Re: Agent Controller setup [message #79855 is a reply to message #79781] |
Thu, 03 August 2006 14:03  |
Veny wrote:
> Thanks for your reply.
> I've downloaded the IA version too, but does not seems to work properly.
Symptoms/results? What did you see to say it's not working correctly?
> On windows, what should i check on to decide which version of the agent
> controller i should be using? How about on Linux?
On Windows, Right-click on My Computer => Properties and see what System
it says... My EM64T system says "Microsoft Windows Server 2003
Enterprise x64 Edition Service Pack 1" ... I use agntctrl.win_em64t
downloads there; my Itanium system says "Microsoft Windows Server 2003
Enterprise Edition Service Pack 1" ... I use agntctrl.win_ipf downloads
there; and my laptop says "Microsoft Windows XP Professional Version
2002 Service Pack 2" ... I use agntctrl.win_ia32 downloads there.
I think the ia32 version will work on both of the other systems, but you
have to be careful the "environment" you run it in (making sure not to
mix with "native" 64-bit code on those systems).
Linux -- uname -m should give you the info you need. i686 => Linux-IA32,
ia64 => Linux-IPF, and x86_64 => Linux-EM64T.
> Also i've extracted the main TPTP package into eclipse installation. But
> does not seem to find the new plugin. When i go to File -> New -> Other,
> there is no 'Test' menu shown. How do i check what i've configured
> wrongly? Or is there any dependency on other eclipse plugin and its
> version?
Extracted into the eclipse installation? That's SO pre-Callisto! :-) The
Update Manager is your FRIEND!!
If you've done this, I expect you didn't read the download page's
Requirements list, right? Before TPTP will work, you'd need EMF&XSD
installed into your Eclipse installation as well.
Better to (1) Get Eclipse (platform runtime or SDK or Eclipse SDK) and
then use the Help => Software Updates => Find and Install... and go to
the Callisto Discovery Site, select TPTP and "Select Required" to get
Requirements met.
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
FUDForum. Page generated in 0.03814 seconds
