Powered by FUDForum. Page generated in 0.03738 seconds
