Home » Newcomers » Newcomers » Eclipse runs but can't build anything(trying to get new install to work)
Eclipse runs but can't build anything [message #789275] Thu, 02 February 2012 15:00 Go to next message
I installed the 64 bit version of Eclipse for C++ today. I checked to make sure I have a 64 bit version of Java, which I do, it's version 1.6_29
I'm running a MacBook Pro with Lion 10.7.2 on an Intel Core 2 Duo processor and 8 GB of DDR3 RAM.
I read the posts I'm supposed to read as a newbie and I opened up the ini file and did the -vm fix, but the error messages didn't change.
I can start up Eclipse, but when I tested it with a simple program I get errors that appear to be related to the #include directive. Here's the code for the program:
// Name : JavaTweak.cpp
// Author :
// Version :
// Copyright : Your copyright notice
// Description : Hello World in C++, Ansi-style
#include <iostream>
using namespace std;
int main() {
cout << "!!!Hello World!!!" << endl; // prints !!!Hello World!!!
return 0;
And here are the error messages:
Description Resource Path Location Type
Symbol 'cout' could not be resolved JavaTweak.cpp /JavaTweak/src line 13 Semantic Error
Symbol 'endl' could not be resolved JavaTweak.cpp /JavaTweak/src line 13 Semantic Error
Symbol 'std' could not be resolved JavaTweak.cpp /JavaTweak/src line 10 Semantic Error
Error launching external scanner info generator (g++ -E -P -v -dD /Users/Home/Documents/workspace/.metadata/.plugins/org.eclipse.cdt.make.core/specs.cpp) JavaTweak [Discovery Options] page in project properties C/C++ Problem
Error launching external scanner info generator (gcc -E -P -v -dD /Users/Home/Documents/workspace/.metadata/.plugins/org.eclipse.cdt.make.core/specs.c) JavaTweak [Discovery Options] page in project properties C/C++ Problem
Program 'g++' is not found in $PATH JavaTweak [Discovery Options] page in project properties C/C++ Problem
Program 'gcc' is not found in $PATH JavaTweak [Discovery Options] page in project properties C/C++ Problem
Anyone know why I'm having problems or what is the fix? THANKS!
Re: Eclipse runs but can't build anything [message #789349 is a reply to message #789275] Thu, 02 February 2012 17:13 Go to previous message
No matter about Java, this is still a C/C++ problem. Eclipse is running
okay; it's something to take up with the Eclipse CDT forum?
> // Author : // Version :
> #include <iostream>
> int main() {
> return 0;
> Semantic Error
> Semantic Error
> Semantic Error
Previous Topic:Eclipse Marketplace Maven not updating dependencies
Next Topic:Fresh install on Mac OSX... Eclipse won't run
Current Time: Sun Jul 20 12:03:44 EDT 2025
Powered by FUDForum. Page generated in 0.07861 seconds
