Home » Modeling » TMF (Xtext) » (XText 1.0) importUri and ProposalProvider("unresolvable" Proxies provided for imported elements)
(XText 1.0) importUri and ProposalProvider [message #787997] Wed, 01 February 2012 03:12 Go to next message
I create a dsl using Xtext 1.0. I use the "importUri" method and all work fine.
I implement some methods for my model elements in the label provider but due to the
getDisplayString() method in org.eclipse.xtext.ui.editor.contentassist.AbstractContentProposalProvider they are never called for content assist proposal, only elements name are displayed.
I tried solve this by overriding the getDisplayString method in my ProposalProvider.
	protected String getDisplayString(EObject modelElement, String qualifiedName, String shortName) {
		//try resolve proxy but don't work
		if (modelElement.eIsProxy()) {
			modelElement = EcoreUtil.resolve(modelElement, modelElement.eResource());
		String displayString = getLabelProvider().getText(modelElement);
		return displayString;
when the ProposalProvider selects an element from imported model the selected modelElement is a proxy with a null eResource() and i can't create a correct displayString.
Maybe my workflow configuration is incomplete for Import and contentAssist support:
module com.sysord.Gvbscript
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "classpath:/com/sysord/Gvbscript.xtext"
var file.extensions = "gvbs"
var projectName = "com.sysord.gvbscript"
var runtimeProject = "../${projectName}"
Workflow {
    bean = StandaloneSetup {
		platformUri = "${runtimeProject}/.."
	component = DirectoryCleaner {
		directory = "${runtimeProject}/src-gen"
		directory = "${runtimeProject}.ui/src-gen"
	component = Generator {
		pathRtProject = runtimeProject
		pathUiProject = "${runtimeProject}.ui"
		projectNameRt = projectName
		projectNameUi = "${projectName}.ui"
		language = {
			uri = grammarURI
			fileExtensions = file.extensions
			// Java API to access grammar elements (required by several other fragments)
			fragment = grammarAccess.GrammarAccessFragment {}
			// generates Java API for the generated EPackages
			fragment = ecore.EcoreGeneratorFragment {
			// referencedGenModels = "uri to genmodel, uri to next genmodel"
			// the serialization component
			fragment = parseTreeConstructor.ParseTreeConstructorFragment {}
			// a custom ResourceFactory for use with EMF
			fragment = resourceFactory.ResourceFactoryFragment {
			// The antlr parser generator fragment.
//			fragment = parser.antlr.XtextAntlrGeneratorFragment {
//			  	options = {
//			//		backtrack = true
			fragment = parser.antlr.ex.rt.AntlrGeneratorFragment {
				options = {
					ignoreCase = true
			// java-based API for validation
			fragment = validation.JavaValidatorFragment {
				composedCheck = "org.eclipse.xtext.validation.ImportUriValidator"
				composedCheck = "org.eclipse.xtext.validation.NamesAreUniqueValidator"
				// registerForImportedPackages = true
			// scoping and exporting API
			 fragment = scoping.ImportURIScopingFragment {
			 	ignoreCase = true
			 fragment = exporting.SimpleNamesFragment {}
//			fragment = scoping.ImportNamespacesScopingFragment {}
//			fragment = exporting.QualifiedNamesFragment {}
//			fragment = builder.BuilderIntegrationFragment {}
			// formatter API
			fragment = formatting.FormatterFragment {}
			// labeling API
			fragment = labeling.LabelProviderFragment {}
			// outline API
			fragment = outline.TransformerFragment {}
			fragment = outline.OutlineNodeAdapterFactoryFragment {}
			fragment = outline.QuickOutlineFragment {}
			// quickfix API
			fragment = quickfix.QuickfixProviderFragment {}
			// content assist API
			fragment = contentAssist.JavaBasedContentAssistFragment {}
			// generates a more lightweight Antlr parser and lexer tailored for content assist
//			fragment = parser.antlr.XtextAntlrUiGeneratorFragment {
			fragment = org.eclipse.xtext.generator.parser.antlr.ex.ca.ContentAssistParserGeneratorFragment{
					options = {
					ignoreCase = true
			// project wizard (optional)
			// fragment = projectWizard.SimpleProjectWizardFragment {
			// 		generatorProjectName = "${projectName}.generator"
			//		modelFileExtension = file.extensions
I create a workaround using scopeProvider and resolving EObjectDescription in the ProposalProvider, but i think it exists an easier way. Does someone know the solution ?
P. Palau
Re: (XText 1.0) importUri and ProposalProvider [message #789291 is a reply to message #787997] Thu, 02 February 2012 15:24 Go to previous messageGo to next message
you have basically these options
(1) resolve the proxy (which might be slow and you have to overwrite all the stuff up to org.eclipse.xtext.ui.editor.contentassist.AbstractJavaBasedContentProposalProvider.DefaultProposalCreator.apply(IEObjectDescription)
where you have access to the context which gives you an model object you can resolve against)
(2) enrich the IEObjectDescriptions with the Information you need (which might be painful since you have to provide a custom IResourceDescription.Manager)
~Christian
Re: (XText 1.0) importUri and ProposalProvider [message #808241 is a reply to message #787997] Mon, 27 February 2012 10:14 Go to previous message
Hi Christian,
Thanks for your help.
I'm sorry, i did not receive (or saw) notification about your post and just found it yesterday.
I used resolve proxy, it's slow but it works. I created generic behaviour in the ProposalProvider to resolve crossref using ScopeProvider (maybe it's not a good thing). I put the code, it could help some users.
public class GvbscriptProposalProvider extends AbstractGvbscriptProposalProvider {
	@Inject
	IScopeProvider scopeProvider;
	public void completeAssignment(Assignment assignment, ContentAssistContext contentAssistContext, ICompletionProposalAcceptor acceptor) {
		//when assignment is a crossreference
		if(CrossReference.class.isAssignableFrom(assignment.getTerminal().getClass())){
			CrossReference crossReference = (CrossReference)assignment.getTerminal();
			ParserRule containingParserRule = GrammarUtil.containingParserRule(crossReference);
			if (!GrammarUtil.isDatatypeRule(containingParserRule)) {
				//Look for complete method override
				boolean existsMethodOverride;
				try {
					String methodName = "complete" + Strings.toFirstUpper(containingParserRule.getName()) + "_" + Strings.toFirstUpper(assignment.getFeature());
					Method completeMethod = this.getClass().getMethod(methodName, EObject.class, Assignment.class, ContentAssistContext.class, ICompletionProposalAcceptor.class);
					existsMethodOverride = (completeMethod.getDeclaringClass().equals(this.getClass()));
				} catch (Exception e) {
					existsMethodOverride = false;
				//No complete method override, Use generic complete method for crossReference
				if(!existsMethodOverride){
					completeUsingScopeProvider(crossReference, contentAssistContext, acceptor);
		//Use standard base method.
		super.completeAssignment(assignment, contentAssistContext, acceptor);
// Custom complete methods override ...
	 * Create proposal with scope provider
	 * @param crossReference
	 * @param contentAssistContext
	 * @param acceptor
	protected void completeUsingScopeProvider(CrossReference crossReference, ContentAssistContext contentAssistContext,
		EReference target = GrammarUtil.getReference(crossReference);
		if(target == null){
			return;
		//Request elements to the scope provider
		EObject currentModelElement = contentAssistContext.getCurrentModel();
		IScope scope = scopeProvider.getScope(currentModelElement, target);
		for (IEObjectDescription scopeElement : scope.getAllContents()) {
			//Get element and resolve proxy if needed
			EObject object = scopeElement.getEObjectOrProxy();
			if (object.eIsProxy()) {
				object = EcoreUtil.resolve(object, currentModelElement.eResource());
			//Create new proposal
			String label = getLabelProvider().getText(object);
			if(label == null || label.equals("")){
				label = scopeElement.getName();
			ICompletionProposal completionProposal = createCompletionProposal(scopeElement.getName(),
					getLabelProvider().getText(object), null, contentAssistContext);
			//Register proposal
			acceptor.accept(completionProposal);
Thanks Again.
P. Palau
Previous Topic:help with Xdoc
Next Topic:cross references and name spaces
Current Time: Sat Jul 19 19:15:01 EDT 2025
Powered by FUDForum. Page generated in 0.03846 seconds
