Home » Eclipse Projects » EGit / JGit » Installation EGit(Missing requirement: EGit Mylyn UI)
Installation EGit [message #811187] Thu, 01 March 2012 21:44 Go to next message
Cannot complete the install because one or more required items could not be found.
Software being installed: EGit Mylyn 1.3.0.201202151440-r (org.eclipse.egit.mylyn.feature.group 1.3.0.201202151440-r)
Missing requirement: EGit Mylyn UI 1.3.0.201202151440-r (org.eclipse.egit.mylyn.ui 1.3.0.201202151440-r) requires 'bundle
Any idea how to solve the issue?
Thank you!
Peter
Re: Installation EGit [message #811332 is a reply to message #811187] Fri, 02 March 2012 02:56 Go to previous messageGo to next message
What is the complete error message?
After the line "Missing requirement: EGit Mylyn UI 1.3.0.201202151440-r (org.eclipse.egit.mylyn.ui 1.3.0.201202151440-r) requires 'bundle" there should be the missing packages.
Re: Installation EGit [message #811370 is a reply to message #811332] Fri, 02 March 2012 03:58 Go to previous messageGo to next message
I am sorry Sad
This is a completed message I got:
Missing requirement: EGit Mylyn UI 1.3.0.201202151440-r (org.eclipse.egit.mylyn.ui 1.3.0.201202151440-r) requires 'bundle org.eclipse.mylyn.monitor.core [3.0.0,4.0.0)' but it could not be found
Cannot satisfy dependency:
From: EGit Mylyn 1.3.0.201202151440-r (org.eclipse.egit.mylyn.feature.group 1.3.0.201202151440-r)
To: org.eclipse.egit.mylyn.ui [1.3.0.201202151440-r]
Re: Installation EGit [message #811393 is a reply to message #811370] Fri, 02 March 2012 04:40 Go to previous messageGo to next message
Is the checkbox "Contact all update sites during install to find required software" checked? That dependency should be in the indigo repository, maybe you can also try to add the Mylyn update site (http://download.eclipse.org/mylyn/releases/latest), and then try again to install.
Re: Installation EGit [message #811442 is a reply to message #811393] Fri, 02 March 2012 05:51 Go to previous messageGo to next message
You're right! My mistake - I did not have marked the checkbox "Contact all update sites during install to find required software". Now it's installing!
Thank you very much! SOLVED
Peter
Re: Installation EGit [message #896261 is a reply to message #811187] Tue, 17 July 2012 15:00 Go to previous messageGo to next message
I had a problem with this, figured it out Smile And so now I don't know how to delete this post, sorry that I'm a newcomer here.
[Updated on: Tue, 17 July 2012 15:03] by Moderator
Re: Installation EGit [message #896287 is a reply to message #896261] Tue, 17 July 2012 17:14 Go to previous messageGo to next message
Don Hahn skrev 2012-07-17 21.00:
> I'm having pretty much this same exact problem, but the checkbox for
> "Contact all update sites during install to find required software" is
> checked by default. I'm trying to get EGit from
> http://download.eclipse.org/egit/updates. The entire message for me is
> be found.
> Software being installed: EGit Import Support 2.0.0.201206130900-r
> (org.eclipse.egit.import.feature.group 2.0.0.201206130900-r)
> Missing requirement: EGit Import 2.0.0.201206130900-r
> (org.eclipse.egit.import 2.0.0.201206130900-r) requires 'bundle
> org.eclipse.team.core 3.6.100' but it could not be found
> From: EGit Import Support 2.0.0.201206130900-r
> To: org.eclipse.egit.import [2.0.0.201206130900-r]
That's not the same problem. Skip the "EGit Import Support" feature if
you are not on Eclipse 3.8 or 4.2.
-- robin
Re: Installation EGit [message #1779528 is a reply to message #811332] Tue, 09 January 2018 04:26 Go to previous messageGo to next message
I am also trying to install GIt and getting error "Cannot complete the install because one or more required items could not be found.
Software being installed: Git integration for Eclipse - Task focused interface 4.10.0.201712302008-r (org.eclipse.egit.mylyn.feature.group 4.10.0.201712302008-r)
Missing requirement: EGit Mylyn UI 4.10.0.201712302008-r (org.eclipse.egit.mylyn.ui 4.10.0.201712302008-r) requires 'bundle org.eclipse.mylyn.monitor.core [3.0.0,4.0.0)' but it could not be found
From: Git integration for Eclipse - Task focused interface 4.10.0.201712302008-r (org.eclipse.egit.mylyn.feature.group 4.10.0.201712302008-r)
To: org.eclipse.egit.mylyn.ui [4.10.0.201712302008-r]
1) I have already marker check box for "Contact all update sites during install to find required software".
But still I am getting such error.Kindly Suggest
Bhupendra Singh
Re: Installation EGit [message #1780548 is a reply to message #1779528] Tue, 23 January 2018 15:24 Go to previous message
You probably don't have Mylyn installed in your Eclipse installation. You should be able to install it from
your release's update site. If you are using the latest release Oxygen (Eclipse 4.7.x) you should be able
to install it from http://download.eclipse.org/releases/oxygen
Previous Topic:GIT HTTPS Internal CA "cannot open git-upload-pack"
Next Topic:Cancelling a JGit operation
Current Time: Sat Jul 19 21:39:08 EDT 2025
Powered by FUDForum. Page generated in 0.04074 seconds
