Home » Modeling » M2T (model-to-text transformation) » [Acceleo] running an installed module from workbench
[Acceleo] running an installed module from workbench [message #800565] Fri, 17 February 2012 03:21 Go to next message
when you develop some acceleo module in your workspace, you may test it with a Acceleo Launch configuration.
Then, when you export the Acceleo project as plugin, and install it in another eclipse, you may run it with java call from one another plugin project.
But there is no more way of launching the installed module from an Acceleo launch configuration (since it requires some project/class from workspace).
Did you think about a way for offering to launch an installed acceleo module (may be based on some additional extension point) directly from a workbench menu/action/... ?
Fabien.
Re: [Acceleo] running an installed module from workbench [message #800774 is a reply to message #800565] Fri, 17 February 2012 08:31 Go to previous message
This feature has already been requested, I think it would be a nice addition. In the mean time, if you want to have a launch configuration for your generator, you can fork the code that I have in this project: https://github.com/ObeoNetwork/UML-Java-Generation/tree/master/plugins/org.obeonetwork.pim.uml2.gen.java.ui
I have created, as a prototype, a launch configuration for an Acceleo UI plugin and its a feature that I would like in Acceleo too. I don't have any more information on this since I have not worked on such feature inside of Acceleo but if I can find some time it would be a welcomed addition.
Stephane Begaudeau, Leader of Acceleo
Twitter: @sbegaudeau & @acceleo
Google+: stephane.begaudeau & acceleo
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Previous Topic:Errors in XPAND
Next Topic:[Acceleo] Launch a transformation by code
Current Time: Sun Jul 20 09:38:32 EDT 2025
Powered by FUDForum. Page generated in 0.03658 seconds
