Home » Archived » M2M (model-to-model transformation) » [ATL] Feature ... is not changeable
[ATL] Feature ... is not changeable [message #788838] Thu, 02 February 2012 04:33 Go to next message
i'm trying to perform a M2M-transformation from an Java-Model (created with MoDisco) to an UML-Model.
My Problem: If i try to set the owner of a UML::Property i always get the error message "Feature owner is not changeable". I know that in the UML Metamodel owner is declared as not changeable, but despite that is there a way to set the owner during the transformation? Perhaps to force ATL to set this attribute?
I already tried to set the ownedAttribute-Field of an UML::Class to the corresponding attributes of the Java-Modell, but that didn't work either.
So, i hope that there is a possibility to force ATL to set this owner-Field.
Thanks for your answers!
Stoehm
Re: [ATL] Feature ... is not changeable [message #788858 is a reply to message #788838] Thu, 02 February 2012 04:52 Go to previous messageGo to next message
The UML meta-model has a variety of subset properties and generally you
can only change one of them.
I suggest checking that you add to the container from which the subsets
are built.
Ed Willink
On 02/02/2012 09:33, stoehm Mising name wrote:
> either.
> owner-Field.
> Best regards,
> Stoehm
Re: [ATL] Feature ... is not changeable [message #789116 is a reply to message #788858] Thu, 02 February 2012 11:12 Go to previous messageGo to next message
Edward Willink wrote on Thu, 02 February 2012 04:52
are built.
Ed Willink
Hi Ed,
thanks for your answer. But i think i dont get it.
Now i've tried it that way:
rule Class2Class {
	from
		jClassDeclaration : JAVA!ClassDeclaration,
		jClassModifier : JAVA!Modifier (
			jClassDeclaration.modifier = jClassModifier
	to
		umlClass : UML!Class (
			name <- jClassDeclaration.name,
			package <- jClassDeclaration.package,
			visibility <- jClassModifier.getVisibility(),
			isAbstract <- jClassModifier.isAbstract(),
			isLeaf <- jClassModifier.isFinal(),
--			isActive <-
--			elementImport <-
--			packageImport <-
--			clientDependency <-
--			nestedClassifier <-
--			ownedOperation <-
			ownedAttribute <- jClassDeclaration.bodyDeclarations->select(e | e.oclIsKindOf(JAVA!FieldDeclaration))
--			ownedConnector <-
--			ownedPort <-
--			generalization <-
--			general <-
--			interfaceRealization <-
--			superClass <- jClassDeclaration.superClass.type
--			_ <- jClassDeclaration.superInterfaces
But I always get the warning "Cannot set feature ownedAttribute to value ... containment references cannot span across models."
I don't know whats the Problem with that transformation. In an other transformation I do it that way: packagedElement <- jPackage.ownedElements and that works fine.
Re: [ATL] Feature ... is not changeable [message #789126 is a reply to message #789116] Thu, 02 February 2012 11:22 Go to previous messageGo to next message
Cross-resource containment is a different issue. I think it's normally
disabled because it's expensive but you can enable it when you genmodel.
However the message may indicate something nastier like putting an input
element ion an output resource. I've never been able to understand ATL
so I cannot help you on ATL-specific subtleties.
Ed Willink
>> Hi
>> you can only change one of them.
>> subsets are built.
>> Regards
>> Ed Willink
> Hi Ed,
> rule Class2Class {
> from
> to
> -- isActive <-
> -- elementImport <- -- packageImport <-
> -- nestedClassifier <- -- ownedOperation <-
> ownedAttribute <-
> -- ownedConnector <- -- ownedPort <-
> -- general <-
Re: [ATL] Feature ... is not changeable [message #789146 is a reply to message #789126] Thu, 02 February 2012 12:00 Go to previous messageGo to next message
are you sure you do have a rule to transform "jClassDeclaration.bodyDeclarations->select(e | e.oclIsKindOf(JAVA!FieldDeclaration))" to UML properties ?
Re: [ATL] Feature ... is not changeable [message #792075 is a reply to message #789146] Mon, 06 February 2012 10:25 Go to previous messageGo to next message
Yes, i'm sure.
Here it is. By the way thisModule.resolveTemp doesn't work either.
rule Attribute2Property {
	from
		jFieldDeclaration : JAVA!FieldDeclaration,
		jModifier : JAVA!Modifier
			(jModifier.bodyDeclaration = jFieldDeclaration)
	to
		umlProperty : UML!Property (
			name <- jFieldDeclaration.fragments->collect(e | e.name),
			visibility <- jModifier.getVisibility(),
			class <- thisModule.resolveTemp(jFieldDeclaration.abstractTypeDeclaration, 'umlClass')
--			owner <- jFieldDeclaration.abstractTypeDeclaration.refImmediateComposite()
--			class <- jFieldDeclaration.abstractTypeDeclaration.refImmediateComposite()
Re: [ATL] Feature ... is not changeable [message #825020 is a reply to message #792075] Tue, 20 March 2012 07:07 Go to previous messageGo to next message
I got the same problem.
For me the cause was that in the ecore file I used, the associations were not declared as containments.
Checking "is Contaiment" in the ecore editor for your different associations should resolve the problem.
Re: [ATL] Feature ... is not changeable [message #840607 is a reply to message #788838] Tue, 10 April 2012 05:42 Go to previous messageGo to next message
Hi again,
i solved the Problem two Month ago, and i only want to post the answer for that Problem.
The Key was the FieldDeclaration2Property-Transformation. I matched FieldDeclaration AND Modifier, and so the created Properties didn't go into the ownedAttribute because of the Modifier-Match.
Now my Rule FieldDeclaration2Property works without the Modifier-Match and the Properties are all on the place where they should be Smile
Greetings,
Stoehm
[Updated on: Tue, 10 April 2012 05:42] by Moderator
Re: [ATL] Feature ... is not changeable [message #865698 is a reply to message #840607] Mon, 30 April 2012 10:28 Go to previous message
great, thanks! Smile
Previous Topic:[ATL] WSDL: Access name attribute
Next Topic:Regla que cree y retorne coleccion de objetos
Current Time: Sun Jul 20 14:58:59 EDT 2025
Powered by FUDForum. Page generated in 0.25195 seconds
