Home » Newcomers » Newcomers » Installing Eclipes second time
icon5.gif  Installing Eclipes second time [message #800047] Thu, 16 February 2012 11:16 Go to next message
can anyone guide me how to fix this issue that i have facing to install eclipes second time I have my java is installed in "c:\java"
index.php/fa/7184/0/
index.php/fa/7185/0/
index.php/fa/7186/0/
  • Attachment: 1.JPG
    (Size: 17.20KB, Downloaded 348 times)
  • Attachment: 2.JPG
    (Size: 64.22KB, Downloaded 360 times)
  • Attachment: 3.JPG
    (Size: 22.96KB, Downloaded 323 times)
[Updated on: Thu, 16 February 2012 11:17] by Moderator
Re: Installing Eclipes second time [message #800122 is a reply to message #800047] Thu, 16 February 2012 13:04 Go to previous messageGo to next message
My advice would be to download a proper JDK or (at least) JRE from Sun
rather than the C:\Windows\SYSTEM32\javaw.exe.
I would also ensure that the bittedness of the JRE you do use match that
of the Eclipse you downloaded, i.e.: 32 for 32 or 64 for 64.
Hope this helps.
Re: Installing Eclipes second time [message #800139 is a reply to message #800122] Thu, 16 February 2012 13:47 Go to previous messageGo to next message
I have already download java and its work. For now I am using notepad to write java code then i am using cmd to run java
index.php/fa/7189/0/
  • Attachment: 4.jpg
    (Size: 108.74KB, Downloaded 331 times)
Re: Installing Eclipes second time [message #800145 is a reply to message #800139] Thu, 16 February 2012 13:57 Go to previous messageGo to next message
This is how i am testing for now
index.php/fa/7190/0/
  • Attachment: 5.JPG
    (Size: 46.71KB, Downloaded 292 times)
Re: Installing Eclipes second time [message #800219 is a reply to message #800145] Thu, 16 February 2012 15:42 Go to previous messageGo to next message
Okay, that's good. We all thought you were trying to use Eclipse since
you posted questions in an Eclipse forum.
Best of luck.
Re: Installing Eclipes second time [message #800225 is a reply to message #800219] Thu, 16 February 2012 15:54 Go to previous messageGo to next message
wait but to make eclipes work coz i have have the same error every time i try to run eclipes
Re: Installing Eclipes second time [message #800229 is a reply to message #800225] Thu, 16 February 2012 16:00 Go to previous messageGo to next message
You need to tell Eclipse where the JDK is located using either the -vm argument on the command line or editing the eclipse.ini file to include the entries to point to the jdk. There are a number of posts in the forums with details on both methods.
Re: Installing Eclipes second time [message #800236 is a reply to message #800225] Thu, 16 February 2012 16:07 Go to previous messageGo to next message
If you come to this forum, you should take our advice.
C:\Windows\SYSTEM32\javaw.exe is not a proper JRE for running Eclipse
even though you've put it into eclipse.ini. Please download a JRE of the
proper bittedness from http://java.sun.com, install it, then tell
Eclipse where it is via what's in http://wiki.eclipse.org/Eclipse.ini .
Then come back if you have further questions.
Re: Installing Eclipes second time [message #800750 is a reply to message #800236] Fri, 17 February 2012 07:49 Go to previous message
Thanks for your help it finally worked and now i can use eclipes .....
Previous Topic:Remote debugging , connetion refused !!
Next Topic:Updating eclipse 3.7.1
Current Time: Sun Jul 20 13:13:28 EDT 2025
Powered by FUDForum. Page generated in 0.12505 seconds
