Home » Eclipse Projects » Remote Application Platform (RAP) » How to add js for widgets?
How to add js for widgets? [message #788812] Thu, 02 February 2012 03:59 Go to next message
I need to add some script for canvas. I did it like following, but it doesn't work.
code in customize LCA class:
public void renderChanges(Widget widget) throws IOException {
JavaScriptResponseWriter writer =
ContextProvider.getStateInfo().getResponseWriter();
writer
.write("$('#"
+ WidgetUtil.getId(widget)
+ "').bind('mousewheel', function(event, delta, deltaX, deltaY) {alert('wtf!!');});");
I have imported jquery and mousewheel plugin. I don't how rap works since I can't see any script(for widgets) written by JavaScriptResponseWriter on the client. It seems that these scripts(for widgets) will be evaluated internally.
any advice? Thanks for your attention.
Re: How to add js for widgets? [message #788865 is a reply to message #788812] Thu, 02 February 2012 04:56 Go to previous messageGo to next message
Hi.
You won't be able to access the client widgets with jquery just like
that. I'm not sure what you want to do exactly, but i recommand you to
look at http://wiki.eclipse.org/RAP/ClientScripting. This project is in
very early development. Its currently missing Java API, which should be
there in a week or so. After that, any questions or suggestions for this
project are welcome.
greetings,
Tim
Am 02.02.2012 09:59, schrieb sapzqq tyapqz:
> doesn't work.
> @Override
> writer
> .write("$('#"
> } I have imported jquery and mousewheel plugin. I don't how rap works
Re: How to add js for widgets? [message #788909 is a reply to message #788865] Thu, 02 February 2012 06:18 Go to previous messageGo to next message
Hi Tim
There's no content now in the page you provided. Maybe wait for some time.
What I want to do is to add mousewheel listener to canvas. On RCP, we have a canvas which can be zooming with mousewheel event. This does not support in RAP. So I try to do it myself.
The solution I thought is implementing a customized LCA class for the canvas, adding the mousewheel listener and in the handler of js, sending the request to server(this seems possible).
Do you have any idea about this? Thanks for your reply.
[Updated on: Thu, 02 February 2012 06:19] by Moderator
Re: How to add js for widgets? [message #789171 is a reply to message #788909] Thu, 02 February 2012 12:37 Go to previous message
Am 02.02.2012 12:18, schrieb sapzqq tyapqz:
> Hi Tim
There is for me, but it now seems to me its not relevant for your issue.
> What I want to add mousewheel listener to canvas.
I suggest you open an enhancement request on our bugzilla, we can
continue discussion there. Describe what API is missing and perhaps what
your usecase would look like.
Greetings,
Tim
Previous Topic:HTTP Status 404 - ProxyServlet: /tmf_rap/mcrap
Next Topic:show view option enablement
Current Time: Sat Jul 19 06:34:04 EDT 2025
Powered by FUDForum. Page generated in 0.24829 seconds
