Home » Modeling » EMF » Proxy resolution problem
Proxy resolution problem [message #816877] Fri, 09 March 2012 06:24 Go to next message
I'm trying to run the EMF code generator programmatically (from Java),
but I'm getting weird "Unable to resolve proxy" errors when validating
the genmodel. I tried following the code in
org.eclipse.emf.codegen.ecore.Generator, and came up with something like
this:
> ResourceSet rs = new ResourceSetImpl();
> rs.getURIConverter().getURIMap()
> .putAll(EcorePlugin.computePlatformURIMap());
> URI uri = getServiceGenModelURI();
> Resource genModelResource = rs.getResource(uri, true);
> GenModel genModel = (GenModel) genModelResource.getContents().get(0);
> genModel.setCanGenerate(true);
> genModel.setUpdateClasspath(true);
> genModel.setCodeFormatting(true);
When validating ("genModel.validate()"), I get the following errors:
> Unable to resolve proxy 'platform:/plugin/com.iar.ide.debugger.rpc.runtime/model/runtimerpc.ecore#//NativeObject/id'
> Unable to resolve proxy 'platform:/plugin/com.iar.ide.debugger.rpc.runtime/model/runtimerpc.ecore#//NativeObject'
Running the code generator from the GenModel editor works fine. The
genmodel file looks like this:
> <genmodel:GenModel xmi:version="2.0"
> xmlns:xmi="http://www.omg.org/XMI" xmlns:genmodel="http://www.eclipse.org/emf/2002/GenModel" modelDirectory="/my.service/src-gen"
> modelPluginID="my.service" modelName="MyService" codeFormatting="true" importerID="org.eclipse.emf.importer.ecore"
> copyrightFields="false" usedGenPackages="platform:/plugin/com.iar.ide.debugger.rpc.runtime/model/runtimerpc.genmodel#//runtimerpc">
> <foreignModel>myservice.ecore</foreignModel>
> <genPackages prefix="MyService" basePackage="my.service" disposableProviderFactory="true"
> ecorePackage="myservice.ecore#/">
> <genEnums typeSafeEnumCompatible="false" ecoreEnum="myservice.ecore#//MyServiceMethod"/>
> <genClasses ecoreClass="myservice.ecore#//MyService">
> <genOperations ecoreOperation="myservice.ecore#//MyService/connect">
> <genParameters ecoreParameter="myservice.ecore#//MyService/connect/session"/>
> </genOperations>
> </genClasses>
> </genPackages>
> </genmodel:GenModel>
What am I missing?
/Jesper
Re: Proxy resolution problem [message #816894 is a reply to message #816877] Fri, 09 March 2012 06:49 Go to previous messageGo to next message
Jesper,
Comments below.
On 09/03/2012 12:24 PM, Jesper Eskilson wrote:
> the genmodel.
Are you running in the IDE?
> this:
Are you running in an Eclipse process with these bundles installed?
>> <?xml version="1.0" encoding="UTF-8"?>
>> <genParameters
>> </genOperations>
>> </genClasses>
>> </genPackages>
> What am I missing?
> /Jesper
Re: Proxy resolution problem [message #816934 is a reply to message #816894] Fri, 09 March 2012 07:41 Go to previous message
On 03/09/2012 12:49 PM, Ed Merks wrote:
> Jesper,
> Comments below.
I seemd to have forgotten to call "reconcile" on the genmodel. I looked
at how GenModelEditor did things, and saw that it called reconcile on
the model when initializing (and before validating).
After adding "genmodel.reconcile()" before the call to validate,
everything looks good.
/Jesper
Previous Topic:Executing an EMF command without recording
Next Topic:Combo-Binding for User-Entries
Current Time: Sat Jul 19 13:26:06 EDT 2025
Powered by FUDForum. Page generated in 0.04325 seconds
