Home » Eclipse Projects » Memory Analyzer » J2RE 1.3.1 IBM AIX build ca131-20030618 DUMP(How to parse IBM 1.3.1 for MAT)
J2RE 1.3.1 IBM AIX build ca131-20030618 DUMP [message #797481] Mon, 13 February 2012 09:45 Go to next message
Thks for MAT ! a very helpfull tool.
Now, I have got several heapdumps from Websphere running on a J2RE 1.3.1 IBM AIX build ca131-20030618. Would be great if I could use MAT to analyse them. But as I understand, it seems that under 1.4 this is not possible.
Is the format as different ? No way to have a tool to parse this kind of dumps so that they could be recognized by MAT ?
Thks a lot.
Re: J2RE 1.3.1 IBM AIX build ca131-20030618 DUMP [message #798866 is a reply to message #797481] Wed, 15 February 2012 01:56 Go to previous messageGo to next message
I think the heapdumps produced by j2re 1.3.1 is text heapdump. you can use try ibm heap analyzer for that. I think MAT works with dtfj.
Re: J2RE 1.3.1 IBM AIX build ca131-20030618 DUMP [message #806149 is a reply to message #798866] Fri, 24 February 2012 10:53 Go to previous messageGo to next message
thks for your reply.
Yes, it is in txt form.
// Version: J2RE 1.3.1 IBM AIX build ca131-20030618
0x30030200 [16] primitive array
0x30030210 [256] class com/ibm/websphere/models/config/appdeployment/DeploymentTarget...
But, ibm heap analyzer is more difficult to interpret that MAT !
Re: J2RE 1.3.1 IBM AIX build ca131-20030618 DUMP [message #808453 is a reply to message #806149] Mon, 27 February 2012 15:03 Go to previous messageGo to next message
Those versions of Java and WebSphere Application Server are too old to be of much interest.
http://www.ibm.com/developerworks/java/jdk/aix/outofservice.html
Java 1.3.1 and earlier releases
These releases are no longer available. Customers are strongly advised to move to a supported version of Java.
http://www-01.ibm.com/support/docview.wss?uid=swg27004980#ver50
Support for releases of IBM WebSphere Application Server V5.1 has been withdrawn on 30 September 2008
V5.0 Support notice
WebSphere Application Server Version 5.0 is now out of support. New APARs will NOT be opened. IBM recommends that you upgrade to V5.0.2.18.
Re: J2RE 1.3.1 IBM AIX build ca131-20030618 DUMP [message #810857 is a reply to message #808453] Thu, 01 March 2012 11:10 Go to previous message
Yes, of course I know that ;o)
But, sometimes you have got some nice old projects going on running such very old versions (old applications that will never be re-writen for example)
So, as I understand, there is definively no hope.
Thks anyway.
Previous Topic:Identify list of jar files loaded by a classloader
Next Topic:OQL Find all objects which belong to a HttpSession
Current Time: Sat Jul 19 16:32:46 EDT 2025
Powered by FUDForum. Page generated in 0.50878 seconds
