Home » Eclipse Projects » Memory Analyzer » MAT on Linux(Running MAT on Linux)
icon5.gif  MAT on Linux [message #791679] Mon, 06 February 2012 00:55 Go to next message
I ran eclipse memory analyzer on Linux (Linux serverName 2.6.18-194.11.3.el5 #1 SMP Mon Aug 23 15:51:38 EDT 2010 x86_64 x86_64 x86_64 GNU/Linux)
using using below command
jdk1.6.0_24/bin/java -XX:MaxNewSize=512m -Xmx7168m -XX:MaxPermSize=512m -XX:+PrintGCDetails -XX:+PrintGCTimeStamps -verbose:gc -XX:-UseGCOverheadLimit -jar plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar -consoleLog -application org.eclipse.mat.api.parse ../java_pid98178.hprof
And it created below files for java_pid98178.hprof (2.5GB file)
java_pid98178.idx.index
java_pid98178.o2c.index
java_pid98178.a2s.index
java_pid98178.inbound.index
java_pid98178.outbound.index
java_pid98178.o2hprof.index
java_pid98178.index
java_pid98178.domIn.index
java_pid98178.o2ret.index
java_pid98178.domOut.index
Now, how can I analyze the files in graphic mode like in Windows on LInux. I am using Putty from my Windows laptop and I have Xwindows too.
I have exported DISPLAY variable and ran Xwindows on my laptop. Then ran ./MemoryAnalyzer, but no luck.
GV
[Updated on: Mon, 06 February 2012 01:00] by Moderator
Re: MAT on Linux [message #795999 is a reply to message #791679] Sat, 11 February 2012 02:52 Go to previous messageGo to next message
There shouldnt be any difference to how you run MAT compared to Eclipse or other GUI software. It should be enough to export the display. I can't tell what is going wrong.
May be if this doesn't work, you can try the other way around - copy the dump and index files on your desktop machine. See http://www.eclipse.org/forums/index.php/t/271643/ .
Hope this helps.
Krum
Re: MAT on Linux [message #835806 is a reply to message #791679] Tue, 03 April 2012 13:45 Go to previous messageGo to next message
Did you manage to get this working? I am in the same situation as you were; running the tool on our linux development server but not sure of the best route to viewing the results graphically. I would appreciate any guidance you could possibly give.
Simon.
Re: MAT on Linux [message #836514 is a reply to message #835806] Wed, 04 April 2012 11:27 Go to previous messageGo to next message
Simon,
I made an update to my command. Below is my updated command, this will also run the Leak_Suspects, System_Overview and Top_Components reports.
<JAVA_HOME>/bin/java -XX:MaxNewSize=512m -Xmx4096m -XX:MaxPermSize=512m -XX:-UseGC
OverheadLimit -jar plugins/org.eclipse.equinox.launcher_1.1.1.R36x_v20101122_1400.jar -consoleLog -application org.eclipse.mat.api.parse <HeapFileLocation>/heap.wls1_103d121.02-15-2012.hprof org.eclipse.mat.api:suspects org.eclipse.mat.api:overview org.eclipse.mat.api:top_components
This will generate <HeapDump>_Leak_Suspects.zip, <HeapDump>_Top_Components.zip and <HeapDump>_System_Overview.zip along with the index files.
Then I have copied my heap dump, index files and zip files (reports) to my windows desktop and ran eclipse memory analyzer on windows against my heap dump. Since MAT already got index files and Leak_Suspects, System_Overview and Top_Components reports, it wont parse the heapdump again (here you can give max heap ~1GB or 512MB) and you can view all the 3 reports. I hope this will help you.
Additionally even if X windows works the display wont be as good and fast as we run MAT locally on windows.
I hope this helps you
Gopi
Re: MAT on Linux [message #837449 is a reply to message #836514] Thu, 05 April 2012 13:21 Go to previous message
Thanks Gopi. It worked fine for me. Appreciate you taking the time to respond.
Simon.
[Updated on: Thu, 05 April 2012 13:21] by Moderator
Previous Topic:OQL Find all objects which belong to a HttpSession
Next Topic:can't aquire or open dump with MAT 1.1 on IBM SDK J9
Current Time: Sun Jul 20 19:50:12 EDT 2025
Powered by FUDForum. Page generated in 0.03921 seconds
