Home » Modeling » M2T (model-to-text transformation) » how to get a list of import packages
how to get a list of import packages [message #814990] Tue, 06 March 2012 23:47 Go to next message
Hello.
I'm new to Acceleo and I'm working on my first template. I am
trying to generate java source code and need to get a list of packages
which need to be imported per class file. Any idea on how I could
accomplish this ? a [for] block with an OCL expression ?
Re: how to get a list of import packages [message #815066 is a reply to message #814990] Wed, 07 March 2012 02:23 Go to previous message
You first need to compute the set of all references, then convert the
reference targets to a set of all target modules, exclude target modules
that do not need referencing (e.g the current module) and emit that set,
perhaps after alphabeticizing.
Computing the set of references requires knowledge of the meta-model to
identify all potential referencing classes. For instance if using Ecore
you would identify at least ETypedElement.eType, EOperation.eExceptions.
These can be found conveniently by using the type arguments of
eAllContents or filter.
Ed Willink
On 07/03/2012 04:47, ritz par wrote:
> Hello.
Previous Topic:[Acceleo] How to generate a sequence (bag) of consecutive integers starting at 1
Next Topic:[ACCELEO] Using OCL Invocation and Setting delegates
Current Time: Sat Jul 19 20:11:43 EDT 2025
Powered by FUDForum. Page generated in 0.05371 seconds
