Home » Modeling » TMF (Xtext) » Boolean-Rule not used but causes Error in ANTlr
Boolean-Rule not used but causes Error in ANTlr [message #787677] Tue, 31 January 2012 16:31 Go to next message
i'm having some troubles with a small grammar i've created. I'm using xtext 2.2.1
grammar de.lang.common
import "http://www.eclipse.org/emf/2002/Ecore" as ecore
generate common "http://www.lang.de/Common"
Model: name=QNAME;
QNAME:
	ID ('.' ID)*;
terminal ID:
	'^'?('a'..'z'|'A'..'Z'|'_') ('a'..'z'|'A'..'Z'|'_'|'0'..'9')*;
terminal BOOLEAN:
	'true'|'false';
When i try to compile this grammar, antlr says:
'The following token definitions can never be matched because prior tokens match the same input: RULE_BOOLEAN'
I don't know how to fix this. The Boolean-Rule isn't even used. This grammar will become a set of rules that i want to use throughout my other grammars and now i'm stuck, since it won't compile correctly.
If someone could point me into the right direction, maybe i do not understand the error message correctly...
That would be awesome.
Kind regards
Hendrik
Re: Boolean-Rule not used but causes Error in ANTlr [message #787693 is a reply to message #787677] Tue, 31 January 2012 16:56 Go to previous messageGo to next message
never the less the id terminal rule hides the boolean terminal rule
=> you have to switch the order of the rules in the Xtext file
~Christian
Re: Boolean-Rule not used but causes Error in ANTlr [message #787884 is a reply to message #787677] Tue, 31 January 2012 23:33 Go to previous messageGo to next message
There really is no such thing as "unused terminals" - the lexer will
deliver the input as tokens - one per found terminal. If your grammar
does not use a particular terminal just means that there will be a
syntax error when the lexer matches and delivers this token.
BTW, handling keywords as terminals is typically a really bad idea. By
default, your keywords are treated a special way - if the lexer matches
input that is a keyword it will return the token for the keyword instead
of what it otherwise matched. For booleans, you probably want a datatype
that also transforms from the string form "true"/"false" and a boolean
value.
BooleanValue returns ecore::EBoolean: 'true' | 'false';
And you associate a transformer with the "BooleanValue" rule. Perhaps
something like this:
@ValueConverter(rule = "BooleanValue")
public IValueConverter<Boolean> BooleanValue() {
return new IValueConverter<Boolean>() {
public String toString(Boolean value) {
return value.toString();
public Boolean toValue(String string, INode node) {
if(Strings.isEmpty(string))
throw new ValueConverterException("Could not convert empty string
to boolean", node, null);
return new Boolean(string).equals(Boolean.TRUE)
? Boolean.TRUE
: Boolean.FALSE;
- henrik
On 2012-31-01 22:31, Hendrik Renken wrote:
> Hello,
> xtext 2.2.1
> Model: name=QNAME;
> QNAME:
> ID ('.' ID)*;
> terminal ID:
> terminal BOOLEAN:
> 'true'|'false';
> Kind regards
> Hendrik
Re: Boolean-Rule not used but causes Error in ANTlr [message #787968 is a reply to message #787884] Wed, 01 February 2012 02:28 Go to previous message
Ah. Thanks for the reply.
Didn't know there was an implied order on the rules.
Previous Topic:What i need to use for get entities-attributes in a variable?
Next Topic:Projectional Editor?
Current Time: Sun Jul 20 14:09:35 EDT 2025
Powered by FUDForum. Page generated in 0.16446 seconds
