Home » Modeling » TMF (Xtext) » Use xtext-based plugin as base for another grammar
Use xtext-based plugin as base for another grammar [message #795597] Fri, 10 February 2012 11:55
I'd like to create a coffeescript plugin which can be used to extend its grammar, just like Xbase can be used to build other grammars on top of it. I understand it's more complicated than a simple plugin. My process has these steps
  1. Configure my coffeescript project to have everything needed later
  2. Create a plugin and an update site. Install it into eclipse.
  3. Configure my cake project to properly extend the coffeescript grammar.
In step 1. I register the genmodel in my mwe2 file like this
bean = StandaloneSetup {
  registerGenModelFile = "platform:/resource/csep/src-gen/csep/CoffeeScript.genmodel"
  registerGeneratedEPackage = "csep.coffeeScript.CoffeeScriptPackage"
I don't like the "src-gen" part, but after trying different combinations, that was the only one that worked. (I tried the text book example of "csep/model/CoffeeScript.genmodel", I don't know how the "model" part of the URI should be resolved, but it didn't for me).
Step 2. seems to be easy, the same thing as with any other plugin.
Step 3. also presents some problems. First, I had to add a reference to the coffeescript plugin, I did it like this
fragment = ecore.EcoreGeneratorFragment {
  referencedGenModels = "platform:/resource/csep/src-gen/csep/CoffeeScript.genmodel"
This is really bad. It uses a deprecated method, but I couldn't figure out how to go the recommended way. But my main problem here is, I don't know what URI to use here, it works only on my machine with an existing "src-gen" folder, but it won't if a user just installs this plugin.
The other problem in step 3. is that the generated code refers to "serializer.CoffeeScriptSemanticSequencer" in many places which it can't find. I assume it should be generated, but it's not generated into the "src-gen" folder.
Any help appreciated. I'm using xtext 2.1.0
[Updated on: Fri, 10 February 2012 12:03] by Moderator
Previous Topic:Code formatting fails
Next Topic:testing custom validator - different behaviour for assertWarning() vs assertWarningContains()?
Current Time: Sat Jul 19 16:20:13 EDT 2025
Powered by FUDForum. Page generated in 0.03465 seconds
