Home » Eclipse Projects » GEF » Disable connection feedback
Disable connection feedback [message #793135] Tue, 07 February 2012 15:19 Go to next message
I have a GEF/Draw2D-based editor that allows users to build a data flow
diagram. Figures include both input data 'channel' anchors and output
data 'channel' anchors. I've extended AbstractConnectionAnchor to suit
my needs and this mostly works well.
One problem. When I select an output 'channel' anchor on an figure
using the connection tool, a feedback connection line appears between
the channel I've just selected and the closest input 'channel' anchor on
the same element. I would prefer nothing appear in this case; the model
doesn't support nodes to be connected to themselves.
In the edit part for the nodes, I've implemented the
GRAPHICAL_NODE_ROLE edit policy
(getConnectionCreateCommand(CreateConnectionRequest),
getConnectionCompleteCommand(CreateConnectionRequest), etc.) and tried
to return NULL in the 'getConnectionCompleteCommand()' method if the
source and target nodes are the same.
No luck.... Any other ideas?
Re: Disable connection feedback [message #793137 is a reply to message #793135] Tue, 07 February 2012 15:25 Go to previous messageGo to next message
Don't return null (which means the edit policy ignores the command) but an UnexecutableCommand instance. That should to the trick...
Re: Disable connection feedback [message #794581 is a reply to message #793137] Thu, 09 February 2012 08:15 Go to previous messageGo to next message
in the target EdtiPart override the method
public ConnectionAnchor getSourceConnectionAnchor(Request request)
public ConnectionAnchor getTargetConnectionAnchor(Request request)
and make them return the correct anchor point for the creationConnection request.
This anchor will be used only during the creation of the connection.
hop this help you
Re: Disable connection feedback [message #794784 is a reply to message #793137] Thu, 09 February 2012 12:51 Go to previous messageGo to next message
This didn't work (the connection feedback line was still there). The
fix that worked was to return a 'null' ConnectionAnchor in my public
ConnectionAnchor EditPart.getTargetConnectionAnchor(Request request) {}
method.
I check to see if the source n target parts exist and return null if
their models' are the same.
Thanks! R
Re: Disable connection feedback [message #794785 is a reply to message #794581] Thu, 09 February 2012 12:51 Go to previous message
> request.
> hop this help you
Thanks. The fix that worked was to return a 'null' ConnectionAnchor in
my public ConnectionAnchor EditPart.getTargetConnectionAnchor(Request
request) {} method.
Thanks! R
Previous Topic: GEF based project
Next Topic:GEF Displaying rulers
Current Time: Sat Jul 19 16:56:18 EDT 2025
Powered by FUDForum. Page generated in 0.05249 seconds
