Home » Newcomers » Newcomers » joptionpane(messages do not appear)
joptionpane [message #794104] Wed, 08 February 2012 18:05 Go to next message
Hi!
I have recently started learning Java and I have the code below. When I run the code, using eclipse, the pop up window appears but without the message "ABC". The same problem appears with other methods from the same class.
import javax.swing.*;
public class EA38 {
JOptionPane.showMessageDialog(null, "ABC");
System.exit(0);
Re: joptionpane [message #794748 is a reply to message #794104] Thu, 09 February 2012 11:58 Go to previous messageGo to next message
Hi, I tested your code in my Eclipse, it is working properly!
Could you capture the screen-shot?
Re: joptionpane [message #795306 is a reply to message #794748] Fri, 10 February 2012 05:05 Go to previous messageGo to next message
I send you the whole screenshot from eclipse.
I can understand that there is nothing wrong with the code.
I have also tried running it from command line and the same problem appears there too.
Re: joptionpane [message #796633 is a reply to message #795306] Sun, 12 February 2012 04:18 Go to previous messageGo to next message
I could not re-produce the problem in my environment, which version of Eclipse and JDK are you using?
Re: joptionpane [message #796796 is a reply to message #796633] Sun, 12 February 2012 10:34 Go to previous message
Eclipse Java EE IDE for Web Developers.
Galileo
Version: 1.2.2.20100217-2310
jdk 1.6
Previous Topic:Exception in thread "main"
Next Topic:Color problem in comparison editor using Aptana plugin
Current Time: Sat Jul 19 16:19:46 EDT 2025
Powered by FUDForum. Page generated in 1.12178 seconds
