Home » Archived » M2M (model-to-model transformation) » [QVTo] Standalone execution
[QVTo] Standalone execution [message #807941] Mon, 27 February 2012 02:47 Go to next message
A few earlier threads suggest some problems but ultimately success when
running a QVTo transformation standalone, but also some ambiguity about
quite what standalone means.
Does anyone know how to run a QVTo transformation when the Eclipse
platform is not running; i.e. no IFiles and no plugin registries?
It appears that DeployedQvtModule supports execution from a plugin and
that WorkspaceQvtModule supports execution from an IFile, but where is
the support for execution from a standalone Resource?
Ed Willink
Re: [QVTo] Standalone execution [message #809831 is a reply to message #807941] Wed, 29 February 2012 05:09 Go to previous messageGo to next message
Hi All
It's pretty easy; just use org.eclipse.m2m.qvt.oml.TransformationExecutor.
Only minor trick is to provide positionally aligned ModelExtents with a
probably empty output one, whose contents need to be copied to an output
resource and saved on completion.
An MWE2 integration may soon be found at:
/org.eclipse.ocl.examples.build/src/org/eclipse/ocl/examples/build/utilities/QvtoWorkflowComponent.java
Ed Willink
On 27/02/2012 07:47, Ed Willink wrote:
> Hi
> when running a QVTo transformation standalone, but also some ambiguity
> about quite what standalone means.
> Regards
> Ed Willink
Re: [QVTo] Standalone execution [message #817207 is a reply to message #809831] Fri, 09 March 2012 14:48 Go to previous messageGo to next message
Ed,
Have you got QVTO running outside of OSGi (i.e. in a Java static void
main?) or is it just outside of Eclipse but within Equinox? I ran into
headaches getting things like blackbox units and transformation units
to compile when I tried this a while ago as a plain old java runtime,
but I've been successfully running it with a light-weight OSGi kernel.
Alan
On 2012-02-29 10:09:33 +0000, Ed Willink said:
> Hi All
> output resource and saved on completion.
> Regards
> Ed Willink
>> Hi
>> Regards
>> Ed Willink
Re: [QVTo] Standalone execution [message #817218 is a reply to message #817207] Fri, 09 March 2012 15:05 Go to previous message
Hi Alan
I'm running within the MWE2 environment for which
EMFPlugin.IS_ECLIPSE_RUNNING is false.
I have my own ProjectMapSetup to fully populate platform:/resource/...
and platform:/plugin/... from the class path. See
https://bugs.eclipse.org/bugs/show_bug.cgi?id=360926#c7 for my analysis
of what's needed to make standalone work.
Ed Willink
On 09/03/2012 19:48, Alan McMorran wrote:
> Ed,
> into headaches getting things like blackbox units and transformation
> units to compile when I tried this a while ago as a plain old java
> runtime, but I've been successfully running it with a light-weight
> OSGi kernel.
> Alan
>> Hi All
>> a probably empty output one, whose contents need to be copied to an
>> Regards
>> Ed Willink
>>> Hi
>>> ambiguity about quite what standalone means.
>>> and that WorkspaceQvtModule supports execution from an IFile, but
>>> where is the support for execution from a standalone Resource?
>>> Regards
>>> Ed Willink
Previous Topic:Papyrus MDT DI2ToDI
Next Topic:Metamodel in workspace in QVTO Problem
Current Time: Sun Jul 20 16:39:29 EDT 2025
Powered by FUDForum. Page generated in 0.03891 seconds
