GraphitiUi.getUiLayoutService().calculateTextSize [message #810209] |
Wed, 29 February 2012 16:00  |
Is there any way other than
GraphitiUi.getUiLayoutService().calculateTextSize(text, font);
to calculate a text dimension?
I have a wizard which is generating a diagram and dark mode and my IAddFeature implementations are calling layoutPictogramElement(containerShape)
The problem is that in the related ILayoutFeature, I need to calculate the dimensions of my ga based on the dimensions of the contained Text, especially the maximum width.
But when I do that, I get:
Quote:org.eclipse.emf.common.util.WrappedException: An exception was ignored during command execution
at org.eclipse.emf.common.command.BasicCommandStack.handleError(BasicCommandStack.java:287)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.handleError(AbstractTransactionalCommandStack.java:125)
at org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:118)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.basicExecute(AbstractTransactionalCommandStack.java:241)
at org.eclipse.emf.transaction.impl.TransactionalCommandStackImpl.doExecute(TransactionalCommandStackImpl.java:63)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at org.eclipse.graphiti.internal.command.CommandExec.executeCommand(CommandExec.java:75)
at org.eclipse.graphiti.features.impl.AbstractFeatureProvider.layoutIfPossible(AbstractFeatureProvider.java:288)
at org.eclipse.graphiti.features.impl.AbstractFeature.layoutPictogramElement(AbstractFeature.java:181)
at net.stuff.servoy.eclipse.graphiti.features.tables.TableAddFeature.add(TableAddFeature.java:148)
at org.eclipse.graphiti.internal.command.AddFeatureCommandWithContext.execute(AddFeatureCommandWithContext.java:76)
at org.eclipse.graphiti.internal.command.GFPreparableCommand.doExecute(GFPreparableCommand.java:37)
at org.eclipse.emf.transaction.RecordingCommand.execute(RecordingCommand.java:135)
at org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:84)
at org.eclipse.graphiti.features.impl.AbstractFeatureProvider.addIfPossible(AbstractFeatureProvider.java:361)
at org.eclipse.graphiti.features.impl.AbstractFeature.addGraphicalRepresentation(AbstractFeature.java:108)
at net.stuff.servoy.eclipse.graphiti.features.FileAddFeature.addTable(FileAddFeature.java:601)
at net.stuff.servoy.eclipse.graphiti.features.FileAddFeature.addIFile(FileAddFeature.java:168)
at net.stuff.servoy.eclipse.graphiti.features.FileAddFeature.add(FileAddFeature.java:142)
at net.stuff.servoy.eclipse.graphiti.ui.wizards.AddFilesCommand.doExecute(AddFilesCommand.java:90)
at net.stuff.servoy.eclipse.graphiti.ui.wizards.CreateDiagramWizard.doFinish(CreateDiagramWizard.java:244)
at net.stuff.servoy.eclipse.graphiti.ui.wizards.CreateDiagramWizard$1.run(CreateDiagramWizard.java:146)
at org.eclipse.jface.operation.ModalContext$ModalContextThread.run(ModalContext.java:121)
Caused by: org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.SWT.error(SWT.java:3969)
at org.eclipse.swt.widgets.Widget.error(Widget.java:468)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:282)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:273)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:223)
at org.eclipse.swt.widgets.Shell.<init>(Shell.java:158)
at org.eclipse.draw2d.FigureUtilities.getGC(FigureUtilities.java:74)
at org.eclipse.draw2d.FigureUtilities.setFont(FigureUtilities.java:363)
at org.eclipse.draw2d.FigureUtilities.getStringDimension(FigureUtilities.java:124)
at org.eclipse.draw2d.FigureUtilities.getStringExtents(FigureUtilities.java:154)
at org.eclipse.draw2d.TextUtilities.getStringExtents(TextUtilities.java:43)
at org.eclipse.graphiti.ui.internal.services.impl.GefService.calculateTextSize(GefService.java:525)
at org.eclipse.graphiti.ui.internal.services.impl.UiLayoutService.calculateTextSize(UiLayoutService.java:118)
at net.stuff.servoy.eclipse.graphiti.features.tables.TableLayoutFeature.layout(TableLayoutFeature.java:74)
at org.eclipse.graphiti.features.impl.AbstractLayoutFeature.execute(AbstractLayoutFeature.java:56)
at org.eclipse.graphiti.internal.command.GenericFeatureCommandWithContext.execute(GenericFeatureCommandWithContext.java:64)
... 32 more
So I suppose GraphitiUi.getUiLayoutService() is not meant to be used in dark mode.
But I fail to find out how to calculate text dimensions apart from using this service...
Any tips/guidance would be welcome.
Thanks in advance,
-Patrick
Re: GraphitiUi.getUiLayoutService().calculateTextSize [message #819499 is a reply to message #810209] |
Mon, 12 March 2012 21:21  |
i came across the same problem (in the same situation @ an handler started by the "create from existing"-wizard) and filed bug @374020 (cannot post a link by now)
a workaround (of course not recommended) could be to create a wrapper for "GraphitiUi.getUiLayoutService().calculateTextSize(String, Font)" which runs the method synchronously in the UI thread. all accesses to the method which could be processed during the "dark feature" should use this wrapper method.
example:
public class CalculateUtil {
private static class CalculateRunnable implements Runnable {
private final String text;
private final Font font;
private IDimension dimension;
public CalculateRunnable(String text, Font font) {
this.text = text;
this.font = font;
public void run() {
dimension = GraphitiUi.getUiLayoutService().calculateTextSize(text, font);
public IDimension getDimension() {
return dimension;
public static IDimension calculateTextSize(String text, Font font) {
CalculateRunnable runnable = new CalculateRunnable(text, font);
PlatformUI.getWorkbench().getDisplay().syncExec(runnable);
return runnable.getDimension();
[Updated on: Mon, 12 March 2012 21:22] by Moderator
FUDForum. Page generated in 0.04083 seconds
