Home » Modeling » TMF (Xtext) » Access a reference's feature(Given an EReference, how to access the referenced object's name?)
Access a reference's feature [message #786638] Mon, 30 January 2012 12:07 Go to next message
I hope the following description and code snippets makes my problem clear. I have a ForceDefinition:
ForceDefinition:
	keyword=ForceDefKeyword
	name=STRING
		side=[SideDefinition|STRING]
		& attributes+=Attribute*
		& attributes+=EnemyAttribute*
		& attributes+=UnitAttribute*
		& attributes+=SatelliteAttribute*
	=>EndKeyword
Which, as you saw above, can reference a SideDefinition:
SideDefinition:
	keyword=SideDefKeyword
	name=STRING
	=>EndKeyword
I test things out with DSL text that looks like this:
Plan "hierarchy"
SideDef "Good guys"
End
SideDef "Bad guys"
End
ForceDef "Good force"
	Side	"Good guys"
End
End
I am accessing Xtext's global index in my Java code, and I manage to obtain an EReference from a ForceDefinition instance:
		for (IEObjectDescription eObjectDesc :
			desc.getExportedObjectsByType(TplXPackage.Literals.FORCE_DEFINITION))
		// Force's name?
		QualifiedName qName = eObjectDesc.getQualifiedName();
		String forceName = qName.getLastSegment();
		// Does this Force reference a Side?
		String sideName = null;
		for (EReference eRef : eObjectDesc.getEClass().getEReferences())
			if (eRef.getName().equals("side"))
				// TODO: Wish I could access the name of this side...
How can I achieve the TODO above? What approach would allow me to determine the name of the SideDefinition being referenced?
Re: Access a reference's feature [message #787179 is a reply to message #786638] Tue, 31 January 2012 03:48 Go to previous messageGo to next message
(This is really an EMF question.)
You mean to obtain the value of the EReference's target, right? You need an EObject for that, which is given by IEObjectDescription.getEObjectOrProxy(), so this should work (untested):
((SideDefinition) desc.getEObjectOrProxy().eGet(eRef)).getName()
Re: Access a reference's feature [message #787196 is a reply to message #787179] Tue, 31 January 2012 04:01 Go to previous messageGo to next message
Hi Meinte, hi Joey,
this will likely return the proxy which has no values set (usually).
You'd have to resolve that with a resource set.
XtextResourceSet rs = resourceSetProvider.get(myProject);
ForceDef fd = rs.getEObject(description.getEObjectURI(), true);
fd.get(..)
Sebastian
Am 31.01.12 09:48, schrieb Meinte Boersma:
Re: Access a reference's feature [message #787441 is a reply to message #787179] Tue, 31 January 2012 10:32 Go to previous message
Meinte,
I expanded your one-line suggestion and found that the call to eGet(...) returns null:
				EObject objOrProxy = eObjectDesc.getEObjectOrProxy();
				Object obj = objOrProxy.eGet(eRef);	// <-- returns null
				SideDefinition sideDef = (SideDefinition)obj;
				sideName = sideDef.getName();
I'm not sure if this is what Sebastian was referring to when he said, "the proxy which has no values set (usually)."
Sebastian,
Thanks for the advice - I obtained an XtextResourceSetProvider the following way:
Class MyClass {
	@Inject
	private XtextResourceSetProvider xtextResourceSetProvider;
	public MyClass ()
		Injector injector =
				TplXActivator.getInstance().getInjector("com.exoanalytic.seas.tplx.TplX");
		injector.injectMembers(this);
And used the following code to obtain the SideDefinition referenced by a ForceDefinition:
                ResourceSet xtextResourceSet = xtextResourceSetProvider.get(currentProject);
		    ForceDefinition forceDef = (ForceDefinition)
				    xtextResourceSet.getEObject(eObjectDesc.getEObjectURI(), true);
		    SideDefinition referencedSideDef = forceDef.getSide();
		    String referencedSideName = referencedSideDef.getName();
Thanks much for the replies!
Previous Topic:Generic access for QualifiedName
Next Topic:Conditional formatter
Current Time: Sat Jul 19 15:33:57 EDT 2025
Powered by FUDForum. Page generated in 0.25916 seconds
