[solved]How get and set features values on drag and drop ? [message #790209] |
Fri, 03 February 2012 19:02  |
I'm trying alter some eClass features value when some node drop on a diferent compartment. But when I try alter the feature value on my destiny node, this node became invalid, no one another node can be droped there.
I register my DragDropEditPolicy, in EditPart, overriding de getDropCommand as below:
protected Command getDropCommand(ChangeBoundsRequest request) {
FolderEditPart folder = (FolderEditPart)getTargetEditPart(request).getParent();
Folder eFolder = (Folder)folder.resolveSemanticElement();
EStructuralFeature esf = eFolder.eClass().getEStructuralFeature("files");
File file = FolderFactory.eINSTANCE.createFile();
file.setName("newFile");
eFolder.eSet(esf, file); // here is the problem, I cant set the new value
return super.getDropCommand(request);
My duvid is, how can I set and get feature values on drag and drop events using the gmf?
obs: the feature that I want change is many-valued.
[Updated on: Sat, 04 February 2012 22:48] by Moderator
Re: How get and set features values on drag and drop ? [message #790469 is a reply to message #790209] |
Sat, 04 February 2012 04:32   |
Comments below.
> droped there.
> new value
Given this method is returning a command, any changes you make to the
model need to be done as part of executing a command, not as part of
creating the command. I'm also not sure why you'd be doing this
reflectively rather than doing eFolder.getFiles().add().
> My duvid is, how I can set and get feature values on drag and drop
It's clear then that calling eSet will require the argument to be a list
so you'll be getting a class cast exception. Haven't you used the
debugger to track what's happening? You'd better look at what super
does and understand how to create commands. No doubt you'll need to
compose a command (CompoundCommand) for adding a file to the folder with
the command you're getting back from super...
Re: How get and set features values on drag and drop ? [message #791038 is a reply to message #790955] |
Sun, 05 February 2012 01:56  |
Comments below.
On 05/02/2012 4:47 AM, Missing name Mising name wrote:
> I solve my problem with this:
> FolderImpl folder = (FolderImpl)getHostObject();
Why cast to an Impl? Aren't all the methods you need available on the
interface?
> folder.eSetDeliver(false); // permite get/set EObjects
> List l = request.getEditParts();
> File f = null;
> for (Object obj : l) {
> if(obj instanceof FileEditPart) {
> FileEditPart fileEditPart = ((FileEditPart)obj);
> f = ((File)fileEditPart.resolveSemanticElement());
> } if(!folder.getFiles().contains(f))
> folder.getFiles().add(f); // apenas um EObject e setado no
> destino
Keep in mind that this can't be undone and that the command stack
assumes the state of the model is only ever changed by virtue of
executing, undo, and redoing commands. You really should do this as a
command...
> ChangeBoundsRequest req = new ChangeBoundsRequest(REQ_ADD);
> req.setEditParts(request.getEditParts());
> req.setMoveDelta(request.getMoveDelta());
> req.setSizeDelta(request.getSizeDelta());
> req.setLocation(request.getLocation());
> req.setResizeDirection(request.getResizeDirection());
> Command cmd = getHost().getCommand(req);
> if (cmd == null || !cmd.canExecute()) {
> return cmd;
FUDForum. Page generated in 0.04632 seconds
