Home » Eclipse Projects » Eclipse Platform » Match brace
Match brace [message #81664] Tue, 24 June 2003 15:09 Go to next message
Originally posted by: rlopes.ipb.pt
Hi there! Does any one knows if it is possible and how to match braces?
In vi it should correspond to the '%' character.
Rui Pedro
Re: Match brace [message #81754 is a reply to message #81664] Tue, 24 June 2003 16:38 Go to previous messageGo to next message
For a Java editor, the "Highlight matching bracket" Preference in the
Appearance tab under Java/Editor controls this. (turn that setting on and
move the cursor to a paren or bracket to see it work).
Unfortunately, it won't show the matching brace if it's offscreen.
mike
> Rui Pedro
Re: Match brace [message #81798 is a reply to message #81754] Tue, 24 June 2003 18:10 Go to previous messageGo to next message
Originally posted by: richkulp.NOSPAM.us.ibm.com
Also, double-click just to the right of the left brace or to the left of
the right brace and the entire section between the selected brace and
the matching brace will be hightlighted.
This works for braces, parenthesis, and brackets.
Rich
Re: Match brace [message #82242 is a reply to message #81664] Wed, 25 June 2003 10:59 Go to previous messageGo to next message
> braces? In vi it should correspond to the '%' character.
Ctrl-Shift-P
Regards, Ilja
Re: Match brace [message #84204 is a reply to message #82242] Fri, 27 June 2003 15:00 Go to previous messageGo to next message
> Ctrl-Shift-P
Perfect! Thanks.
Do you know if this shortcut is configurable? Where can I find it?
Thanks a lot!
/rp
> Regards, Ilja
Re: Match brace [message #85041 is a reply to message #84204] Mon, 30 June 2003 03:57 Go to previous message
>> Ctrl-Shift-P
> Perfect! Thanks.
Navigate -> Go To Matching Bracket
Previous Topic:Question about "compare with local history"
Next Topic:TreeViewer.findItem(Object item)
Current Time: Sat Jul 19 14:24:45 EDT 2025
Powered by FUDForum. Page generated in 0.03843 seconds
