[ATL] uml2wsdl [message #80678] |
Mon, 05 May 2008 06:00  |
Originally posted by: hr_mi.live.cn
Hi everybody,
I want to make a transformation from uml to wsdl , now my problem is
that it doesn't make a nesting.
My code is as following :
--@atlcompiler atl2006
module onlinesale_merge2wsdl; -- Module Template
create OUT : WSDL from IN :UML;
helper context UML!Class def: hasStereotype(stereotype :
String) : Boolean =
self.getAppliedStereotypes()->exists (c | c.name = stereotype);
helper context UML!Package def : getElementbyStereotypeName(stereotype :
String) : Set(UML!Class)=
self.packedElement->select(c|c.oclIsKindOf(UML!Class) and
c.hasStereotype(stereotype));
helper context UML!Class def : getAttr() : Sequence(UML!Property)=
self.ownedAttribute->collect();
rule Definition{
from c : UML!Package(c.oclIsTypeOf(UML!Package) and
c.name='Class Package')
to d :WSDL!Definition(
targetNamespace <-'edu.xidian.ictt.webservices.bpelmodeling.wsdl',
eTypes <- c.getElementbyStereotypeName('Data'),
eMessages <- c.getElementbyStereotypeName('Message'),
ePortTypes <- c.getElementbySterotypeName('PortType')
rule Class2Message{
from u : UML!Class(
u.hasStereotype('Message')
to t : WSDL!Message(
qName <- u.name,
eParts <- u.getAttr()
But I just get the result as following :
<?xml version="1.0" encoding="ISO-8859-1"?>
<wsdl:Definition xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:wsdl="http://www.eclipse.org/wsdl/2003/WSDL"/>
I can't find where it is wrong . Who can help me ??
Best regrads
Re: [ATL] uml2wsdl [message #81038 is a reply to message #80785] |
Wed, 07 May 2008 22:27  |
William Piers 写道:
> Hello,
> unique a écrit :
>> Hi everybody,
>> String) : Boolean =
>> rule Definition{
>> rule Class2Message{
>> from u : UML!Class(
>> qName <- u.name,
> The transformation may have fail. Do you check the error log ?
> Best regards,
> William
>> Best regrads
Hi William ,
Thanks for your attention. Now I rework my code as followiong:
create OUT : WSDL from IN : UML;
helper context UML!Class def: hasStereotype(stereotype : String)
:Boolean =
self.getAppliedStereotypes()->collect(e|e.name)->includes(stereotype);
helper context UML!Package def : getClassbyStereotypeName(stereotype :
self.packagedElement->select(c|c.oclIsKindOf(UML!Class) and
rule Definition{
targetNamespace <- 'edu.xidian.ictt.webservices.bpelmodeling.wsdl',
eTypes <- type
type : WSDL!Types(
schema <- schem
schem : WSDL!XSDSchema(
targetNamespace <- 'edu.xidian.ictt.webservices.bpelmodeling.xsd',
elementDeclarations <- c.getClassbyStereotypeName('Data')
Now I have the following result:
<xmi:XMI xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:xsd="http://www.eclipse.org/xsd/2002/XSD">
<wsdl:Definition/>
<wsdl:Types/>
<xsd:XSDSchema/>
</xmi:XMI>
But the correct result should be as following :
<wsdl:Definition>
<wsdl:Types>
<wsdl:XSDSchema/>
</wsdl:Types>
</wsdl:Defintion>
It still have no nesting. And it is also have no error log.
Would you please check my code ??
Best regards
FUDForum. Page generated in 0.06936 seconds
