JPQL: SIZE function causing strange exceptions [message #809648] |
Tue, 28 February 2012 23:41  |
I'm porting from Hibernate. What's wrong with SIZE function in the JPQL statement (assuming the mappings are correct)?:
SELECT NEW de.poyry.pqgenerator.view.PqListItem(
pq.id,
pq.name,
pq.submissionDate,
pe.firstName,
pe.lastName,
SIZE(pa))
FROM Prequalification pq
JOIN pq.user us
JOIN us.person pe
LEFT JOIN pq.partnerships pa
LEFT JOIN pa.company co
GROUP BY pq.id
Here's the constructor signature (the only constructor):
public PqListItem(Integer id, String name, Date submissionDate,
String ownerFirstName, String ownerLastName,
Integer numPartnerships) The query results in:
Caused by: Exception [EclipseLink-8023] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.JPQLException
Exception Description: Syntax error parsing the query [^^...].
Internal Exception: org.eclipse.persistence.internal.libraries.antlr.runtime.EarlyExitException
at org.eclipse.persistence.exceptions.JPQLException.syntaxError(JPQLException.java:352)
at org.eclipse.persistence.internal.jpa.parsing.jpql.JPQLParser.handleRecognitionException(JPQLParser.java:354)
at org.eclipse.persistence.internal.jpa.parsing.jpql.JPQLParser.addError(JPQLParser.java:246)
at org.eclipse.persistence.internal.jpa.parsing.jpql.JPQLParser.reportError(JPQLParser.java:363)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.pathExpression(JPQLParser.java:2894)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.collectionValuedPathExpression(JPQLParser.java:2624)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.size(JPQLParser.java:7660)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.functionsReturningNumerics(JPQLParser.java:6710)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.arithmeticPrimary(JPQLParser.java:4762)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.arithmeticFactor(JPQLParser.java:4660)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.arithmeticTerm(JPQLParser.java:4546)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.simpleArithmeticExpression(JPQLParser.java:4462)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.scalarExpression(JPQLParser.java:4834)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.constructorItem(JPQLParser.java:1980)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.constructorExpression(JPQLParser.java:1849)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.selectExpression(JPQLParser.java:1300)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.selectItem(JPQLParser.java:1169)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.selectClause(JPQLParser.java:1081)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.selectStatement(JPQLParser.java:359)
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.document(JPQLParser.java:281)
at org.eclipse.persistence.internal.jpa.parsing.jpql.JPQLParser.parse(JPQLParser.java:134)
at org.eclipse.persistence.internal.jpa.parsing.jpql.JPQLParser.buildParseTree(JPQLParser.java:95)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.buildEJBQLDatabaseQuery(EJBQueryImpl.java:215)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.buildEJBQLDatabaseQuery(EJBQueryImpl.java:190)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.<init>(EJBQueryImpl.java:142)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.<init>(EJBQueryImpl.java:126)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.createQuery(EntityManagerImpl.java:1475)
... 139 more
Caused by: org.eclipse.persistence.internal.libraries.antlr.runtime.EarlyExitException
at org.eclipse.persistence.internal.jpa.parsing.jpql.antlr.JPQLParser.pathExpression(JPQLParser.java:2882)
... 161 more
The seems to cause problems. When changing to I get:
Caused by: Exception [EclipseLink-6137] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.QueryException
Exception Description: An Exception was thrown while executing a ReportQuery with a constructor expression: java.lang.NoSuchMethodException: de.poyry.pqgenerator.view.PqListItem.<init>(java.lang.Integer, java.lang.String, java.util.Date, java.lang.String, java.lang.String, int)
Query: ReportQuery(referenceClass=Prequalification jpql="SELECT NEW de.poyry.pqgenerator.view.PqListItem(pq.id, pq.name, pq.submissionDate, pe.firstName, pe.lastName, SIZE(pq.partnerships)) FROM Prequalification pq JOIN pq.user us JOIN us.person pe LEFT JOIN pq.partnerships pa LEFT JOIN pa.company co GROUP BY pq.id")
Default FetchGroup(){id, partnerships, submissionDate, nodes, designSheets, name, statuses, group, user, tendering, isLocked}
at org.eclipse.persistence.exceptions.QueryException.exceptionWhileUsingConstructorExpression(QueryException.java:494)
at org.eclipse.persistence.queries.ConstructorReportItem.initialize(ConstructorReportItem.java:188)
at org.eclipse.persistence.queries.ReportQuery.prepare(ReportQuery.java:1044)
at org.eclipse.persistence.queries.DatabaseQuery.checkPrepare(DatabaseQuery.java:598)
at org.eclipse.persistence.queries.ObjectLevelReadQuery.checkPrepare(ObjectLevelReadQuery.java:839)
at org.eclipse.persistence.queries.DatabaseQuery.prepareCall(DatabaseQuery.java:1719)
at org.eclipse.persistence.internal.jpa.EJBQueryImpl.buildEJBQLDatabaseQuery(EJBQueryImpl.java:268)
at org.eclipse.persistence.internal.jpa.EntityManagerImpl.createQuery(EntityManagerImpl.java:1497)
at com.sun.enterprise.container.common.impl.EntityManagerWrapper.createQuery(EntityManagerWrapper.java:468)
at de.poyry.pqgenerator.service.PqService.findAllPqs(PqService.java:60)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.glassfish.ejb.security.application.EJBSecurityManager.runMethod(EJBSecurityManager.java:1052)
at org.glassfish.ejb.security.application.EJBSecurityManager.invoke(EJBSecurityManager.java:1124)
at com.sun.ejb.containers.BaseContainer.invokeBeanMethod(BaseContainer.java:5366)
at com.sun.ejb.EjbInvocation.invokeBeanMethod(EjbInvocation.java:619)
at com.sun.ejb.containers.interceptors.AroundInvokeChainImpl.invokeNext(InterceptorManager.java:800)
at com.sun.ejb.EjbInvocation.proceed(EjbInvocation.java:571)
at org.jboss.weld.ejb.SessionBeanInterceptor.aroundInvoke(SessionBeanInterceptor.java:46)
at com.sun.ejb.containers.interceptors.AroundInvokeInterceptor.intercept(InterceptorManager.java:861)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.doAround(SystemInterceptorProxy.java:162)
at com.sun.ejb.containers.interceptors.SystemInterceptorProxy.aroundInvoke(SystemInterceptorProxy.java:144)
at com.sun.ejb.containers.interceptors.InterceptorManager.intercept(InterceptorManager.java:370)
at com.sun.ejb.containers.BaseContainer.__intercept(BaseContainer.java:5338)
at com.sun.ejb.containers.BaseContainer.intercept(BaseContainer.java:5326)
at com.sun.ejb.containers.EJBLocalObjectInvocationHandler.invoke(EJBLocalObjectInvocationHandler.java:214)
... 106 more
Looks like not autoboxing is occurring. The type of the last constructor param is Integer. Strange, it should work IMO.
Can anyone help please? I'm using EclipseLink 2.3.2 on GlassFish 3.1.1.
How do I correctly determine the number of partnerships from within the query? What does the JPA define here?
Thanks in advance
Karsten
[Updated on: Wed, 29 February 2012 08:40] by Moderator
FUDForum. Page generated in 0.02981 seconds
