Home » Eclipse Projects » Rich Client Platform (RCP) » can't add org.eclipse.core.expressions
can't add org.eclipse.core.expressions [message #784792] Fri, 27 January 2012 20:28 Go to next message
I'm trying to follow the directions on using Eclipse Commands in my RCP app.
On the manifest dependencies page, I need to add the "org.eclipse.core.expressions" plug in so I can define expressions.
I can't.
When I click on the "Add..." button, and start typing "expre", it only show me the org.eclipse.core.expressions.source plugin.
I can see from looking at my run configuration that the core.expressions plug-in is used, as it's included in the run configuration.
I just can't seem to add it to the dependencies tab in the Manifest editor.
Any suggestions?
Re: can't add org.eclipse.core.expressions [message #784798 is a reply to message #784792] Fri, 27 January 2012 20:34 Go to previous messageGo to next message
So, reading the instructions again: "Select plugin.xml and add "org.eclipse.core.expressions" as a dependency. Select then the Extensions tab and add the extensions org.eclipse.core.expressions.definitions. "
I decided to try the 2nd step, since I can't do the 1st.
It lets me add the extension, without adding the dependency.
Somehow, this seems wrong.
Re: can't add org.eclipse.core.expressions [message #786729 is a reply to message #784798] Mon, 30 January 2012 14:08 Go to previous message
Sounds like you are picking it up already, but the dependencies in your MANIFEST.MF will describe from where.
PW
Previous Topic:FilteredTree with TreeViewerColumns?
Next Topic:Add MRU to File menu defined in plugin.xml ?
Current Time: Sat Jul 19 08:02:13 EDT 2025
Powered by FUDForum. Page generated in 0.11390 seconds
