Home » Archived » BIRT » How to display the toolbar in the Run Pattern
How to display the toolbar in the Run Pattern [message #811248] Fri, 02 March 2012 00:08 Go to next message
I have a problem for export the data in run pattern.
I am wondering how to display the toolbar or display the export data dialog in the Run Pattern?
The Code as :
<birt:viewer id="birtViewer"
reportDesign="callTimeDaily.rptdesign" format="HTML" pattern="run"
showParameterPage="false" isHostPage="true" showTitle="false">
<birt:param name="startDate" value="<%=startDate%>"/>
<birt:param name="endDate" value="<%=endDate%>"/>
</birt:viewer>
[Updated on: Fri, 02 March 2012 00:26] by Moderator
Re: How to display the toolbar in the Run Pattern [message #811753 is a reply to message #811248] Fri, 02 March 2012 14:24 Go to previous message
The toolbar is only available in the frameset Pattern.
Jason
On 3/2/2012 12:08 AM, Missing name Mising name wrote:
> Wrote as :
> </birt:viewer>
> How to display the toolbar in the Run Pattern?
> Or display the export dialog for Run Pattern?
Previous Topic:Birt Viewer Limits Results to 500 records
Next Topic:How to remove column in chart
Current Time: Sat Jul 19 19:51:36 EDT 2025
Powered by FUDForum. Page generated in 0.04613 seconds
