Home » Modeling » EMF » [Databinding] TreeViewer not notified(After setting a single object on a parent object the tree viewer is not refreshed.)
[Databinding] TreeViewer not notified [message #814535] |
Tue, 06 March 2012 10:11  |
Hi all,
after setting a single object on a parent object I cannot get the tree viewer to refresh automatically.
This can be reproduced with a simple demo model.
Root references 0..* branches
A branch referenes 0..* leaves
A leaf references 0..1 singleItems
An initial tree
root
branch1
leaf1
singleitem1
gets displayed correctly.
Adding a 'leaf2' to 'branch1' afterwards is also shown immediatly in the tree viewer.
But setting a single item on 'leaf2' has no effect on the tree viewer.
The TreeViewer is created as follows
public void createPartControl(Composite parent) {
Composite container = new Composite(parent, SWT.NONE);
container.setLayout(new GridLayout(1, false));
Composite treeComposite = new Composite(container, SWT.NONE);
treeComposite.setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true, 1, 1));
treeComposite.setLayout(new FillLayout());
createInitialModel();
treeViewer = new TreeViewer(treeComposite);
ObservableListTreeContentProvider cp = new ObservableListTreeContentProvider(
new DataModelTreeFactory(), null);
treeViewer.setContentProvider(cp);
IObservableSet knownElementSet = cp.getKnownElements();
IObservableMap[] map = new IObservableMap[3];
map[0] = EMFProperties.value(
ModelPackage.Literals.BRANCH__NAME
).observeDetail(knownElementSet);
map[1] = EMFProperties.value(
ModelPackage.Literals.LEAF__NAME
map[2] = EMFProperties.value(
ModelPackage.Literals.SINGLE_ITEM__NAME
treeViewer.setLabelProvider(new TestModelLabelProvider(treeViewer, map));
treeViewer.addDoubleClickListener(new IDoubleClickListener() {
public void doubleClick(DoubleClickEvent event) {
Object selection = ((IStructuredSelection) treeViewer
.getSelection()).getFirstElement();
treeViewer.setExpandedState(selection,
!treeViewer.getExpandedState(selection));
treeViewer.setInput(root);
private void createInitialModel(){
root = ModelFactory.eINSTANCE.createRoot();
root.setName("root");
Branch branch1 = ModelFactory.eINSTANCE.createBranch();
branch1.setName("branch1");
root.getBranches().add(branch1);
Leaf leaf1 = ModelFactory.eINSTANCE.createLeaf();
leaf1.setName("Leaf1");
branch1.getLeaves().add(leaf1);
SingleItem singleItem = ModelFactory.eINSTANCE.createSingleItem();
singleItem.setName("item1");
leaf1.setSingleItem(singleItem);
The DataModelTreeFactory is implemented as
public class DataModelTreeFactory implements IObservableFactory {
private IEMFListProperty rootNodes = EMFProperties.list(
ModelPackage.Literals.ROOT__BRANCHES);
private IEMFListProperty branchNodes = EMFProperties.list(
ModelPackage.Literals.BRANCH__LEAVES);
private IEMFListProperty leafNodes = EMFProperties.list(
ModelPackage.Literals.LEAF__SINGLE_ITEM);
public IObservable createObservable(Object target) {
System.out.println("target instanceof " + target.getClass());
if (target instanceof IObservableList){
return (IObservable)target;
} else if (target instanceof Root) {
return rootNodes.observe(target);
} else if (target instanceof Branch) {
return branchNodes.observe(target);
} else if (target instanceof Leaf) {
return leafNodes.observe(target);
return null;
From a command a single item is set on a leaf with the following code:
SingleItem item = modelFactory.createSingleItem();
item.setName("Item");
leaf.setSingleItem(item);
The item is only displayed by the tree after 'refresh()' has been called on the TreeViewer.
The debugger shows that org.eclipse.emf.databinding.internal.EMFPropertyListener.EMFValuePropertyListener
does not notify because getFeature() does not equal msg.getFeature() (???).
public abstract static class EMFValuePropertyListener extends EMFPropertyListener
public void notifyChanged(Notification msg)
if (getFeature() == msg.getFeature() && !msg.isTouch())
getListener().handleEvent(
My suspicion is that the observables are not created in the right way.
An hints on how to correctly handle the databinding for 0..1 references ?
Matthias
Re: [Databinding] TreeViewer not notified [message #814815 is a reply to message #814535] |
Tue, 06 March 2012 18:04   |
I'm currently traveling so don't have the time to take a look - if I'm
not following up until Friday please ping this thread so that it don't
get lost.
Tom
Am 06.03.12 16:11, schrieb Matthias Beer:
> Hi all,
> An initial tree
> root
> branch1
> leaf1
> singleitem1
> @Override
> return null;
> @Override
> Best regards,
> Matthias
Re: [Databinding] TreeViewer not notified [message #818847 is a reply to message #814815] |
Mon, 12 March 2012 03:31   |
Ok - I think I understand the problem - you want to show a single-valued
element in the tree.
I need to think a bit about this - I think there's no direct support for
this but you need to write some custom code to create a WritableList and
translate set calls into it.
Tom
Am 07.03.12 00:04, schrieb Tom Schindl:
> get lost.
> Tom
>> Hi all,
>> An initial tree
>> root
>> branch1
>> leaf1
>> singleitem1
>> @Override
>> return null;
>> @Override
>> Best regards,
>> Matthias
Re: [Databinding] TreeViewer not notified [message #818864 is a reply to message #818847] |
Mon, 12 March 2012 03:59   |
Yes as expected you'll need to translate your single valued attribute
into an WritableList in your factory method.
Tom
Am 12.03.12 08:31, schrieb Tom Schindl:
> Tom
>> get lost.
>> Tom
>>> Hi all,
>>> An initial tree
>>> root
>>> branch1
>>> leaf1
>>> singleitem1
>>> @Override
>>> return null;
>>> @Override
>>> Best regards,
>>> Matthias
Re: [Databinding] TreeViewer not notified [message #819848 is a reply to message #818954] |
Tue, 13 March 2012 07:56  |
Hi Tom,
I now created a 'ValuePropertyList' that hopefully will clean up the observables.
public class ValuePropertyList extends WritableList {
ArrayList<IObservableValue> observableValues = new ArrayList<IObservableValue>();
IEMFValueProperty [] valueProperties;
public ValuePropertyList(EStructuralFeature... features) {
valueProperties = new IEMFValueProperty [features.length];
int i = 0;
for (EStructuralFeature feature : features) {
valueProperties[i++] = EMFProperties.value(feature);
public WritableList observe(Object target){
for (IEMFValueProperty valueProperty : valueProperties) {
observeProperty(target,valueProperty);
return this;
private void observeProperty(Object target,IEMFValueProperty valueProperty){
Object singleValue = ((EObject)target).eGet(
(EStructuralFeature)valueProperty.getValueType());
if (singleValue != null) {
add(0, singleValue);
IObservableValue observableValue = valueProperty.observe(target);
observableValue.addValueChangeListener(new IValueChangeListener() {
public void handleValueChange(ValueChangeEvent event) {
if (event.diff.getOldValue() != null) {
remove(event.diff.getOldValue());
if (event.diff.getNewValue() != null) {
add(0, event.diff.getNewValue());
observableValues.add(observableValue);
public synchronized void dispose() {
for (IObservableValue observableValue : observableValues) {
System.out.println("disposing " + observableValue.toString() );
observableValue.dispose();
super.dispose();
The factory uses this class like this
return new ValuePropertyList(
ModelPackage.Literals.LEAF__SINGLE_ITEM,
ModelPackage.Literals.LEAF__SINGLE_ITEM2).
observe(target);
return null;
Matthias
Current Time: Sat Jul 19 13:45:30 EDT 2025
Powered by FUDForum. Page generated in 0.04005 seconds
