Home » Eclipse Projects » Remote Application Platform (RAP) » Dropdown with a list widget
Dropdown with a list widget [message #78819] Fri, 21 March 2008 18:39 Go to next message
Hello All,
I am new to RAP and also to RCP. I wanted to find out if there is any
widget which will allow multiple selections on dropdown
or
when focus comes on a text-field we can create a list below that
text-field and allow user to select multiple items from that list.
I want to achieve this functionality in RAP. Currently I am using RAP
1.1 M1 target platform.
Please advice.
Arpit
Re: Dropdown with a list widget [message #78850 is a reply to message #78819] Sun, 23 March 2008 04:41 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
hi,
a first idea on how to achieve this: you could add a focus listener on the
text widget which opens a new shell at the coords of the text widget. the
shell only contains a check table with the selectable items. the shell
closes upon loosing its focus and returns an array of the selected items.
if you need help or some examples with the codebase pls report back :).
greetings and happy easter!
-ben
Re: Dropdown with a list widget [message #79030 is a reply to message #78850] Mon, 24 March 2008 10:10 Go to previous messageGo to next message
Thanks Ben,
Sounds like a good idea, I am gonna give it a shot today and will report
back if run into any road-bumps.
Thanks again
Arpit
Ben W. wrote:
> hi,
> the text widget which opens a new shell at the coords of the text
> widget. the shell only contains a check table with the selectable items.
> the shell closes upon loosing its focus and returns an array of the
> selected items. if you need help or some examples with the codebase pls
> report back :).
> -ben
Re: Dropdown with a list widget [message #79103 is a reply to message #79030] Mon, 24 March 2008 14:59 Go to previous messageGo to next message
Hey Guys,
Here is a snippet of what I came up with but somehow its not working. I
am able to create and display the new shell but the List inside this new
shell is never displayed. I tried putting a simple text box too but that
didn't show up either.
What am I doing wrong here ?
Arpit
txtVersion.addFocusListener(new FocusAdapter() {
Shell sh;
Text widget;
List lst;
Composite c;
Display display;
public void focusGained(final FocusEvent event) {
widget = (Text)event.widget;
display = widget.getDisplay();
sh = new Shell(display.getCurrent().getActiveShell(), SWT.NO_TRIM);
System.out.println("x=" + widget.getLocation().x + "
y="+widget.getLocation().y);
sh.setLayout(new GridLayout());
sh.setLocation(widget.toDisplay(widget.getLocation()));
sh.setSize(widget.getSize().x, 100);
// Text t = new Text(sh, SWT.BORDER);
// t.setText("Typo");
lst = new List(sh, SWT.MULTI | SWT.V_SCROLL);
lst.setItems(new String[] { "1 - Hello", "2 - Hello", "3 - Hello",
"4 - Hello", "5 - Hello" });
lst.setVisible(true);
sh.open();
sh.redraw();
while (!sh.isDisposed()) {
if (!(display.readAndDispatch())) {
display.sleep();
public void focusLost(FocusEvent event) {
sh.close();
sh.dispose();
Arpit Desai wrote:
> Thanks Ben,
> Thanks again
> Arpit
> Ben W. wrote:
>> hi,
>> items. the shell closes upon loosing its focus and returns an array of
>> the selected items. if you need help or some examples with the
>> -ben
Re: Dropdown with a list widget [message #79133 is a reply to message #79103] Mon, 24 March 2008 15:08 Go to previous message
Originally posted by: fappel.innoopract.com
which RAP-Version do you use? There was a bug #204556 that seems similar
to what you are describing. That bug is solved in CVS-Head. Just in
case...
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Arpit Desai [mailto:arpitdesai23@gmail.com]
Bereitgestellt: Montag, 24. März 2008 20:00
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Dropdown with a list widget
Betreff: Re: Dropdown with a list widget
Hey Guys,
Arpit
Shell sh;
Text widget;
List lst;
Composite c;
Display display;
sh = new
SWT.V_SCROLL);
sh.open();
sh.redraw();
if
display.sleep();
sh.close();
sh.dispose();
Arpit Desai wrote:
> Thanks Ben,
> report back if run into any road-bumps.
> Thanks again
> Arpit
> Ben W. wrote:
>> hi,
>> on the text widget which opens a new shell at the coords of the text
>> of the selected items. if you need help or some examples with the
>> -ben
Previous Topic:Color Dialog?
Next Topic:Images in TreeViewer
Current Time: Sat Jul 19 12:15:06 EDT 2025
Powered by FUDForum. Page generated in 0.45979 seconds
