Home » Newcomers » Newcomers » how to use the Arguments in the run configuration(C program, running a text file in the command line)
how to use the Arguments in the run configuration [message #784068] Thu, 26 January 2012 21:45 Go to next message
void getInputFile(char** argv[]) {
//Local Declaration
FILE* spIn;
printf("\nRetrieving Data");
spIn = fopen("argv[1]", "r");
if(!spIn){
printf("\nCould not open input file\a\n");
This is a function that I have written in eclipse (Indigo). In my project folder I have 3 sub-folders the source folder, release folder and debug folder. I have also created a text file and placed a copy of this text file in each sub-folder. This are the steps I took read the text file. Run Configuration -> my project release folder is selected -> Arguments under the Program arguments I typed in the name of the text file inputFile.txt. And I clicked on the run button. but the error message I programmed came up. It seems as though eclipse cannot find my inputFile.txt. How do I correct this problem. Thank you!
Re: how to use the Arguments in the run configuration [message #784132 is a reply to message #784068] Fri, 27 January 2012 00:01 Go to previous message
Arrays in C start with indexes of 0. Try printing out argv[0] as part of the error message.
Previous Topic:Assigning a keystroke to a macro (practicalmacro)
Next Topic:Compatibility of InstanceScope in lower version of eclipse
Current Time: Sun Jul 20 02:27:21 EDT 2025
Powered by FUDForum. Page generated in 0.08352 seconds
