Updating eclipse 3.7.1 [message #800622] |
Fri, 17 February 2012 04:35  |
I downloaded eclipse classic 3.7.1.
The first thing I tried to do is to check for updates, it seems to start doing it but at some point the progress bat stalls until I receive the following error:
Unable to read repository at download.eclipse.org/releases/indigo/201109230900/content.jar.
Read timed out
When I tried to install a Scala plugin, I selected the relevant components, and clicked on Next... eclipse waited for some time and again I receive the above error (I don't understand why as it is not part of Scala urls).
I read several links but everything I did, lead to nothing. Then I saw the following link: bugs.eclipse.org/bugs/show_bug.cgi?id=362741 , it describes the exact same problem. The only thing I didn't understand is the last comment about java.util.Arrays.useLegacyMergeSort=true - I didn't understand where to set it exactly.
Notice that the connection is established and the progress bar progresses, but at some point it just stuck until the read time out error appears... Please help
Thanks!
Re: Updating eclipse 3.7.1 [message #800764 is a reply to message #800698] |
Fri, 17 February 2012 08:13  |
On 2012.02.17 4:17, amos sz wrote:
> I already had 6.30 and 7 update 1 installed, so I simply uninstalled 7
> update 1 and now it works ok, thanks a lot
> Will there be a fix soon, for this problem with 7?
You didn't need to uninstall Java 7, just download Java 6 and point
Eclipse at it instead of at Java 7.
FUDForum. Page generated in 0.45167 seconds
