can connect to dl.google.com but not download.eclipse.org [message #793404] |
Tue, 07 February 2012 23:57  |
hi all,
i'm running eclipse indigo ("eclipse-java-indigo-SR1-win32") and jdk ("jdk-7u2-windows-i586") on windows 7.
under "help", "install new software", i'm able to see updates with "http //dl.google.com/eclipse/plugin/3.7" in the "works with" field, but i cannot see updates for any "download.eclipse.org" url (for example "http //download.eclipse.org/eclipse/updates/3.7") - it gets stuck saying "pending..." and goes nowhere.
since i'm able to see updates from "dl.google.com" but not from "download.eclipse.org", i have to believe my connection setup is good. however, when i go to "download.eclipse.org" in a browser i can see the site is currently up. i've been having this problem throughout multiple attempts for 2 days now.
i'm stumped. any thoughts?
[Updated on: Wed, 08 February 2012 00:07] by Moderator
Re: can connect to dl.google.com but not download.eclipse.org [message #794232 is a reply to message #794079] |
Wed, 08 February 2012 22:30   |
So I connected to download.eclipse.org using the '://download.eclipse.org/releases/indigo/201109230900/' path. I then went on to start installing GWT. Midway through, I think the same issue happened again when it went back out to download.eclipse.org. Please see error output below and let me know your thoughts on what the root cause could be. Thanks much!
An error occurred while collecting items to be installed
session context was:(profile=epp.package.java, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.datatools.connectivity,1.2.3.v201108101135
No repository found containing: osgi.bundle,org.eclipse.datatools.connectivity.db.generic,1.0.1.v200908130547
No repository found containing: osgi.bundle,org.eclipse.datatools.connectivity.dbdefinition.genericJDBC,1.0.1.v200906161815
No repository found containing: osgi.bundle,org.eclipse.datatools.connectivity.sqm.core,1.2.3.v201109022323
No repository found containing: osgi.bundle,org.eclipse.datatools.connectivity.ui,1.2.1.v201010211430
No repository found containing: osgi.bundle,org.eclipse.datatools.help,1.5.0.v200906020553
No repository found containing: osgi.bundle,org.eclipse.datatools.modelbase.dbdefinition,1.0.2.v201002130228
No repository found containing: osgi.bundle,org.eclipse.datatools.modelbase.sql,1.0.4.v201002250945
No repository found containing: osgi.bundle,org.eclipse.jst.common.project.facet.core,1.4.200.v201103170302
No repository found containing: osgi.bundle,org.eclipse.jst.server.core,1.2.202.v20110419
No repository found containing: osgi.bundle,org.eclipse.pde.build,3.7.0.v20110512-1320
No repository found containing: osgi.bundle,org.eclipse.pde.core,3.7.1.v20110822-2108
No repository found containing: osgi.bundle,org.eclipse.wst.css.core,1.1.500.v201104191926
No repository found containing: osgi.bundle,org.eclipse.wst.css.ui,1.0.600.v201103022054
No repository found containing: osgi.bundle,org.eclipse.wst.html.core,1.1.501.v201109080146
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.core,1.1.101.v201108151912
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.manipulation,1.0.300.v201104272153
No repository found containing: osgi.bundle,org.eclipse.wst.jsdt.ui,1.1.101.v201108151912
No repository found containing: osgi.bundle,org.objectweb.asm,3.3.1.v201105211655
FUDForum. Page generated in 0.10307 seconds
