Home » Modeling » EMF » [Xcore] invoking constructor for Data Type
[Xcore] invoking constructor for Data Type [message #801028] Fri, 17 February 2012 15:46 Go to next message
Next problem Smile
Using xcore I defined a domain model which I edit using the reflective editor for testing purposes. The domain model contains a defined data type similiar to the Date data type found in the small example by Ed Merks.
However if I define my own data type which resides in x.y.z.util (same project,just the src and not the srcgen folder), everytime I enter a value in the reflective editor I get an exception IllegalStateException: could not invoke Constructor MyType(String). Of course it has a public constructor with a String parameter. I also tried to use a static method (same problem) and to be exactly like the Date example I added a class which constructs the datatype, but I never can invoke any methods.
the datatype is also listed among the resources when I open reflective editor, so it seems to be "known".
Any ideas?
Markus
Re: [Xcore] invoking constructor for Data Type [message #801320 is a reply to message #801028] Sat, 18 February 2012 02:13 Go to previous messageGo to next message
Markus,
Comments below.
On 17/02/2012 9:46 PM, Markus Klink wrote:
> Next problem :)
> Merks.
The class loader in the running IDE itself would need to be able to find
the class so if it's only in your workspace, you can't use it in the
IDE's reflective editor.
Is there something in the resource?
I can't think of a good way to make this even more flexible. The class
does need to be loaded, so we'd need to be able to load classes that are
only in the workspace...
> Any ideas?
> Markus
Re: [Xcore] invoking constructor for Data Type [message #801478 is a reply to message #801320] Sat, 18 February 2012 08:00 Go to previous messageGo to next message
I can't get it to run unfortunately. I stripped down the model to a barebones sample and now it even crashes when I try to enter a value into the reflective editor. this is my xcore file:
package x.y.z
import x.y.z.util.Test
import java.util.Date
import java.text.SimpleDateFormat
class SomeClass {
Test something
Date date
type Date wraps Date
create {
try {
new SimpleDateFormat("yyyy-MM-dd").parse(it)
} catch (Exception e) {
throw new RuntimeException(e)
convert {
new SimpleDateFormat("yyyy-MM-dd").format(it)
type Test wraps Test
create {
new Test(it)
convert {
it.toString
In the src folder I have the class x.y.z.util.Test
package x.y.z.util;
public class Test {
private String text;
public Test(String text) {
this.text = text;
public String toString() {
return text;
I create a dynamic instance of SomeClass and view it in the reflective editor. I see the do fields, but neither in the Date nor in the test field I can enter something. If I do I see the spinning wheel of death and have to shutdown eclipse. I guess I am doing something really stupid which I am missing, or maybe the combinations of my plugins does not cut it? If I can provide any other kind of debug information, please let me know.
Re: [Xcore] invoking constructor for Data Type [message #801487 is a reply to message #801478] Sat, 18 February 2012 08:23 Go to previous messageGo to next message
Appendum: it works when I just create the model programmatically and serialize/deserialize the Resource. I guess, I am doing something wrong with the reflective editor.
Re: [Xcore] invoking constructor for Data Type [message #802599 is a reply to message #801478] Mon, 20 February 2012 01:44 Go to previous message
Markus,
Comments below.
> package x.y.z
> class SomeClass {
> Test something
> Date date
> type Date wraps Date create {
> try {
> convert {
> create {
> new Test(it)
> convert {
> it.toString
> package x.y.z.util;
> public class Test {
> this.text = text;
> @Override
> return text;
I mentioned already that classes not actually installed in the
already-running IDE will not work in the reflective editor, so I don't
expect Test to work. Perhaps in the future we can play class loader
games (as I've done with dynamic JET templates), but that's not a
priority...
If I try the above, the stack trace from the error log is quite informative:
at java.util.Calendar.setTime(Calendar.java:1106)
at java.text.SimpleDateFormat.format(SimpleDateFormat.java:955)
at java.text.SimpleDateFormat.format(SimpleDateFormat.java:948)
at java.text.DateFormat.format(DateFormat.java:336)
That makes it clear that the case of "it" being null isn't handled.
That is the danger of running things in the IDE process itself. Rogue
behavior can kill the process.
Overlooked handling null and expecting data types to work reflectively
for classes not reflectively accessible in the IDE...
> let me know.
When things go wrong, be sure to check the Error Log view for causes.
Previous Topic:[Xcore] specifying GenModel annotations
Next Topic:[CDO] preferred DBStore DB vendor.
Current Time: Sun Nov 02 07:06:19 EST 2025
Powered by FUDForum. Page generated in 0.03890 seconds
