Home » Modeling » TMF (Xtext) » Help with xtext grammar void method(Create a grammar to void method)
Help with xtext grammar void method [message #813255] Sun, 04 March 2012 22:02 Go to next message
Hi guys,
If possible, I would like of an example or some tutorial of the grammar that define a void method.
Thanks in advance!
Re: Help with xtext grammar void method [message #813626 is a reply to message #813255] Mon, 05 March 2012 09:17 Go to previous messageGo to next message
Sorry, but I don't understand your question. What do you mean by "Xtext
void method" ?
- henrik
On 2012-05-03 4:02, Leonardo Torres wrote:
> Hi guys,
> Thanks in advance!
Re: Help with xtext grammar void method [message #813711 is a reply to message #813626] Mon, 05 March 2012 11:28 Go to previous messageGo to next message
I´m sorry. Let me explain
I'm creating a DSL for Oriented Objetct teach purposes, so I can create rule for entities (class) properties (attibute) and method with return. However, I don´t know to create a rule for method without return. Thus, I would like of an exemple of the rule for a method without return.
Thank for help-me
Re: Help with xtext grammar void method [message #813726 is a reply to message #813711] Mon, 05 March 2012 11:38 Go to previous messageGo to next message
Hat about simply makeing the return type optional in the grammar
Re: Help with xtext grammar void method [message #813791 is a reply to message #813726] Mon, 05 March 2012 13:07 Go to previous messageGo to next message
Thanks for answer.
I did that :
Method:
	 'operacao' name= ValidID '('(param+=FullJvmFormalParameter (','
	   param+=FullJvmFormalParameter)*)?') retorna' resultType = ResultType
	       body=XBlockExpression
ResultType :
	NoResult | Result
NoResult:
	'nada'
Result :
	type=JvmTypeReference
It is works! In the Editor:
operacao test() retorna nada{
        var int nome = 2;
    	return 2;
Where can I validate the semantic ? Because in this case above, It´s wrong. The word 'nada' means no return, but I can still write the statement return.
Re: Help with xtext grammar void method [message #813823 is a reply to message #813791] Mon, 05 March 2012 13:55 Go to previous messageGo to next message
it would have been very helpful if youd mentione using Xbase before.
what you are askin for is about xbases type system.
if you translate your stuff correctly in the jvmmodelinferrer it will work out of the box.
so simply infer void as return type
NoResult:
	{NoResult}'nada'
package org.eclipse.xtext.example.domainmodel.jvmmodel
import com.google.inject.Inject
import org.eclipse.xtext.common.types.JvmDeclaredType
import org.eclipse.xtext.example.domainmodel.domainmodel.Entity
import org.eclipse.xtext.example.domainmodel.domainmodel.Operation
import org.eclipse.xtext.example.domainmodel.domainmodel.Property
import org.eclipse.xtext.naming.IQualifiedNameProvider
import org.eclipse.xtext.util.IAcceptor
import org.eclipse.xtext.xbase.jvmmodel.AbstractModelInferrer
import org.eclipse.xtext.xbase.jvmmodel.JvmTypesBuilder
import org.eclipse.xtext.example.domainmodel.domainmodel.Result
class DomainmodelJvmModelInferrer extends AbstractModelInferrer {
	@Inject extension JvmTypesBuilder
	@Inject extension IQualifiedNameProvider
	def dispatch infer(Entity e, IAcceptor<JvmDeclaredType> acceptor, boolean prelinkingPhase) {
		acceptor.accept(
			e.toClass( e.fullyQualifiedName ) [
				documentation = e.documentation
				if (e.superType != null)
					superTypes += e.superType.cloneWithProxies
				for ( f : e.features ) {
					switch f {
						Property : {
							members += f.toField(f.name, f.type)
							members += f.toGetter(f.name, f.type)
							members += f.toSetter(f.name, f.type)
						Operation : {
							members += f.toMethod(f.name, if (f.result instanceof Result) (f.result as Result).type else f.newTypeRef("java.lang.void")) [
								documentation = f.documentation
								for (p : f.params) {
									parameters += p.toParameter(p.name, p.parameterType)
								body = f.body
this will work in the editor
but will still lead to a compile error in the generated java code (if the ops body is empty)
so a bug for this will be welcome
~Christian
[Updated on: Mon, 05 March 2012 13:56] by Moderator
Re: Help with xtext grammar void method [message #813845 is a reply to message #813823] Mon, 05 March 2012 14:30 Go to previous messageGo to next message
Thanks for all answer.
Re: Help with xtext grammar void method [message #813904 is a reply to message #813845] Mon, 05 March 2012 15:51 Go to previous messageGo to next message
Just one more question. Are there any indication about xtext/xbase/xtend book´s ?
Re: Help with xtext grammar void method [message #813909 is a reply to message #813823] Mon, 05 March 2012 15:51 Go to previous messageGo to next message
Hi Christian,
f.newTypeRef("void")
instead of
should do the trick.
Sebastian
Am 05.03.12 19:56, schrieb Christian Dietrich:
> NoResult:
> {NoResult}'nada'
> acceptor.accept(
> switch f {
> Property : {
> Operation : {
> body = f.body
> ~Christian
Re: Help with xtext grammar void method [message #813916 is a reply to message #813909] Mon, 05 March 2012 16:06 Go to previous message
Hi Sebastian,
yes it does
~Christian
Previous Topic:linking cross-references manually
Next Topic:Scoping question, references to sub-elements of auto-imported elements
Current Time: Sat Jul 19 22:37:11 EDT 2025
Powered by FUDForum. Page generated in 0.11681 seconds
