Home » Archived » BIRT » Can't startup the OSGI fr
Can't startup the OSGI fr [message #220478] Thu, 22 February 2007 11:23 Go to next message
Hi all,
- I installed the ReportEngine under
C:\Devel\birt-runtime-2_1_1\ReportEngine
- I set BIRT_HOME to C:\Devel\birt-runtime-2_1_1\ReportEngine\
- I added itext-1.3.jar under
C:\Devel\birt-runtime-2_1_1\ReportEngine\plugins\com.lowagie .itext\lib
I'm using eclipse, I created a test project with a main class that call a
method that tries to convert a report to pdf format but I have the
following exception:
org.eclipse.birt.core.exception.BirtException: $NO-RB$ Can't startup the
OSGI framework
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:90)
at hplus.webapp.birt.Exporting.export(Exporting.java:36)
at hplus.webapp.birt.Exporting.main(Exporting.java:23)
Caused by: org.eclipse.birt.core.exception.BirtException: $NO-RB$ Could
not start the Framework - {0}C:\Develirt-runtime-2_1_1\ReportEngine\
at
org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OS GILauncher.java:44)
at org.eclipse.birt.core.framework.Platform.startup(Platform.ja va:78)
... 2 more
I've red a lot of posts of many peoples with the same problems but i
couldn't solve the problem. Can you help me? Tnx in advance.
Ciao Gabriele
Re: Can't startup the OSGI fr [message #220487 is a reply to message #220478] Thu, 22 February 2007 11:29 Go to previous messageGo to next message
sorry for the double post
Re: Can't startup the OSGI fr [message #220492 is a reply to message #220478] Thu, 22 February 2007 11:47 Go to previous messageGo to next message
Originally posted by: martin.tauber.t-online.de
Gabriele,
do you have all the jars from the reportengine/lib directory in your
classpath?
Martin
P.S. If your using eclipse select the "run ..." action goto your java
application and select the classpath tab. then press add external jars
and navigate to the reportengine/lib directory and select all the jars
in that directory.
Gabriele schrieb:
> Hi all, - I installed the ReportEngine under
> a method that tries to convert a report to pdf format but I have the
> OSGI framework
> at
> ... 2 more
> Ciao Gabriele
Re: Can't startup the OSGI fr [message #220510 is a reply to message #220478] Thu, 22 February 2007 13:31 Go to previous messageGo to next message
Originally posted by: home4slc.pacbell.net
Hi Gabriele,
This may just be a cut and paste error, but it appears that the value
you think you have BIRT_HOME set to and what it is actually set to
according to the stack trace are different.
It looks like there is a missing '\b' in the BIRT_HOME path.
Susan
> OSGI framework
> at
> ... 2 more
> Ciao Gabriele
Re: Can't startup the OSGI fr [message #220657 is a reply to message #220510] Fri, 23 February 2007 04:15 Go to previous messageGo to next message
Hi Susan, hi Martin. At first thanks a lot for your answers, but I didn't
solve the problem.
In the Java Build Path of my projects I added all the external jars from
the lib "C:\Devel\birt-runtime-2_1_1\ReportEngine\lib" do I have to do
something more Martin?
Moreover I set the EV to, is that right Susan?
BIRT_HOME = C:\Devel\birt-runtime-2_1_1\ReportEngine
BIRT_LIB = %BIRT_HOME%\lib
BIRTCLASSPATH =
%BIRT_LIB%\com.ibm.icu_3.4.4.1.jar;%BIRT_LIB%\commons-cli-1. 0.jar;%BIRT_LIB%\commons-codec-1.3.jar;%BIRT_LIB%\coreapi.ja r;%BIRT_LIB%\dataadapterapi.jar;%BIRT_LIB%\dteapi.jar;%BIRT_ LIB%\engineapi.jar;%BIRT_LIB%\flute.jar;%BIRT_LIB%\js.jar;%B IRT_LIB%\modelapi.jar;%BIRT_LIB%\org.eclipse.emf.common_2.2. 0.v200606051102.jar;%BIRT_LIB%\org.eclipse.emf.ecore.xmi_2.2 .0.v200606051102.jar;%BIRT_LIB%\org.eclipse.emf.ecore_2.2.0. v200606051102.jar;%BIRT_LIB%\sac.jar;%BIRT_LIB%\scriptapi.ja r
CLASSPATH = %BIRTCLASSPATH% (and all the other dirs)
PATH = %BIRT_HOME% (and all the other dirs)
Re: Can't startup the OSGI fr [message #798976 is a reply to message #220657] Wed, 15 February 2012 04:47 Go to previous messageGo to next message
Hi friends,
Am also having this issue. Please someone help me to solve this issue.
I'm new to eclipse BIRT.
The project is configured successfully. And i can view the index page also.
But when i hit ".../run?__report=report/demoReport.rptdesign"
it showing
"+ Cant startup the OSGI framework" ..
Please some one help me to resolve this issue.
Thanks in Advance.
[Updated on: Wed, 15 February 2012 07:09] by Moderator
Re: Can't startup the OSGI fr [message #799272 is a reply to message #798976] Wed, 15 February 2012 12:20 Go to previous messageGo to next message
What version of BIRT are you using? How do you want to deploy it (
using the viewer or report engine API)?
Jason
On 2/15/2012 4:47 AM, suganya govindaraj wrote:
> Hi friends,
> I'm new to eclipse BIRT. I don't know how to include
> "birt-runtime/ReportEngine/lib" into my project.
> When i try to run my project, It showing SEVERE Error listenerStart in
> tomcat. In web.xml, <context-param>
> <param-name>BIRT_VIEWER_CONFIG_FILE</param-name>
> <param-value>/WEB-INF/viewer.properties</param-value>
> </context-param>
> <listener>
> <listener-class>org.eclipse.birt.report.listener.ViewerServletContextListener</listener-class>
> </listener>
> I included these lines. So that only am getting error likewise...
> If i stop tomcat. And copied the "jar" files from
> birt-runtime/WebViewerExample/WEB-INF/lib into
> tomcat/webapps/sampleProject/WEB-INF/lib
> But when i hit ".../run?__report=report/demoReport.rptdesign" it showing
> Thanks in Advance.
Re: Can't startup the OSGI fr [message #799916 is a reply to message #799272] Thu, 16 February 2012 08:17 Go to previous messageGo to next message
At first, thanks for your reply.
Am using BIRT version 2.6.2..
Actually I want to view my BIRT report in jsp file.
But it showing "+ Cant startup the OSGI framework" ..
My jsp file is
<%@ taglib uri="/WEB-INF/birt.tld" prefix="birt" %>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
</head>
<body>
<birt:viewer id="birtViewer"
reportDesign="sample.rptdesign"
pattern="frameset"
height="600"
width="800"
format="html"
title="My Viewer Tag"
showTitle="true"
showToolBar="true"
showNavigationBar="true">
</birt:viewer>
</body>
</html>
Why am getting Can't startup the OSGI framework error.
Re: Can't startup the OSGI fr [message #800189 is a reply to message #799916] Thu, 16 February 2012 14:56 Go to previous messageGo to next message
Try copying the WebViewerExample folder to your app server. For example
with tomcat put it in the webapps directory. Rename it to birt.
Then copy the jsp file you created to the birt directory.
Start app server and enter the url
http://localhost:8080/birt/yourjsppage.jsp
Jason
On 2/16/2012 8:17 AM, suganya govindaraj wrote:
> My jsp file is
> <html>
> <head>
> </head>
> <body>
> pattern="frameset"
> height="600"
> width="800"
> format="html"
> showTitle="true"
> showToolBar="true"
> </birt:viewer>
> </body>
> </html>
Re: Can't startup the OSGI fr [message #804179 is a reply to message #800189] Wed, 22 February 2012 04:43 Go to previous messageGo to next message
Ya I copied WebViewerExample folder and renamed as birt in my webapps. Within that i copied my jsp file and rptdesign file both are working fine.
But I created a new Project(birtdemo) in Eclipse. When i executing that,
http://localhost:8080/birtdemo/sample.jsp
It showing
And when i try to hit
http://localhost:8080/birtdemo/report/sample.rptdesign
It showing
HTTP Status 404 - Not Found Network Error
I don't know where was the problem..
[Updated on: Wed, 22 February 2012 04:45] by Moderator
Re: Can't startup the OSGI fr [message #804406 is a reply to message #804179] Wed, 22 February 2012 10:32 Go to previous messageGo to next message
You might want to look at using the WTP Integration package for BIRT.
It is located on the full downloads page:
http://download.eclipse.org/birt/downloads/build.php?build=R-R1-3_7_1-201109131734
Look for BIRT Web Tools Integration. Download the zip and extract into
your Eclipse install. This will make a Configuration available under
new web project named BIRT Reporting Web Project. Take a look at the
screen shots in this post:
http://www.birt-exchange.org/org/forum/index.php/topic/18337-installing-birt-wtp-integration-sdk-2-5-1-in-eclipse-reporting-galileo-2-5-1/page__s__4fa567b4dd6fd90f6987b617252b7b72
Jason
> Jason
> It showing Can't startup the OSGI framework
> It showing
> I dont know where was the problem..
Re: Can't startup the OSGI fr [message #804902 is a reply to message #804406] Thu, 23 February 2012 00:53 Go to previous messageGo to next message
Hi Jason,
I downloaded "birt-wtp-integration-sdk-3_7_1.zip", copied into eclipse. and extracted into the eclipse (installed location. In my case D:\Progs\eclipse)..
And I created new dynamic web project http://www.birt-exchange.org/org/forum/index.php/topic/18337-installing-birt-wtp-integration-sdk-2-5-1-in-eclipse-reporting-galileo-2-5-1/page__s__4fa567b4dd6fd90f6987b617252b7b72 as you mentioned in this post. Then copied my "old source" into this new project.
But the Exception is not cleared. It still showing "Can't startup OSGI framework".
My Tomcat exception is,
org.eclipse.birt.core.exception.BirtException: Can't startup the OSGI framework
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:91)
at org.eclipse.birt.report.service.ReportEngineService.setEngineContext(
ReportEngineService.java:320)
at org.eclipse.birt.report.service.BirtViewerReportService.setContext(Bi
rtViewerReportService.java:1022)
at org.eclipse.birt.report.servlet.ViewerServlet.__getContext(ViewerServ
let.java:148)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.doPo
st(BirtSoapMessageDispatcherServlet.java:243)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)
at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBas
e.java:327)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherServlet.serv
ice(BirtSoapMessageDispatcherServlet.java:122)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl
icationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationF
ilterChain.java:206)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(ViewerFilter.jav
a:68)
icationFilterChain.java:235)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperV
alve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextV
alve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.j
ava:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.j
ava:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineVal
ve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.jav
a:293)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java
:849)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.proce
ss(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:45
4)
at java.lang.Thread.run(Thread.java:662)
Caused by: org.eclipse.birt.core.exception.CoreException
at org.eclipse.birt.core.framework.osgi.OSGILauncher.startup(OSGILaunche
r.java:90)
at org.eclipse.birt.core.framework.Platform.startup(Platform.java:79)
... 23 more
And I'm having one more doubt. "platform" folder is required within ...\webapps\(mysampleproject)\WEB-INF\....
Re: Can't startup the OSGI fr [message #805435 is a reply to message #804902] Thu, 23 February 2012 14:14 Go to previous messageGo to next message
If you are using BIRT 3.7 or greater you should not have a platform
directory underneath WEB-INF. Without your customizations does the
default birt web project run?
Jason
On 2/23/2012 12:53 AM, suganya govindaraj wrote:
> Hi Jason,
> D:\Progs\eclipse)..
> project.
> framework".
> framework
> let.java:148)
> e.java:327)
> a:68)
> alve.java:233)
> alve.java:191)
> ava:128)
> ava:102)
> ve.java:109)
> a:293)
> :849)
> 4)
> r.java:90)
> ... 23 more
Re: Can't startup the OSGI fr [message #805744 is a reply to message #805435] Thu, 23 February 2012 23:48 Go to previous message
No, It showing exception.
org.eclipse.birt.core.exception.BirtException: Can't startup the OSGI framework.
I have a platform directory underneath WEB-INF. If i deleted means also it showing this exception.
Suganya
Previous Topic:Dynamic Parameter with Scripted Data Set
Next Topic:How to Make Reports Attractive
Current Time: Sat Jul 19 13:55:49 EDT 2025
Powered by FUDForum. Page generated in 0.06268 seconds
