[ report "" [message #788345] |
Wed, 01 February 2012 12:30  |
i am using the Serializer to serialize my Result in the Generator. But now it occurs, that i seem to lose some Tokens.
From the Input: assume always test
Derives this: assert test [ report ""
When i Input only: assume always
It derives: assert always [ report ""
My Grammar itself seem to be ok. Its too big to post, but assume and always are terminals, and test is a value of ID
Any Ideas?!
Re: [ report "" [message #789766 is a reply to message #789654] |
Fri, 03 February 2012 06:27   |
On 2012-03-02 9:31, Sebastian Burg wrote:
> I just didnt have the time to boil it down, as i am happy to have a
> running system right now to show the client.
> The problem is, the grammar is really deterministic at the given point.
> The first word is a terminal word. So i dont see how it should refer to
> another path in the grammar.
> i.e.
> expression:
> ASSERT ex=ID AT fo=bar | ASSUME ex=ID value=SomeString;
> terminal ASSERT: 'assert';
> terminal ASSUME: 'assume';
> terminal AT: '@';
> as it is now, if there i enter assume, sometimes i get assert xyz @.
Not surprising, nothing is produced that makes the *result* differ, the
fact that an 'assert' or an 'assume' was seen is lost and you get an
instance of 'expression'. You are not showing the grammar for "fo=bar"
so impossible to tell you exactly what is going on.
You need something in the created object that keeps the information. You
can use a boolean flag, assign the keyword, or use two different classes
(this is what typically used).
// using boolean flag
expression: isAssert ?= 'assert' 'at' ... ;
// assigning the keyword
expression : type = ASSERT AT ... | type = ASSUME ... ;
// using classes
expression: AssertExpression | AssumeExpression ;
AssertExpression : 'assert' '@' ... ;
AssumeExpression : 'assign' ... ;
Another thing to possibly change is using the Xtext keyword support as
using terminals for keywords is usually not a very good idea.
Use either:
expression: 'assert' '@' fo = bar | 'assume' ex= .... ;
or
expression: ASSERT AT ...
ASSERT: 'assert';
AT: '@';
Doing so, they will be recognized as keywords.
> Could it be a cache problem?
no
> I tried new example to file with a bug, but yet havent been able to
> reproduce the problem. As i said, didnt have the time yet. I will try
> today after the presentation.
The problem is in your grammar.
Hope that helps.
- henrik
FUDForum. Page generated in 0.29036 seconds
