Home » Modeling » EMF » Add userinput to existing XMI
Add userinput to existing XMI [message #810753] Thu, 01 March 2012 09:10 Go to next message
Hello all,
I hope this is the right place to ask this question. I am new to use EMF and am trying to save the data that a user inputs in my application to an XMI file.
I have found a way to save 1 input. But everytime there is a new input, it gets overwritten and not added to it.
Here is the code to save that I have so far:
btnAddPerson.addMouseListener(new MouseAdapter() {
			public void mouseDown(MouseEvent e) {
				System.out.println(person.getFirstName());
				ResourceSet resourceSet = new ResourceSetImpl();
				URI fileURI = URI.createFileURI(SmartSignResourceUtil.getPath(DataPart.Persons));
				Resource resource = resourceSet.createResource(fileURI);
				resource.getContents().add(person);
				try {
					final Map<Object, Object> saveOptions = new HashMap<Object, Object>();
					saveOptions.put(Resource.OPTION_SAVE_ONLY_IF_CHANGED, Resource.OPTION_SAVE_ONLY_IF_CHANGED_MEMORY_BUFFER);
					saveOptions.put(XMLResource.OPTION_KEEP_DEFAULT_CONTENT, true);
					resource.save(saveOptions);
				} catch (IOException e1) {
					e1.printStackTrace();
				setTextTextbox();
So just to be clear:
The persondata gets added to the file. When I try to add another person, it overwrites the previous record instead of adding a new.
Re: Add userinput to existing XMI [message #811281 is a reply to message #810753] Fri, 02 March 2012 01:16 Go to previous messageGo to next message
Comments below.
On 01/03/2012 3:10 PM, El Shorty wrote:
> Hello all,
> @Override
> URI fileURI =
Do you want to read what's there at that URI so you can add to it?
> try {
> setTextTextbox();
Think about how you'd do this without EMF or just in general. Clearly
you need to check whether the file exists already and you need to load
it in that case so you can add to it and save the combined results.
ResourceSet.getURIConverter().exists is useful for checking if the
resource at that URI really exists. ResourceSet.getResource(uri, true)
is useful for loading already existing contents.
Re: Add userinput to existing XMI [message #811428 is a reply to message #811281] Fri, 02 March 2012 05:34 Go to previous messageGo to next message
Thanks for the help, I managed to get it working now. I tried a similar solution before, not with the .getResources but with the load command. There I had an IndexOutOfBound exception, that got fixed with using getResource instead.
Re: Add userinput to existing XMI [message #813538 is a reply to message #811428] Mon, 05 March 2012 06:49 Go to previous messageGo to next message
Now I have one other little problem that is linked to this issue. When I do:
 loadResource = resourceSet.getResource(fileURI, true);
but the file is empty I'll get an error. So the first Person can't get added now. I'm not sure how to fix this
Re: Add userinput to existing XMI [message #813546 is a reply to message #813538] Mon, 05 March 2012 07:05 Go to previous messageGo to next message
I explained earlier how you can test for existence. If there is not
underlying resource at the URI, you can use resourceSet.createResource
instead to create an empty new resource which you can then use and save
like you're doing now.
> I do:
Re: Add userinput to existing XMI [message #813614 is a reply to message #813546] Mon, 05 March 2012 08:59 Go to previous messageGo to next message
I tried that but it still gives me errors. Here is the error
!SESSION 2012-03-05 14:45:39.082 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.7.0_03
Framework arguments: -product smartapps.smartsignature.ui.product
Command-line arguments: -product smartapps.smartsignature.ui.product -data C:\../../runtime-smartsignature.product -dev file:C:/.../.metadata/.plugins/org.eclipse.pde.core/smartsignature.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.ui 4 0 2012-03-05 14:50:33.074
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.xml.sax.SAXParseExceptionpublicId: file:/C:/.../Groups.smartsigndatabase; systemId: file:/C:/.../Groups.smartsigndatabase; lineNumber: 1; columnNumber: 1; Premature end of file.
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
at smartapps.smartsignature.ui.views.SaveMethod.save(SaveMethod.java:55)
at smartapps.smartsignature.ui.views.GroupView$2.mouseDown(GroupView.java:135)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:191)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at smartapps.smartsignature.ui.Application.start(Application.java:20)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Caused by: org.xml.sax.SAXParseExceptionpublicId: file:/C:/.../Groups.smartsigndatabase; systemId: file:/C:/.../Groups.smartsigndatabase; lineNumber: 1; columnNumber: 1; Premature end of file.
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLScanner.reportFatalError(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:242)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1511)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1290)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:255)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:270)
... 29 more
And this is the code that gives the error:
public void save(EObject object)
		URI fileURI;
		EList<EObject> list = null;
		Resource loadResource = null;
		if (object instanceof Person)
		else if (object instanceof Group)
			fileURI = URI.createFileURI(SmartSignResourceUtil.getPath(DataPart.Groups));
		else if (object instanceof Address)
			fileURI = URI.createFileURI(SmartSignResourceUtil.getPath(DataPart.Addresses));
		else if (object instanceof Contact)
			fileURI = URI.createFileURI(SmartSignResourceUtil.getPath(DataPart.Contacts));
		else
			fileURI = null;
		if(resourceSet.getURIConverter().exists(fileURI, null))
			loadResource = resourceSet.getResource(fileURI, true);           //<--- here is the error
			list = loadResource.getContents();
		list.add(object);
		resource.getContents().addAll(list);
		try {
I check if it exists, if it does it should load, problem is the empty file exists so it tries to load that and that it errors
Re: Add userinput to existing XMI [message #813638 is a reply to message #813614] Mon, 05 March 2012 09:34 Go to previous messageGo to next message
What's happening here?
at
at
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !STACK 0
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> ... 29 more
> URI fileURI;
> fileURI =
> fileURI =
> fileURI =
> fileURI =
> else
> fileURI = null;
> list.add(object);
> try {
> true);
Re: Add userinput to existing XMI [message #813645 is a reply to message #813638] Mon, 05 March 2012 09:50 Go to previous messageGo to next message
Ed Merks wrote on Mon, 05 March 2012 09:34
at
That's the imported method that should get my data from my file, it works when there is something in it to retrieve, but it doesn't work on an empty file. (I think)
at
that's the method I just copy/pasted
Re: Add userinput to existing XMI [message #813736 is a reply to message #813645] Mon, 05 March 2012 11:53 Go to previous message
I didn't see that at the end. So it looks like the file exists but
doesn't have a complete XML document, as you said. You can look at the
file to see, so you don't need to guess. Do you expect it to be in that
state? If you expect to deal with bad files, you can use logic like
what you see in the generated editor (with a catch block that calls
getResource(uri, false) to fetch the resource that failed to load). I
would have expected the createResource to be in an else branch...
>> at
Previous Topic:URI Fragments
Next Topic:Missing support for XML Schema documentation annotation
Current Time: Sun Jul 20 08:05:53 EDT 2025
Powered by FUDForum. Page generated in 0.05169 seconds
