Home » Archived » BIRT » localize dataset value(localize (localise) a dataset value)
localize dataset value [message #813219] Sun, 04 March 2012 20:34 Go to next message
I have a urgent question ,e.g.
If the sudo SQL in the data set was something like (i.e. it generated derived data)
select case (age > 55 then 'Old' else 'young') from person
I would need to localise the values 'old ' and 'young', how would we do this ?
I would like to use the same property files used to localize the report title, chart xaxis title ...etc
Is it possible to some-how map the sql data values that comes back from a column in a SQL query to a property name in a localized text file ?
Can I create a map or rule of some kind to "'old' maps to key "report.age.old=Old"
Many thanks.
Anthony.
Re: localize dataset value [message #813942 is a reply to message #813219] Mon, 05 March 2012 16:43 Go to previous messageGo to next message
You could always add a computed column to the dataset that has an
expression similar to:
reportContext.getMessage(row["YOURCOLUMNNAME"]);
As long as the value of YOURCOLUMNAME is in a resource file associated
with the report it should convert it for you.
Jason
> derived data)
> this ?
> Many thanks.
> Anthony.
Re: localize dataset value [message #813978 is a reply to message #813942] Mon, 05 March 2012 17:42 Go to previous messageGo to next message
You can also use that same code in an oncreate of the data element like:
this.setDisplayValue(reportContext.getMessage(this.getValue());
Jason
> Jason
>> derived data)
>> this ?
>> Many thanks.
>> Anthony.
Re: localize dataset value [message #814747 is a reply to message #813978] Tue, 06 March 2012 16:04 Go to previous messageGo to next message
Many thanks for your prompt reply, we will go with the computed column approach :
reportContext.getMessage(row["CASESTATUS"]);
All you need are property values for each CASESTATUS value,e.g. if there were only 2 case status then the property file would only need
open=Open Status
close=Close Status
with a property localised to French containing:
open=Open in french
closed=close in french.
Re: localize dataset value [message #815482 is a reply to message #814747] Wed, 07 March 2012 13:16 Go to previous message
That is correct.
Jason
> approach :
> were only 2 case status then the property file would only need open=Open
> Status
> close=Close Status
> open=Open in french
Previous Topic:pageNumber variable does not seem to work correctly
Next Topic:How to do like this style.
Current Time: Sat Jul 19 17:58:16 EDT 2025
Powered by FUDForum. Page generated in 0.04405 seconds
