Re: Unable to delete Commands [message #797433 is a reply to message #795482] |
Mon, 13 February 2012 08:32   |
It is unclear why do you want to call dispose at the first place.
To my understanding, this method is intended to be called by the CommandStack of limited size, when it pushes the command out of itself. This is the way to tell you that it is safe to release the resources aquired in the command, so you are only expected to implement it, not to explicitly call it.
Note the javadoc of Command#dispose() that states:
* This is called to indicate that the <code>Command</code> will not be used
* again. The Command may be in any state (executed, undone or redone) when
* dispose is called. The Command should not be referenced in any way after
* it has been disposed.
and this is clearly not your case because the command stack still references it.
What is the high level effect you are trying to achieve?
Michael "Borlander" Golubev
at Montages Think Tank, Prague, Czech Republic
Montages AG, Zürich, Switzerland
FUDForum. Page generated in 0.25187 seconds
