Home » Archived » BIRT » Uh-Oh (re: #786618)
Uh-Oh (re: #786618) [message #786751] Mon, 30 January 2012 14:35 Go to next message
I just tried the solution presented in message #786618 to accomplish a redirect upon an error condition (bad DB username / password). This seems to work fine from the Designer, but when I deploy the report to Tomcat, I get the following (note that the code resides in the onCreate event of a table (id=935).
Any idea what I need to do differently to make this work from the web viewer (deployed to Tomcat)?
TypeError: Cannot call method "getTask" of null (/report/body/table[@id="935"]/method[@name="onCreate"]#5) (Element ID:935)
birt.core.JavascriptCommonError ( 1 time(s) )
detail : org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "var taskid =
reportContext.getHttpServletRequest().getAttribute("attributeBean").getTaskId();
var mytask =
reportContext.getHttpServletRequest().getSession().getAttribute("tasks").get(taskid).getTask();
if( !mytask.getErrors().isEmpty() ){
//you could iterate the errors here as well
reportContext.setGlobalVariable("myerrors",true);
}else{
reportContext.setGlobalVariable("myerrors", false);
Re: Uh-Oh (re: #786618) [message #787447 is a reply to message #786751] Tue, 31 January 2012 10:37 Go to previous messageGo to next message
Mike
What version of BIRT are you using and what app server. This worked
fine on my deployment. Also are you using the viewer?
Jason
> var mytask =
> }else{
Re: Uh-Oh (re: #786618) [message #789346 is a reply to message #787447] Thu, 02 February 2012 17:13 Go to previous messageGo to next message
My test env.: win 7, Eclipse 3.7.0, Tomcat 7.
I'm not sure what was up. I was under a bit of a deadline so I ended up un-jar-ing viewservlets.jar, then I added a big blurb in the paramter box prompt message about how 'the red error message means that you've entered your username and password incorrectly -- use your browser's back button if this happens' and the re-jar-ed . . . this was good enough.
I would like to work this out for future projects, though.
Even better would be a way to edit the message text, catch the actual error at this level, etc.
Re: Uh-Oh (re: #786618) [message #789958 is a reply to message #789346] Fri, 03 February 2012 11:08 Go to previous messageGo to next message
Can you log an enhancement for this?
Jason
Re: Uh-Oh (re: #786618) [message #790126 is a reply to message #789958] Fri, 03 February 2012 16:23 Go to previous message
Will do!
Previous Topic:how to bring values from multidimentional java script array in 'initialize block' to dynamic text
Next Topic:Need help to generate PDF Report
Current Time: Sat Jul 19 21:08:40 EDT 2025
Powered by FUDForum. Page generated in 0.24765 seconds
